HDMI no signal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-18-2010, 07:26 AM - Thread Starter
tjhumbert's Avatar
Constant drop out with my receiver and losing video signal. no rhyme or reason why it drops out on the cable box and the Xbox 360
Set up-
Optoma HD20
DENON DHT-590BA AVR-590.
source devices are 2:
Samsung HD cable box SMT-H3260
Xbox 360
HDMI to all devices
projector is only 20 feet from the receiver.
I have tried all types of HDMI cables- the cheap and I even tried the high end Monster brand with insulation.
tjhumbert is offline
post #2 of 6 Old 04-18-2010, 09:23 AM
Brian McKay's Avatar
Set up-
Optoma HD20
Xbox 360
HDMI to all devices
For a quick test, try hooking up one of your components directly to the HD20 and bypassing the Denon. If you still get drop outs then you probably want to look at the cable (again). If not then its something with the Denon and you may want to search the Receivers thread for a setting or F/W upgrade.
Brian McKay is offline
post #3 of 6 Old 04-18-2010, 04:00 PM - Thread Starter
tjhumbert's Avatar
Thanks Brian- good call, I did connect the projector directly to the source (xbox or the cable box) and it does not drop out. so what kind of setting would I need to look for in the receiver? Thanks I will check for a F/W upgrade too.
post #4 of 6 Old 04-18-2010, 05:54 PM
I found this link for you which has all the HDMI settings for your receiver...
http://batpigworld.com/setup.html#hdmi_setup
I'd start with that and see what works. There is also an "official" thread for your receiver on these forums in the appropriate section.
post #5 of 6 Old 04-18-2010, 09:11 PM - Thread Starter
tjhumbert's Avatar
man, that rocks! I will give it a try- I have been dealing with this for 2 months.
This is the best direction I have gotten.
post #6 of 6 Old 02-15-2012, 06:08 PM
rhodes123's Avatar
I have a ESP200AU connected via HDMI to a Yamaha receiver via HDMI to a LG Blue Ray Player - all brand new.
All has been working fine since purchase 2 months ago (though the hdmi projector connection is quite touchy and loses signal easily).
We went to turn it on the other night, same as always and the projector display said no signal (usually when it does this we just fiddle with the hdmi and it comes back on - but this time, no good).
I have moved the BD and AVR so they are near the projector, tested a number of HDMI cables and lengths (all working fine in all different arrangements with my other tv) - still no signal with the proj.
If I plug the BD directly into the proj, the start up screen comes on, then when it should go to the main menu, it goes back to no signal.
Can't get my laptop display to go onto the proj at all - which I used to be able to do (directly or via AVR) – the same scenario works using my tv as the display.
The normal BD > AVR > Proj setup works fine with component cables. What could be the problem?
Also, the AC adaptor blew so I am waiting to see how I get a new one of those - I bought a 5 year warranty with the projector.
I was thinking it must be the hdmi ports somewhere but considering the proj comes on with the direct BD connection, I guess that not it. From the bit of research I've done, maybe a resolution issue??
Any help would be great.
Thanks, Amanda
rhodes123 is offline
