Optoma HD66 settings - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By dajaga007
post #1 of 24 Old 02-22-2010, 06:15 PM - Thread Starter
dajaga007's Avatar
Hey guys im getting my HD66 hopefully on friday. I hear that the default settings make this projector not look so good, so i am wanting to get a collection of everyones setting and get the most out of it.
lets try to keep this post strong
This one is done by a forum member consciousness
Display Mode: User 1
Brightness: 48
Contrast: 45
Sharpness: 7
Saturation: 47
Tint: 49
Advanced
Degamma: PC ( Seems to give those inky blacks w/out sacrificing detail combined with other settings)
Brilliant Color: 5
Color Temp: Warm
Color
Red Gain: 4
Green Gain: 0
Blue Gain: -5
Red Bias: -2
Green Bias: -2
Blue Bias: -2
Color Space: YUV
DISPLAY
Format: Native
Screen Type: 16x9
OPTIONS
Lamp Settings: STD
PS3
DISPLAY SETTINGS
HDMI 720p
RGB Full Range: On
Y Pb/Cb Pr/Cr Super-White (HDMI): On
VIDEO SETTINGS
BD/DVD Video Output Format (HDMI): Y Pb/Cb Pr/Cr
BD 1080p 24 Hz Output (HDMI): On
dajaga007 is offline
post #2 of 24 Old 03-17-2010, 09:31 PM
matt314159's Avatar
I've got one on the way from dell right now, within a week or so hopefully I can dial in my own settings and report back.
In the meantime if anyone else out there has settings, post them! It will help a lot of people!
matt314159 is offline
post #3 of 24 Old 03-18-2010, 01:31 AM - Thread Starter
dajaga007's Avatar
Brightness: 35
Contrast: 65
Sharpness: 7
Saturation: 47
Tint: 49
Advanced
Brilliant Color: off
Color Temp: Warm
Color
Red Gain: 4
Green Gain: 0
Blue Gain: -5
Red Bias: -2
Green Bias: -2
Blue Bias: -2
Color Space: YUV
DISPLAY
Format: Native
Screen Type: 16x9
OPTIONS
Lamp Settings: STD
as some one else posted he recommended that you turn off brilliant color, up the contrast and lower the brightness.
The blacks look wicked, the colors pop out.
before the blacks looked kinda washed out
Skylinedtt likes this.
post #4 of 24 Old 06-07-2010, 05:13 PM
scaf7's Avatar
Great info what are you guys have for screens?
I am using ultra pure white and it looks great but thinking of going gray.
scaf7 is offline
post #5 of 24 Old 07-11-2010, 10:58 AM
elixir518's Avatar
Hey all, thanks for posting these recommended settings, I look forward to trying them out. Currently I'm only playing DVDs from my laptop hooked up to the projector. I don't see the "saturation" and "tint" adjustments, can anyone help me out? Thanks!
elixir518 is offline
post #6 of 24 Old 07-11-2010, 04:19 PM - Thread Starter
dajaga007's Avatar
saturation and tint is only for component cables. you dont get it for the hdmi cables
post #7 of 24 Old 07-11-2010, 05:25 PM
elixir518's Avatar
Oh, I see. Thanks for the reply. I'm using a VGA cable to my laptop not HDMI, but apparently it's the same end-result. Bummer. Well, I wonder how it will look making all the other adjustments except "saturation" and "tint".
post #8 of 24 Old 07-12-2010, 01:10 AM
Mitsu52Guy's Avatar
Just an FYI on these settings. I used them as my initial settings, as the defaults are all wrong, and got a very nice picture. I then recalled some recommendations from projector central and decided to try those. For ME in MY setup ( low light with a black widow DIY screen) their settings, which include a low brightness high contrast combo, works better. I get a picture that looks every bit as good as my 52" RP DLP. These settings were later confirmed against a DVD than had some tests on it. Might be worth checking. I have my Brightness on 45 and Contrast on 70. Sharpness is set to 7 and Color Bril. Is set to 3. Color settings are still from this post On my screen it gives a very nice clear and true to life picture.
Prior to making this change I had really thought about returning the 66 for a 20 but not now.
Mitsu52Guy is offline
post #9 of 24 Old 07-12-2010, 01:18 AM
AzN_plyR's Avatar
Does those settings include any color gain/bias?
Also, any chance you have the link to that thread/review?
AzN_plyR is offline
post #10 of 24 Old 07-12-2010, 11:20 AM
Mitsu52Guy's Avatar
I used the color settings from this thread. Used contrast, and brightness from here.
post #11 of 24 Old 07-12-2010, 12:26 PM
elixir518's Avatar
Thank you, and yes, this setup seems to be working pretty well so far. What are you connecting through... a laptop? gaming console? HDMI? I'm only using a VGA cable hooked up to my laptop. Admittedly the biggest difference in my overall picture was going into the display settings of my Macbook and where I can select a display profile... I chose "Color LCD" over "VGA Display". To be honest, I'm a newbie and stumbled upon this adjustment, but it made a big improvement!
post #12 of 24 Old 07-12-2010, 03:17 PM
Mitsu52Guy's Avatar
I've got my HDMI hooked up to my Directv HDDVR and VGA to my DVD player.
post #13 of 24 Old 07-25-2010, 07:24 PM
Railroad5's Avatar
Those settings are working out great except for the YUV color space. It makes the colors look very off and some things overly bright. Is there any reason why?
