The Offical Epson 8350 Owners Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #31 of 9270 Old 10-01-2010, 07:19 AM
jpolachak's Avatar
Quoted: 12 Post(s)
All I can say is wow. Do you have any pictures of your room eddie187 with the lights on. I am curious if your picture looks this good w/ white walls and white ceiling. Either way that's a pretty sweet looking picture for the price.
jpolachak is offline
post #32 of 9270 Old 10-01-2010, 08:04 AM
derekvli's Avatar
Originally Posted by LucyFord View Post
I'll have some unboxing pics tonight!
ok, we are ready! How is the setup coming along? We are anxious to hear about it!
derekvli is offline
post #33 of 9270 Old 10-01-2010, 09:03 AM
eddieb187's Avatar
Cathedral ceiling with 2 SGDs and lots of large windows.
Walls are white. Room is very bright.
Obviously I can only use the projector at night.
Which is why I chose 8350. Need the lumens.
It's a good thing I don't have a dedicated theater.
I would never come out.
eddieb187 is offline
post #34 of 9270 Old 10-01-2010, 09:16 AM
brodskive's Avatar
What is the audible noise like? I know it says 22-28dB in the manual, but can you hear it during quiet scenes? This projector seems great, but I hate noisy electronics
brodskive is offline
post #35 of 9270 Old 10-01-2010, 09:20 AM
Sisyphus's Avatar
Can the iris be adjusted manually and set to a fixed (not moving) position?
Sisyphus is offline
post #36 of 9270 Old 10-01-2010, 09:34 AM
ramosma's Avatar
Like the picture quality eddieb187! Nice
Will pull trigger on this projector soon - can't wait!
Suggestions on ceiling mount for the 8350? Similar to ones recommended for the 8100?
Also interested in decible volume
Thanks in advance
ramosma is offline
post #37 of 9270 Old 10-01-2010, 10:10 AM
mat82284's Avatar
Quoted: 109 Post(s)
Liked: 38
Holy Crap!!! I wouldn't trust my projector to sit on a shelf that is held up by screws!!!
Buy this! I own it and its as strong as a TV Wall Mount!
http://www.amazon.com/OmniMount-ECSB...5953015&sr=1-4
mat82284 is offline
post #38 of 9270 Old 10-01-2010, 10:17 AM
eddieb187's Avatar
brodskive,
I sit right under and to the side of the projector.
I didn't notice any noise last night.
But I was pretty excited I just got it set up.
I will mute the sound tonight and see if I hear anything.
Sisyphus,
You turn the Iris off. Actually, it came from the factory with it off.
There are three settings in the on screen menu for the Iris.
Normal, High Speed, and Off.
ramosma,
I have mine on a shelf bolted to a large support beam.
Epson has a mount, but I'm sure there are after market ones just as good.
I hear Chief is pretty good.
post #39 of 9270 Old 10-01-2010, 10:23 AM
dhahlen's Avatar
What he has for a shelf is fine.
I have a similar shelf for my Klipsch Academy center channel, and it's a heavy beast. Has been on the shelf for over a year without problems. Not the most cosmetically pleasing, but with a huge ass speaker on it, you can barely see it.
dhahlen is offline
post #40 of 9270 Old 10-01-2010, 10:31 AM
eddieb187's Avatar
[quote=mat82284;19273857]Holy Crap!!! I wouldn't trust my projector to sit on a shelf that is held up by screws!!!
Looking at the pictures it does look a little shaky.
Those shelf brackets are bolted with pretty long screws into the beam.
I have a modular home. That's a double wall beam.
One of the main support beams for the second floor.
It's all solid wood with sheetrock over it.
The projector only weighs 16 lbs. More than adequate.
This is the third projector I've had on those brackets and shelf.
Can't mount it in the front, not enough throw then.
Wouldn't fill my screen.
Besides, how do you think the shelf you linked to is mounted? With screws.
post #41 of 9270 Old 10-01-2010, 10:36 AM - Thread Starter
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1988 Post(s)
Liked: 886
Originally Posted by talk2rider View Post
From looking at the user guide for the 8350, its got me wondering about projector placement. Currently, my old projector sits on a TV mount (essentially a shelf) mounted to the back wall near the ceiling. I would say the lens is about 12 inches from the ceiling and the lens is about 2.5 ft above the center of the screen - so the projector has to project downward. I am wondering if the new lens shift capability is going to allow me to point the image downward enough - with the projector sitting right side up. The A-shift vs. B-Shift described in the user guide confuses me. It doesn't really explain the A-shift.
