Proxima DP8000 - ASK C300 Projector Repair - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-08-2010, 09:10 PM - Thread Starter
ounvme's Avatar
I have had 2 of these projectors for a long time. They are amazingy bright and work well with 720p. Recently one of the projectors went crazy and the colors are out of sync. I poked around inside some and could not see any manual adjustments. I do not have the service code to check any settings in the hidden menu. Is there a way to make adjustments with a computer or is it time to look for a new projector? On a 120 inch screen the convergence is off as follows.
Blue Shifted left 3 inches down 1
Red Shifted down 1 inch
Picture is great other than that.
Thanks for any input!!
ounvme is offline
post #2 of 3 Old 01-18-2010, 11:08 PM - Thread Starter
ounvme's Avatar
Well after a ton of searching and find that the only way to fix this is in the service menu. That leaves me with 2 choices. Try all 888,888 combinations or find a way to read it from the firmware. Either way its not going to be fun and its going to take alot of time...
ounvme is offline
post #3 of 3 Old 09-24-2011, 11:41 AM
cross731's Avatar
Hey ounvme. Were you able to find how to enter the service menu? I'm trying to find it myself. I have no luck with the usual search engines.
cross731 is offline
