JVC DLA-HD250 new entry level DILA - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 1878 Old 10-02-2010, 08:10 PM
cpc
cpc's Avatar
If the HD250 is an RS10 in matt black case, why are the specs for the RS10 32K:1 and the HD250 are 25K:1? Is it simply that JVC has not indicated that you can get up to 32K:1 with the HD250 by stopping down the iris? I think that was the case with the RS10, correct?
Where are the air intake and exhaust for the RS10 / HD350 and HD 250? How much space is needed on the sides and the back?
cpc is offline
post #92 of 1878 Old 10-02-2010, 10:15 PM
SED <--- Rules's Avatar
Quoted: 78 Post(s)
Liked: 70
I wonder how much blacker the blacks are on the RS40 compared to the HD250? I mean, how much difference is an extra native 25,000:1 native contrast?
SED <--- Rules is offline
post #93 of 1878 Old 10-03-2010, 09:05 AM
Kelvin1965S's Avatar
Quoted: 260 Post(s)
Liked: 161
A quote by GaryB of JVC UK when asked the same question on AVForums:
Europe is getting the 350. The US is getting the 250. They are the same. For some reason they've decided to be a little conservative about the contrast figure in the US.
My guess is that they've downspeced the HD250 to further distance it from the RS40 and possibly to make it seem like a different model to any previous one as they've not previously made a 25,000:1 CR model.
The air intake is on the front right as you face the lens and the air outlet on the side left as you face the lens.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #94 of 1878 Old 10-03-2010, 10:11 AM
cbaseuser's Avatar
Quoted: 33 Post(s)
Is there a pixel alignment feature? I know ther qc is probably decent and it wouldn't matter too much, but it's been a feature in the past.
cbaseuser is offline
post #95 of 1878 Old 10-03-2010, 10:34 AM
cpc
cpc's Avatar
Gotcha. Thanks for the feedback. Another AVS member sent me a link to the RS10U owners manual. The air outlet looks like it occupies the left side at the middle of the chassis. The owners manual points out you should place the projector almost 8 inches from a back wall.
I've checked my throw calculations and I can most likely use my prismasonic lens with either this HD250 or the Mits HC7000. My only concerns now are with sharpness and colour decoding. Colour is a personal preference and there are outboard CMS solutions available, and since the HD250 is a lower priced unit, an outboard CMS is a reasonably affordable option, IF one finds it necessary. I hope to hear more back from HD250 pioneers as to the sharpness. Reading the RS10 thread and RS10/HD350 reviews has generally made me feel that people were fairly happy with sharpness. Ultimately I would like to see one in person. The last high-contrast PJ I had in my setup was an Epson 1080UB Pro and I found it wierdly soft. I thought I read somewhere that the JVC RS10 was not as sharp as some of the newer Epsons (6500 UB for example). I'll keep searching for a local RS10 (or soon to be HD250) owner who wants to show off their PJ.
So being an entry level JVC LCOS PJ, where do we figure the HD250 will fit compared to the RS1, RS1x and RS2? I assume the RS15 was just an updated RS10? Is the HD250 essentially a replacement for the original RS1/RS1x?
cpc is offline
post #96 of 1878 Old 10-03-2010, 11:11 AM
Quoted: 260 Post(s)
Liked: 161
There is in my HD350, but it's largely irrelevant as it seems to be set already to the best alignment and it only allows a 1 pixel movement anyway (rather than some of the Sony ones that do a 'software' pixel shift.
The HD350/RS10 was a replacement model for the HD1/RS1 so it kind of fits above the RS1, RS1x and RS2. However some say that the RS2 has a better contrast than the HD350/RS10 as it achieves this without the manual iris that the HDxxx models have. If this helps.