No problems await you. You still approx 35% into the Downward Shift range when the PJ is not inverted
Originally Posted by 96redformula View Post
I was thinking it would be able to do the same downward angle like a DLP does.... Can anybody care to help out with the projector placement. I have my mount ready to go at 10" from the ceiling and my <108" screen is ready to go as well about 15-20"(top of the screen) from the ceiling.
I am just going to give in and order from VisualApex, I just can't wait to get this thing.... Just give me the okay on the projector placement so I can order it .
You say "mount" .....is that a wall mount/shelf/Cradle, or an Ceiling Mount for inverted positioning? If the latter...absolutely no issues...so do NOT angle the PJ downward. I seriously doubt you'll have any issues on a standard mounting (...non-inverted...) but I also suppose a few purists will weigh in with comments decrying the use of any Lens Shift (H or V) beyond a mere 15%-20% adjustment.
They'd be right if you have to go into the 80%+ range, but within that parameter your not going to suffer any noticeable ill effects.
Key stoning is different. It only takes a little bit of such to create distortion and light lost on the edges to take hold. A good reason to avoid it's use altogether, and a primary advantage of using Lens Shifting instead.
If anyone's positioning is so wacky as to not allow for the generous Shift capability of the Epson, then I'd have to say make whatever smallest possible change / allowance you can to bring everything within a "doable" range.
It'll be worth it.
MississippiMan is offline
post #42 of 9270 Old 10-01-2010, 10:50 AM
thespacecowboy's Avatar
I will officially be allowed to post on here when PP actually delivers mine next week! Oops. I posted already. Too late.
thespacecowboy is offline
post #43 of 9270 Old 10-01-2010, 10:51 AM - Thread Starter
Liked: 886
Thanks in advance
The best you can get ain't the most expensive...or the least. Just ideally suited for the 8350.
Chief #RPA 168 dedicated PJ ceiling Mount $139.00 @ PP or A/V Ignore the pricing on the Dell sheet.
http://www.avsforum.com/avs-vb/showt...6lid%3D1342490
Mated to : Peerless ACC 570
http://www.peerlessmounts.com/dyn/Pr...ct.aspx/sp/487 $29.00
Connect the two with Schedule 40 PVC 1-1/2" pipe w/Threaded Couplings Super neat and professional looking with interior Wire drop possible within the 1-1/2" Tube.
post #44 of 9270 Old 10-01-2010, 10:52 AM
dhahlen's Avatar
Very excited, this is going to be a huge step up from my Optoma HD70.
dhahlen is offline
post #45 of 9270 Old 10-01-2010, 10:53 AM - Thread Starter
Liked: 886
You trickster, you! We''ll be keeping a eye out for your shenanigans!
Behave yourself!
post #46 of 9270 Old 10-01-2010, 10:56 AM
czubakow's Avatar
Anyone have any input lag numbers for the 8350? I'm assuming that it uses the same Pixelworks PW392 processor in the 8100, which would give around 30-40ms of lag (from others' measurements). I'm planning on using this PJ mainly for video games, so every millisecond counts.
czubakow is offline
post #47 of 9270 Old 10-01-2010, 01:03 PM
mat82284's Avatar
Quoted: 109 Post(s)
Liked: 38
[quote=eddieb187;19273973]
I have a modual home. That's a double wall beam.
Nope, that one uses big 6in Bolts that bolt into your support beams in the walls. There not little tinny screws that are at most 1" long.
Thats up to you if you want to use it like that. All I'm saying is that I wouldn't risk an item over 1k to some tiny screws even if it does hold it. even a little earthquake or someone running upstairs could shake those screws loose over time causing the shelf to fall. You wouldn't mount a tv on the wall with screws would you? Of Course not, even if screws could hold it up no one would trust it. Same concept here. Its not about the weight its about the value of the item that you have. It's just like a warranty, you want the projector to be covered under warranty, then why wouldn't you want to be 100% sure your shelf wont ever fall.
