PT-AX100, bad lamp or failing projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-12-2010, 05:29 PM - Thread Starter
henrikvg's Avatar
Hi, I hope someone has seen this one before,
The other night my PT-AX100E crossed the 1800h mark and told me it was time to replace the lamp. Fair enough, but today I noticed something I've never seen before, the top of the screen has a brown streak to it that is visible when the PT-AX100E is projecting bright light. Could this be due to the lamp getting old and failing? I really don't want to buy a new lamp if the projector itself is dying since I have no warranty left.
A friend of mine, with another brand, had a similar issue (but blue, and to the right of the screen) that he thought was due to the lamp getting old, but after he bought and installed a new lamp things just kept on getting worse and to the point that it's almost unwatchable now. I really want to avoid that, a new PT-AX100E lamp is almost half the price of what a brand new PT-AX200E would cost me here! :/
henrikvg is offline
post #2 of 7 Old 04-12-2010, 06:12 PM
Sheridan1952's Avatar
Not the lamp, they just don't do that. Problems like that are attributable to either burned polarizers or degrading LCD panels.
Sheridan1952 is offline
post #3 of 7 Old 04-13-2010, 09:35 AM
TF Ghost's Avatar
^ What Sheridan said. For the price of a lamp and the repair you can get a brand new AX200.
TF Ghost is offline
post #4 of 7 Old 04-13-2010, 01:25 PM - Thread Starter
henrikvg's Avatar
Thanks for the replies!
I was afraid this was the case. For reference, this is how it looks,
Like I initially stated I've had 1800h on my PT-AX100, and I have a hard time coming to terms with the fact that it didn't last longer than the lamp itself - like you said, for the price of a new lamp and repairing it I could just as well buy a new PT-AX200. I had to send my PT-AX100 to Panasonic in the UK a year ago to get the notorious iris problem fixed, and like many I found their customer support to be excellent. I was sure that whenever I upgraded I would go Panasonic again, now though, I'm not so sure anymore
henrikvg is offline
post #5 of 7 Old 04-13-2010, 05:27 PM
I don't believe there is a projector out there, regardless of make or technology (DLP vs LCD) that is immune from problems. This is not to say that you WILL have a problem, only that it is not impossible.
post #6 of 7 Old 04-13-2010, 06:18 PM - Thread Starter
henrikvg's Avatar
I know, I was just expecting it to last a lot longer than it apparently did, or at least I wasn't expecting it to show signs of failure until the second lamp. If I hadn't asked here for advice I would have gone ahead and bought a new $500 lamp (yes that's actually the cost here) and felt so cheated. I always thought I'd continue on the budget PT-AX* line because apart from this issue here it's really been a great ride, but maybe it's time to look at some more expensive offerings this time around then...
Thanks for all your help!
henrikvg is offline
post #7 of 7 Old 04-14-2010, 01:53 PM
TF Ghost's Avatar
Given your concerns I would purchase a projector with a better warranty and/or get a 3rd party extended warranty. That way you'll be covered when your new (insert model name) fails, which it will eventually do. Likely not after only 1800hrs, though...
TF Ghost is offline
