3D with Acer H5360, Nvidia GT240 and X102's. Please help? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-31-2010, 12:22 PM - Thread Starter
svdmoot's Avatar
Can someone please help me to get a 3D image on my Acer H5360? I think I have all the right hard/software. This will not work out of the box. I figured that part out. What do I need to do? I already forced the Acer to accept the 120hz. Still on luck. Also trief Stereoscopic player. No luck with that one.
Please help?
svdmoot is offline
post #2 of 3 Old 08-31-2010, 03:29 PM
JOHNnDENVER's Avatar
You have 3D Vision from Nvidia?
Pretty sure it's required for 120hz page flipping 3D support for all such 3D Ready projectors.
JOHNnDENVER is offline
post #3 of 3 Old 08-31-2010, 11:02 PM
goldorak_20's Avatar
3D vision from Nvidia will work but since you got the x102 glasses (which the website of xpand states that it will work with the acer http://www.xpandcinema.com/products/...X102-home/dlp/
you might need then an ATI video card with iz3d driver but not sure of this, because the xpand x102 manual says you only need to set your projector to 3D mode!
anyhow here are some links to a webpage i found for the glasses that contains a link to user manuals: http://www.tru3d.com/products/view_p...0Starter%20Kit
I hope this help, unfirtunatly i dont have the projector that your are using to check if there is 3D mode setting, search for it.
goldorak_20 is offline
