New Casio projectors: LED/Laser, 720p, compact - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #871 of 878 Old 12-30-2012, 11:55 AM
Sincerity's Avatar
And mind sharing your video settings from cow boom deal?^
Sincerity is offline
post #872 of 878 Old 12-30-2012, 06:47 PM
kblarg's Avatar
I would set your PS3 on 720p and see if that solves it.
The settings I found earlier in this thread:
Set in Theater mode
Brightness -20 contrast +5
Bal.colors normal with -10 red, 0 green, +50 blue
You may even want to make it -15 red or so. It looks alot better in Theater mode than the default.
kblarg is offline
post #873 of 878 Old 01-02-2013, 08:36 AM
blee0120's Avatar
Quoted: 651 Post(s)
Liked: 328
Just grabbed one of these for $375. Its basically something that I can use without turning on my jvc for my nephew and the occasional tv watching. Hopefully I can watch the thing, my nephew should not care too much about it. Its bright and led
blee0120 is online now
post #874 of 878 Old 01-05-2013, 11:15 AM
Sincerity's Avatar
720 didn't solve it...also mini HDMI from nexus 10 woulndt display but did on led right beside it...any ideas? I assume nexus outputs 1080p?
post #875 of 878 Old 02-10-2013, 09:09 AM
LeonZA's Avatar
Quoted: 16 Post(s)
When I try to switch it on I can hear the fan or colorwheel starting to spin, but the after 4 seconds it stops and the TEMP and POWER lights remain red.
I don't feel like wasting my money anymore sending it back again(about $250 for oneway shipping). Last time I had to send it back, because I had lots of dead pixels(stuck mirrors).
I think it might be the colorwheel, because a few days back I thought I heard a weird sound and sometimes it looked like the image's color changed a bit..
Anyone had the same problem before?
EDIT: I have the Casio XJ-A230. I just ordered myself a LG PA70G. Hopefully I would be able to live with the diamond pixels and no zoom...also I hope the focus is 100%.
On the plus side I won't see any rainbows anymore...I hope
LeonZA is offline
post #876 of 878 Old 09-17-2013, 05:16 AM
Sincerity's Avatar
having all sorts of issues getting hdmi to display still. With old hr22 Dtv box, using hdmi out to powder monoprice splitter, one run to casio, one run to led I had no problems unless I switched to 480 resolution. then it wouldn't display in sd. But as long as I ran 1080i resolution on hr22, all was well. PS3, roku etc. never would display directly via hdmi right out of the box. Now, upgraded to hr34 and trying to use a genie mini client....no signal on casio. It displays the setup screens, but as soon as content comes in, blank. obviously displays fine on the led in the same hdmi chain. Few questions assuming its an hdcp issue and there's no way around it:
Is there a cheap fix rather than buying new projector?
if I output or use hdmi or component to vga is it still hd picture?
is this isolated to my unit as in a faulty hdmi port or something or are all xj140's this way due to aforementioned hdcp handshake issues?
post #877 of 878 Old 05-27-2016, 05:38 PM
ultracitrus's Avatar
Liked: 5
my Casio XJ-245, 2500 lumen led/laser hybrid is a CHAMP!
Still running strong & bright after 3 years of use (ECO mode, normal mode is way to loud/distracting)
great inexpensive option for rooms with some ambient light
PlayStation 4 games look sharp, input lag seems to acceptable (no formal for FPS style games, not much if any difference to a standard LCD monitor.
ultracitrus is offline
post #878 of 878 Old 05-27-2016, 06:18 PM
JackB's Avatar
Quoted: 579 Post(s)
Liked: 102
When are one of these Casio laser going to offer 1080P?
Jack
JackB is online now
