Problems resetting lamp timer on Sony VPL-HS51 - AVS Forum | Home Theater Discussions And Reviews
Old 02-18-2010, 07:14 AM - Thread Starter
swassbac's Avatar
I replaced my VPL-HS51 bulb after about 2500 hours of use. I put the unit in standby and did the RESET,RIGHT,LEFT,ENTER key sequence but still get the "Replace Lamp" message and the timer has not reset. Have tried multiple times with different key press lengths, tried it when the unit was on and in standby. Tried using the arrow and enter keys on the unit, even replaced the remote control batteries. Does anyone have any suggestions?
I am wondering if I need to pull the projector down again and put the old bulb in and try again - I wonder if there is some sensor that didn't get tripped when I replaced the bulb.
Help...
swassbac is offline
Old 12-02-2012, 01:06 PM
drmuzzbuzz's Avatar
Speed seems to be the key. The projector has to be in standby. You need to do the sequence as quickly as possible. Officially, in under five seconds. Like you, I tried over and over again before it finally worked. I also did the up/down arrows. Hard to know what worked since the projector is off, but no more message on start up!
drmuzzbuzz is offline
Old 09-29-2013, 06:31 PM
kova3's Avatar
NOTE - the projector must be in standby mode. standby mode is when the unit is plugged in and NOT on - there will be a red light on the top of the unit. If the light is green and the projector is projecting a blue screen, you are not in standby mode and cannot reset the timer.
kova3 is offline