I meant to say that I found my HD350 significantly sharper than the AE3000 that it replaced, but my AE3000 was a particularly poor example with uneven focus across the screen and visible uniformity issues (which I managed to adjust out to some degree, though it was never as good as the HD350).
post #97 of 1878 Old 10-03-2010, 05:59 PM
cpc
cpc's Avatar
Ok, that gives me an idea of the lineage of the RS10. Sounds like sharpness is fairly good overall. I'll hopefully have a look at an HD250 and see the sharpness myself.
cpc is offline
post #98 of 1878 Old 10-03-2010, 06:45 PM
MegaToad's Avatar
Does the HD250 have a 12v trigger?
MegaToad is offline
post #99 of 1878 Old 10-03-2010, 07:37 PM - Thread Starter
Woof Woof's Avatar
Quoted: 149 Post(s)
Liked: 83
I also found my AE3000 to be less sharp than the HD250
Woof Woof is online now
post #100 of 1878 Old 10-03-2010, 08:35 PM
TeeCue's Avatar
Any motorized lens memory like the AE 4000 ?
Teecue
TeeCue is offline
post #101 of 1878 Old 10-03-2010, 08:55 PM
cpc
cpc's Avatar
Ever since Panasonic introduced smooth screen I haven't found their pj's to be as sharp as I'd like. Granted they improved the smooth screen over time. Mitsubishi and some others chose Micro Lens Array to reduce the screen door effect. I found with 720p and now 1080p I don't notice screen door and the slightest defocus always cured sde without softening the picture. Of course with LCOS sde is no longer an issue.
Well, I imagine people will be getting HD 250 this week. Let's hope we get some more reports on the colour decoding and image sharpness etc.
cpc is offline
post #102 of 1878 Old 10-04-2010, 12:57 AM - Thread Starter
Woof Woof's Avatar
Quoted: 149 Post(s)
Liked: 83
No lens memory on the HD250.
post #103 of 1878 Old 10-04-2010, 09:50 AM
JackB's Avatar
Quoted: 480 Post(s)
Liked: 80
I did this upgrade too, well similar in that it was A E 3000 to HD350 (HD250 in a shiny box ). I just revealed in how dark blacks looked in mixed scenes and dark scene performance really was a step up. I also foun I lost about 25% in 3 months by selling the AE3000 when I did, but I don't regret it. I found it sharper as well, but this could have been due to my A E 3000 being a particularly poor example on the focus side. Now, some 20 months on I'm still enjoying it with no pressing need to upgrade...in fact I've kind of made a plan that I'll only upgrade it when X7 models fall into my price range used (hopefully when the following year's models are launched ).
Yes, that's exactly it as posted by GaryB (he works for JVC UK) in another thread: The HD250 is the same internally as the HD350. You'll probably find that it's not quite as oversaturated as the HD1, but it is still quite a long way off especially the green. I bought an early adoptor VideoEQ Pro to use with mine and the colours are now spot on. It also works a treat with a used Isco II lens if anyone is interested (at a very long throw setup mind).
Is last year's HD 350 the same as the RS15 or RS25?
Jack
JackB is offline
post #104 of 1878 Old 10-04-2010, 03:04 PM
Daniel Hutnicki's Avatar
Does this projector have sealed display panels, so you don't have to worry about dust blobs
I have owned three different JVC lcos machines and I have never had an issue with dust blobs. Seems to be an issue with LCD machines although I know it still exists,its not a prevalent as it used to be
By the way, our HD-250s are coming in so we will have a quick turnout around on them
As for the issues with lack of features, this is JVC entry level projector and its well priced. People paid a lot more for the RS-1,2,10 and RS15 series projectors and you will probably get the same or better picture. The auto lens are great, but lets be honest, unless you do the poor mans 2.35 , once you set the lens, you wont have to play with it again. CMS would be nice, but a good grayscale calibration will do wonders for your picture and CMS isnt necessary
Daniel Hutnicki is offline
post #105 of 1878 Old 10-04-2010, 04:35 PM
dswdallas's Avatar
Well, two sayings come to mind after my pulling the trigger on the HD250. First from Vito Correlone "We'll make him an offer he can't refuse".. Made the mistake of calling Jason at AV Science and that's what happened.
