Mits HC3800 Tweakers Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 102 Old 11-29-2010, 01:58 AM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
What contrast setting(#) are you using?
Is anyone using the Pan. BD65 player?
I want to see if I'm in the ballpark because I get different results with different cal. discs.
Jim McC is offline
post #92 of 102 Old 09-11-2011, 05:12 PM
jamieuk147's Avatar
Quoted: 76 Post(s)
Anyone upgraded from the HC3800 ? If so what to and are you happier ?
jamieuk147 is offline
post #93 of 102 Old 09-16-2011, 11:31 AM
jamieuk147's Avatar
Quoted: 76 Post(s)
Not sure if its just me, but I always seem to be messing with my sharpness dial as it seems to be out of sharpness most of the time.
Is this a fault ?
post #94 of 102 Old 09-17-2011, 12:48 AM
fleaman's Avatar
Quoted: 78 Post(s)
Liked: 121
Focus adjustment (ring on the PJ) or sharpness control in the PJ menu?
If the focus ring, you should only focus after about 30-60 minutes of warm up. It's focus changes a little from cold to hot (common with many PJ's). Focusing when warmed up allows you to watch most of the movie in the sharpest focus.
If done cold then it will go a little outta focus after warmed up.
fleaman is online now
post #95 of 102 Old 01-05-2012, 08:30 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
What sharpness setting # are you using? Which test pattern/disc did you use? Thanks.
Jim McC is offline
post #96 of 102 Old 01-05-2012, 09:10 PM
fleaman's Avatar
Quoted: 78 Post(s)
Liked: 121
I'm at #2.
On test patterns it appears that #1 is better (less ringing), or even #0, but on video content and from a seated position I prefer #2, it at least makes it appear sharper and I can't see any ringing from my seated position.
post #97 of 102 Old 10-13-2012, 02:36 PM
burton123's Avatar
is there a way to check the firmware version? i couldnt find it under the menu...
burton123 is offline
post #98 of 102 Old 10-15-2012, 09:30 AM
Patrick Murphy's Avatar
Quoted: 67 Post(s)
Liked: 65
On the pj, not the remote; UP, DOWN, ENTER simultaneously.
Patrick Murphy is offline
post #99 of 102 Old 10-15-2012, 10:13 AM
burton123's Avatar
thanks a lot...
post #100 of 102 Old 10-15-2012, 12:01 PM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
And they really need to be simultaneous. It took me multiple tries before I did it right.
Selden
Selden Ball is offline
post #101 of 102 Old 10-15-2012, 12:50 PM
burton123's Avatar
post #102 of 102 Old 10-17-2012, 09:38 PM
burton123's Avatar
it says
S/W Version 1.00HC3800
S/W Version (SUB) 1.00 SCU7
S/W Version (DDP) 0.13 DDP1
I am not a projector expert but I bought this from a local seller with OEM brand new bulb for $400. I haven't seen any problems so far except when going to full screen mode from youtube or any other player, it flicks for one sec which doesn't bother me at all. BUt again, I am not an expert, this is the first projector that I have ever had.