Railroad5 is offline
post #14 of 24 Old 01-04-2011, 05:57 PM
augiedoggy's Avatar
Has anyone actually use a spectrometer and calibrate with actual equipment to 6500k instead of by eye? If so I would appreciate it if you shared.
The mention of color saturation and tint leads me to believe those settings were set up on an analog video source which in it self could have been off and the warm and pc gamma settings just dont seem right going by the calibrated settings of my hd 65 from projector reviews site and my old hd70...
augiedoggy is offline
post #15 of 24 Old 02-12-2011, 09:04 AM
misckramer's Avatar
Just a bump and a follow up.
Wonder if anyone has ever used something like "Avia II: A Guide to Home Theater" and have any settings or suggestions for using it.
I've queued it up from netflix, should be here in a couple days and looking for feedback/suggestions/comments . . .
misckramer is offline
post #16 of 24 Old 04-20-2011, 08:57 AM
booley's Avatar
Optoma is no help with hd66 info!
I am very disappointed at the lousy tech support at Optoma these days. It wasn't like that five years ago when I had a Movietime (actually bought five of them!).
My problem is the HD66. I was trying to calibrate it since I am soon to have the 3D-XL added to it. No matter what I do I can't get a rich picture. It looks rather weak, no punch. The manual says to put it on video and then you get saturation control and tint control. Well, no good because they don't tell you that only works with the composite output. Who would use that with blu ray??!!
I followed settings suggested here on the forum and they give a nice color balance and take away the harsh whites I had driving some controls at max. (What happened to white peaking control that the older projectors had? That helped eliminate that type of noise). But the pic still looks rather weak--like more contrast is needed. It is plenty bright, sharp, etc.
BTW, the Projector Central review said the calibration out of the box is pretty bad (agreed), but they also said they raised the saturation considerably. I can't believe they were using anything other than HDMI!
Thanks for any help you can provide!!
booley is offline
post #17 of 24 Old 05-21-2011, 07:51 PM
slvramalgam's Avatar
Is it just my optoma hd66 but there are few features i don't have in my settings menu i.e. Saturation, tint. On the other hand, i have yellow, cyan and magenta in the color settings. Bought my projector around may 2010.
slvramalgam is offline
post #18 of 24 Old 05-21-2011, 07:53 PM
Nvm, i know why.... I'm using hdmi.
post #19 of 24 Old 03-16-2012, 09:24 PM
stellarsky's Avatar
Oh man!!! Thank you guys for this thread.. I used some of these suggestions on my Optoma 350wpro....beautiful! The screen is 91" diag... Wow! We haven't even ceiling mounted the projector yet.
stellarsky is offline
post #20 of 24 Old 03-24-2012, 10:37 AM
brejneff's Avatar
Really helpful post but not sure if the settings are calibrated for HDMI input. Degamma PC and colorspace YUV doesnt seem to be ok. Anyone with different settings?
brejneff is offline
post #21 of 24 Old 03-24-2012, 03:20 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
If any of you are in the Philadelphia PA area I would be happy to provide a full calibration on your projector. I am a DIY enthusiast so can't really charge for the service but I have the equipment and the know how.. (C6, i1pro Calman, Panasonic 210 BR) PM me if you are close by. I live in Delaware county so within an hour or so...
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #22 of 24 Old 04-07-2012, 11:47 PM
alco19357's Avatar
I'm looking into the HD66. Quick question, how does this thing handle 3D? I'm not using it for 3D but will want it there if I want 3D soon. (Low budget now)
Also, brightness... It will be in my bedroom (which has double window on south-west side with blinds that are good but obviously do not block out ALL sun. Will use mostly at night though. The projected screen/wall is facing the west so light MAY shine on it. I'm looking to have the projector in my closet (about 13'7" from screen). Projector central says something like 33 foot lamberts produced with this throw. Is this too bright for my current layout?
Thanks for the help!
Alex
alco19357 is offline
post #23 of 24 Old 07-09-2012, 07:32 AM
dentjoseph's Avatar
Hello all,
I have an optima hd66. Your advised settings worked great.
I tried to use it for 3d for the first time this week with how to train your dragon half sbs which i watched it on my panasonic 3d tv and popping out was awesome. I hooked my projector to my mac-mini via vga cable send projector 120hz signal. 3d option activated and used dip link with optoma 101 glasses but the image wasn't like 3d. The image was barely popping out.
Is there something wrong with my settings or my computer isn't good enough for that kind of use. If I buy a converter box do you think i'll get a better pop-out image?
Thanks for the help
Joseph
dentjoseph is offline
post #24 of 24 Old 08-29-2012, 09:45 AM
XRA
XRA's Avatar
It's 3D-Ready, not 3D native. You would need one of these to view 3D. My HD66 gets here tomorrow. biggrin.gif
XRA is offline