Second - Old Irish saying - "May you be in heaven half an hour before the devil knows you're dead". If I don't have this up and running before the wife sees it (so she can see how good it looks) I'm dead (or severely wounded).
I've been using a Mits HD1000U (only 600 hours) in a dedicated media room and have been stalking the Panasonic AE4000 forum and the Epson UB8500 and UB8700 forums and wanted to see what might come out of Cedia. Never thought I could own a JVC ($5000 and up is out of my league). Now the fun begins.. Hope to have it by the weekend (they say they're coming into stock now).. If I never post again please check the obits.
dswdallas is offline
post #106 of 1878 Old 10-04-2010, 04:49 PM
dswdallas's Avatar
After mounting the HD250, will need a suggestion on screen material. Light controlled, 13-14ft throw, at this point DIY 16:9 - 106" diagonal white professional material screen with 1.0 or so gain. Don't want to change unless I need to. Don't need to give more ammo to the better half. :-)
post #107 of 1878 Old 10-04-2010, 11:52 PM
thebigeast44's Avatar
dallas - you may want to do what I did when I was deciding which screen material to buy - simply call up the manufacturers and get a bunch of free screen samples. Then try them out and make your own call - you cannot do better then seeing how they perform in your own room.
thebigeast44 is offline
post #108 of 1878 Old 10-05-2010, 12:18 AM
eummagic's Avatar
Can this be decent enough with tolerable brightness in a dark room for a big screen of 130" diag or more?
eummagic is offline
post #109 of 1878 Old 10-05-2010, 07:20 AM
mastiff34's Avatar
I was poking around on projector central, does anyone have a projector calculator for this projector? I am interested in upgrading my Sharp 12000 mkII, I need to make the hop to 1080p!!
Thanks in advance!
Loganed on 4/8/2008
List to be completed
Install blinds - DONE
Finish plumbing my bathroom - WIP
Build EQ Shelves - WIP
Program insteon - DONE
My Build Thread
mastiff34 is offline
post #110 of 1878 Old 10-05-2010, 07:40 AM
chasiliff's Avatar
Quoted: 51 Post(s)
Use the projector calculator for the RS10.
chasiliff is offline
post #111 of 1878 Old 10-05-2010, 08:23 AM
mastiff34's Avatar
Thank you!
Loganed on 4/8/2008
My Build Thread
post #112 of 1878 Old 10-05-2010, 11:30 AM
For screen materials, you would do the following
white 1.3 gain screen if you have no ambient light and dark walls, ceilings and carpets
white 1.0 gain - same as above except it better be a dark as a cave
grey screen - lots of ambient light
If you have no ambient light, but light color walls, gray maybe the way to go but i kind of like white even though the picture will be affected by the light bouncing off the walls back to the screen
Dalite HP is a great compromise. Its white, deals with ambient light and white walls really well. Has high gain if the projected is table mounted but lesser gain if ceiling mounted
post #113 of 1878 Old 10-06-2010, 08:53 AM
Come guys, someone must surely want to talk about this projector
post #114 of 1878 Old 10-06-2010, 09:31 AM
craymail's Avatar
I will be talking lots when I get mine!!! I ordered it on Friday from a local dealer up here, which although paying more than the US, it makes it easy for me. He is hoping to get it in a couple of weeks (I am #1 on his pre-order list).
Being my first projector, I still have a lot of unknowns (screen size/gain/etc...), how and where to mount it (bought a chief RPA-233 mount from the same dealer). The plan is to get the projector, see what distance I prefer and see what size I like it at ... somewhere around 106" most likely.
I am slowly getting the rest of the room completed to a point where when the projector arrives I can hook it up (even if it is just sitting on a table at first). The room is 11x22, in a basement with no windows, so I have a decent setup. Furniture is already in place, with 2 rows ... first being about 13 feet back.
