How much can you move a picture to the side with lens shift ? - AVS Forum
post #1 of 4 Old 08-31-2010, 03:51 AM - Thread Starter
jamieuk147's Avatar
I know a lot of this depends on the projectors capabilities etc but I am just wondering if i could get a way with putting a projector on a side table next to my couch and lens shift it over by quite a lot so its the picture is centre with were I sit.
I really dont want to be putting a projector on the ceiling as it stands out so much and a projector life is daft money. Is there some measurements i can give you were you can tell me if it would be possible ?
I have read the Sanyo PJ`s offer the greatest lens shift.
jamieuk147 is offline
post #2 of 4 Old 08-31-2010, 04:20 AM
lewis26's Avatar
Look in the manual of the projector online, and it will give you a percentage of the screen width.
lewis26 is offline
post #3 of 4 Old 08-31-2010, 06:31 AM
Sheridan1952's Avatar
Right, every projector is different, so you really need to consult the manual.
Sheridan1952 is offline
post #4 of 4 Old 08-31-2010, 08:55 AM
lewke's Avatar
I have an Epson 1080 which has a generous amount of lens shift, I have the projector on the left wall, but the lens is still within the screen image.....so you can get away with your situation if you use a big enough screen, meaning it will extend past your couch on both sides, with an Epson......
S=Screen
C=Couch
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
ProjectorCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
Check this thread to see a few pictures of my similiar setup
http://www.avsforum.com/avs-vb/showthread.php?t=1273385
lewke is offline
User Tag List
