Nikko R2-D2 Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-03-2010, 07:00 PM - Thread Starter
perello23's Avatar
Hi all. I have the Nikko R2-D2 Projector that came out a cupel of years ago and I'm having a tuff time tying to get it service for a new lamp and resent lamp hours. Can anyone out there help me?
Ed
http://www.nikkor2d2.com/
perello23 is offline
post #2 of 18 Old 07-05-2010, 02:20 PM
LD-838D's Avatar
Quoted: 134 Post(s)
Liked: 36
This is my friend I recommended this site to him. Does anyone know of a projector service company that could help him out? Since the company that made the R2-D2 projector is out of business he is looking for a company that could service/repair/replace the Texas Instruments projector housed inside the R2-D2.
He is desperate and will appreciate any recommendations.
Thanks ^_^
LD-838D is offline
post #3 of 18 Old 07-05-2010, 05:36 PM
BuffaloJim's Avatar
Nikko is the same company that produces RC cars. I would contact them to see who was the OEM of the projector. From there it would seem to be relatively easy to get the projector serviced. It sounds like you may just need a new lamp. In fact, if you simply remove the lamp assembly (probably user serviceable) you might find the manufacturer's part number right on it.
Jim
BuffaloJim is offline
post #4 of 18 Old 07-05-2010, 06:39 PM - Thread Starter
perello23's Avatar
Hi Jim. I did that . I didn't get a response. The way they built this thing they hidden all the screws. I only found one. They made this projector not to be opened by there owners .
post #5 of 18 Old 07-20-2010, 08:39 AM - Thread Starter
perello23's Avatar
Is there sowone who can help me out there??
post #6 of 18 Old 05-20-2011, 05:13 AM
giantpopples's Avatar
I know this thread is pretty old, but if it could help you can contact the european service center based in the netherlands with this mail dneufeglise@zesgoes.nl.
This is the mail i used to get my R2D2 repaired when it had a broken DVD unit (between september 2010 and February 2011), maybe they could help you out !
I didn't know it was out of business, you scare me now.. (i have a LOT of hours left on ine but still...)
giantpopples is offline
post #7 of 18 Old 08-13-2011, 02:29 PM
greygorey's Avatar
I found out how to open both the body and the head. I also know the type of projector bulb needed as I just replaced mine. (cost me 125 I think). my original bulb got to 5000 normal hours and 2000 eco hours before turning off every few minutes. pretty amazing life especially living in arizona with the dust. email me at greghazensays@aol.com for info. I should respond within a day. ))
greygorey is offline
post #8 of 18 Old 05-21-2012, 05:07 AM
purpleyez's Avatar
Hello all,
I have this same projector/DVD player system (and I love it) but I would really like to know how to open the body and head as greygorey has discovered. I will need to replace my projector lamp sometime so need to identify that and I am also interested to see what the DVD player component is. I tried emailing greygorey but I did not get an answer so maybe that email doesn't work anymore? Any help or suggestions appreciated.
If I do get it open and find out what the internal components are I will post all info for future reference.
Cheers,
Purpleyez
purpleyez is offline
post #9 of 18 Old 03-08-2014, 08:04 PM
R2D2Fan's Avatar
I don't know if anybody still needs the info, but I dissected my R2D2 tonight and really took more off than needed.  But, I figured it all out so if anybody has questions.  Let me know.  The top dome comes off with 3 phillips-head pretty cleverly hidden screws.  Two are in the little cylindrical things poking out and one is behind a sliding plastic cover to the left of the main projector window.  The bulb is OSRAM P-VIP 200/1.0 E20.6.  They are all over eBay, Amazon, and others.  The cheapest I found is on eBay for $60.  The rechargeable battery is removed even easier.  There is just one screw to reveal the compartment and one screw holding the battery.  It slides right out.   May the force be with you!
R2D2Fan is offline
post #10 of 18 Old 06-15-2014, 05:22 PM
Liked: 0
Hi R2D2Fan, and thanks for the info. Can you just add where the battery compartment / screw are located? My R2D2 has had very light use and is working fine now, but I do want to be prepared for when I need to replace the lamp and battery (or are there more than one?) Thanks!
R2D2-DLP is offline
post #11 of 18 Old 06-19-2014, 10:50 AM
R2D2Fan's Avatar
Battery Access
The battery is located in a compartment on his left side (as you're facing his front, the right side). You have to move his leg backwards (so he points up at the ceiling) to access the door. It's the 2"wide x 2.5" high square panel with vertical blue 'vents' (stripes). Remove the little grey circle sticker and there is the hex screw. Remove screw and panel and there is the battery! Pull to slide out. It's a Ni-MH 2,200 mAh, 7.2v. Mine doesn't hold a charge anymore so I'm going to take it to Batteries+ to see what they can do.
Good luck!
R2D2Fan is offline
post #12 of 18 Old 05-07-2015, 12:41 AM
Liked: 0
Hello;
I have a R2D2 too, bright "new" (as far as a never used 2006 r2d2 is new!). after a few hours, it started to show some white dots on the "screen", that are multiplying themselves !
As far as i understand, it is a dmp issue... I don't have a real clue about what is the dmp, compared to the bulb, but i guess it's related ? if i change the bulb (i understand it's a OSRAM P-VIP 200/1.0 E20.6), will my problem be gone ?
And if i, by any chance need to change the bulb, does anyone have pics about the screws and parts to remove, in order to access it ?
thanks for your help !
gileb is offline
post #13 of 18 Old 07-22-2015, 08:25 AM
Liked: 0
Originally Posted by gileb View Post
Hello;
Hi,
Have you had luck with this, as if not I may be able to help.
Mike
MikeFewtrell is offline
post #14 of 18 Old 08-19-2015, 04:48 AM
Liked: 0
Hi guys, my R2 has been working fine for years until tonight... Using it as a projector, the lamp turns on for about a minute and then I'm getting an error 40 and have no idea what the issue is (God only where the manual ended up, with kids moving out and back again over the past 5 years)
Anyone still have a manual and can let me know what the error code indicates?
Thx in advance
Yallume is offline
post #15 of 18 Old 12-06-2015, 01:46 AM
blx
Liked: 0
From french manual :
someone is too closed to the lamp or something is covering it.
I have the same problem.
Try to press on sensor button on remote control to stop this error.
blx is offline
post #16 of 18 Old 01-23-2016, 05:25 AM
Liked: 0
My R2-unit starts to show an increasing number of white spots on the picture. I suppose the procejtor is dying. Does anyone have any clue where to get the spare parts from and how to fix it?
Any help is deeply appreciated!
Regards from Berlin, Germany,
Mike
MikeDC02 is offline
post #17 of 18 Old 08-12-2016, 11:11 AM
R2_
Liked: 0
Hi all, I have one of these that has been in storage for a year or so now. Was all working fine, but now every time I put a DVD disc in, it gets ejected out after about 30 seconds without ever reading the disc.
Anybody else come across this problem, and if so how did you fix it? Can't find anything in the manual about it.
R2_ is offline
post #18 of 18 Old 08-20-2016, 11:37 AM
pabpoo's Avatar
Hi,
have the same problem, could be a bad laser. I just got a replacement dvd unit, but seems that the lens is a standard hop-120x, that is cheap to replace.
Anyone know how to remove the dvd unit from the body? I only know how to remove the head and body covers.
pabpoo is offline