I never thought I would be able to afford a JVC, and it is a slight gamble buying something you haven't demo'd, but I am confident this will be a winner.
craymail is offline
post #115 of 1878 Old 10-06-2010, 09:57 AM - Thread Starter
Woof Woof's Avatar
Quoted: 149 Post(s)
Liked: 83
Too busy enjoying it
post #116 of 1878 Old 10-06-2010, 12:56 PM
the funny thing about buying JVC projectors is that for the most part, most people buy them without ever seeing one live. This has been true since the original G10 and G11 models. Problem is that they used to be sold only by the commercial side which really doesnt have stores where they show it and now that they have a consumer line, most brick and mortar stores dont demo it
post #117 of 1878 Old 10-06-2010, 01:02 PM
cbaseuser's Avatar
Quoted: 33 Post(s)
Have you calibrated it, and, if so, how bright is it?
post #118 of 1878 Old 10-06-2010, 02:55 PM
230-SEAN's Avatar
Just wondering how the PQ from the hd250 would compare to the AE4000? Anyone know? I know that the AE4000 CR is with a dynamic Iris and the HD250 is native. Also, the AE4000 is lcd, so I assume its kind of like comparing apples to oranges, but maybe someone would have and idea and/or opinion?
-Sean
230-SEAN is offline
post #119 of 1878 Old 10-06-2010, 03:36 PM
rgathright's Avatar
Quoted: 216 Post(s)
Liked: 26
I have added this to my compare list at projector central, but the thing that I am concerned about is the 1000 ansi lumens of the HD250 compared to the Epson 31000 (1200), Mits HC6800 (1500) and Panny AE4000 (1600). Is there something I don't know about the brightness/lumens of these? I will be projecting from around 16' onto a 133" Da-lite HP screen.
Sony XBR-75X850C - Living Room
Samsung UN60J6300AFXZA - Bedroom
rgathright is offline
post #120 of 1878 Old 10-06-2010, 03:47 PM
Quoted: 260 Post(s)
Liked: 161
-Sean
I upgraded from a three month old AE3000 (one of the first in the UK) to a HD350 (= same as a HD250 ). I had a home demo by my dealer and we compared the HD350 and HD750 to my AE3000. The dark scene performance was noticably better and the image was sharper too (though I think my AE3000 was a poor example in this regard as my previous AE2000 was actually sharper). The HD750 was better again, but not so noticable in my room and not enough to justify the extra £2k or so. While the AE4000 claims a bit CR increase over the AE3000, this is in unusable Dynamic mode (just to get the specs looking good if not the actual image ), I believe that the actual CR in Color 1 mode is pretty close judging by Cine4home reviews, so little real improvement between the two models IMHO. Therefore I'd still say the HD350/250 is a better buy than the AE4000, particularly as it has a sealed light path, so no dust blob issues and the uniformity is much better too.
Yes, you're comparing apples to oranges my friend. The 1600 lumens of the AE4000 is in dynamic mode, which has terrible colours. The HD250/350 lumens is pretty much what you get when calibrated, so in practice the HD250 will be brighter than the AE4000 (another reason I changed to the HD350 as the AE3000 couldn't light my 112" 2.35:1 screen well enough and I'm not a lover of an overly bright image). In 'accurate' colour 1 mode the lumens will be nearer 500 or so on the AE4000. In fact if you find the HD250 is too bright, then at least you can close the manual iris down and gain extra contrast rather than resorting to ND2 filters.
PS.My screen is based on a 128" diagonal 16:9 Beamax model (just extra masking to reduce the height). It's lower gain at 1.5 yet the HD350 could light it up without having to fully open the iris when I used to zoom...I think you'll be fine with a 133" HP, you'll probably be able to close the iris right down for best contrast.
Hope this helps.
