Panasonic PT-AX200U Bulb Options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-26-2009, 06:36 PM - Thread Starter
NickTF's Avatar
It's time to put the 3rd bulb in this projector and since i've ruled out the flickering problem being anything I can control or stop from occuring, atleast with the use of the ET-LAX100 replacement bulb, I'm wondering if there are any other bulps that work with this projector that are plug and play and may serve to stop flickering from occuring. I'm all ears if so or if there are threads discussing different bulbs.
The 2nd bulb has never seen eco mode, the first one did. There was no difference in occurence of flickering. Also, the picture i'mm getting at 1700 hours is substantially dimmer than the picture I got at 1700 hours with the first bulb. Perhaps spending about 100 hours in eco mode with the first bulb prolonged the picture.
I vacuum the filter and clean the projector religiously and the issue does not change with cables placement, orientation of the moon, whether I say my prayers before bed, etc. Sorry for my sarcasm but some of the things i've read regarding explanations of why this is ok are a little extreme.
In any event let me know if you know of any other bulb options besides the ET-LAX100 unit. Thanks.
29 Litres of Infinite Baffle Bliss. Oh, and the rest of the setup isn't too shabby either!
NickTF is offline
post #2 of 8 Old 12-28-2009, 07:57 AM
TF Ghost's Avatar
No, there is only one OEM lamp that fits the projector. Any other lamps will be lower quality Chinese knock-offs.
TF Ghost is offline
post #3 of 8 Old 12-29-2009, 06:28 AM - Thread Starter
NickTF's Avatar
Ok, thanks. I'll likely grab another bulb then look into a 3d replacement after the 3rd bulb is finished.
NickTF is offline
post #4 of 8 Old 04-23-2010, 08:58 PM
Ad-Rok's Avatar
Sorry for thread necromancy here, but I was wondering -- has anyone actually purchased and installed one of the Chinese knock-offs on the 'bay? The price difference is rather astronomical. Like, $370 vs $170. At that price, it's almost worth trying...or is it?
Cheers,
Adam
"Stereo replay never actually reproduces a musical event. The only thing you can hope for is a credible illusion. But it can be a very nice illusion." -Bruno Putzeys
Ad-Rok is offline
post #5 of 8 Old 04-23-2010, 09:04 PM
Sheridan1952's Avatar
Your timing is good....here is a thread that is very recent
http://www.avsforum.com/avs-vb/showthread.php?t=1244834
Bottom line..avoid the Chinese junk. Or any "knock-off".
Cheers,
Adam
Sheridan1952 is offline
post #6 of 8 Old 04-23-2010, 09:13 PM
Ad-Rok's Avatar
Yeah, I was wondering about folks who had specifically tried an ET-LAX100 knockoff, but I think I'm convinced. Not worth the risk.
Cheers,
Adam
Ad-Rok is offline
post #7 of 8 Old 03-27-2013, 03:47 AM
prashanth957's Avatar
I used a bulb which cost 200$ in 2010 and has crossed 1800 hours.The colours and picture clarity is still so clear. It is not showing any sign of aging. But i need to buy another one. Am not sure if mine was a kn ock-off or not as all the lamps are named ET LAX 100. i need to buy another one. I forgot from which online store i bought.
prashanth957 is offline
post #8 of 8 Old 03-27-2013, 07:37 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Originally Posted by prashanth957 View Post
I used a bulb which cost 200$ in 2010 and has crossed 1800 hours.The colours and picture clarity is still so clear. It is not showing any sign of aging. But i need to buy another one. Am not sure if mine was a knock-off or not as all the lamps are named ET LAX 100. i need to buy another one. I forgot from which online store i bought.
I'm not sure there is a question in your post. If you purchased the lamp assembly in 2010 for $200 then most certainly it was a knock-off. If you have been satisfied with your current clone bulb you should no trouble finding a company offering a similar bulb.
If you desire an actual OEM lamp assembly try:
Provantage - $310 plus shipping.
http://www.provantage.com/panasonic-et-lax100~4PANP06P.htm
B&H Photo and Video - $345 plus shipping.
http://www.bhphotovideo.com/c/product/461696-REG/Panasonic_ET_LAX100_ETLAX100_Replacement_Lamp_for.html
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