That's just me. You can take your own risk anyway you want. I'd rather be 100% its not going to fall then 60% sure on a guess that the shelf can sustain that weight for a long time without any natural forces at work.
mat82284 is offline
post #48 of 9270 Old 10-01-2010, 01:34 PM
spaceace414's Avatar
Quoted: 13 Post(s)
Liked: 24
[quote=mat82284;19274855]
Dude...an earthquake? I think there would be other things to worry about than the size of screws he used to mount his shelf! I think he is fine with what he has...plus he has been using it for older projectors. Remember, the projector is only 16 pounds. How can you compare hanging a TV on the wall to a small shelf holding a projector??
Anyway, it is his projector and he can do what he wants. Your message comes across a little strong in my opinion.
spaceace414 is offline
post #49 of 9270 Old 10-01-2010, 02:18 PM
lin000's Avatar
will be shipped out next monday. I'm not in a hurry so i picked ground shipping.
lin000 is offline
post #50 of 9270 Old 10-01-2010, 02:20 PM
fargus24's Avatar
Was just curious if anyone knows of a throw calculator for this yet?
Also, is anyone going to try a DIY screen with this or what are we guessing is going to be the right screen specs for it.
Looking forward to this, already saved about a grand towards the purchase!!!!
Dedicated theater is framed up and electric is going in.
fargus24 is offline
post #51 of 9270 Old 10-01-2010, 03:05 PM
LucyFord's Avatar
So far so good gentleman coming from a panny 900 this thing looks amazing I'll have some screenshots soon
LucyFord is offline
post #52 of 9270 Old 10-01-2010, 03:16 PM
sb1
sb1's Avatar
Quoted: 417 Post(s)
Liked: 358
That's my projector (yes, still). Looking forward to hearing your impressions since I know what you're used to image wise.
Stephen.
Chances are very good that I was drinking when I posted the above.
sb1 is offline
post #53 of 9270 Old 10-01-2010, 03:16 PM
Kilgore's Avatar
Quoted: 728 Post(s)
Liked: 435
I still haven't seen anyone say if the 8350 was 120hz or 60hz. Can someone say which?
Kilgore is offline
post #54 of 9270 Old 10-01-2010, 03:51 PM
bnichols's Avatar
60hz
bnichols is offline
post #55 of 9270 Old 10-01-2010, 04:50 PM
LucyFord's Avatar
The colors, the depth, the blacks, the sharpness is a world of difference. I can't wait until somebody posts since calibration settings. Right out of the box the proj is pretty damn, nice!
LucyFord is offline
post #56 of 9270 Old 10-01-2010, 05:11 PM
Trogdor2010's Avatar
Hello.
I have a question about the new Epson projectors (namely the one posted), does this projector offer a V stretch mode? I have a DIY lens and have been watching movies in my Infocus x10, which lacking that feature would be a deal breaker for me (until I get an oppo). I am also interested if they still offered the ultra bright "dynamic" modes, since I heard they can go up to 2000 "real" lumens while looking good, which I may plan on making a large screen (some say it can power 25 foot wide screens).
Trogdor2010 is offline
post #57 of 9270 Old 10-01-2010, 05:30 PM
Davinleeds's Avatar
Originally Posted by bnichols View Post
60hz
I thought I saw differently, but so far can't find. But if true... No sale.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #58 of 9270 Old 10-01-2010, 05:38 PM
sb1
sb1's Avatar
Quoted: 417 Post(s)
Liked: 358
How about the brightness? And what mode did you start with? Just take your time and tell us everything.
Stephen.
sb1 is offline
post #59 of 9270 Old 10-01-2010, 06:31 PM
n01un0's Avatar
The real question is how does the Madden look you intended to play all day, LOL
n01un0 is offline
post #60 of 9270 Old 10-01-2010, 07:00 PM
AVRoberts's Avatar
My 8350 showed up this afternoon and I've been enjoying it for the last few hours. My screen hasn't arrived yet, so I'm just displaying on my yellow painted drywall. It looked so good, my wife asked why I was buying a screen! This is our first projector, so I won't attempt to give any kind of review. But I will say that I'm quite impressed. I tried watching some HD Hockey, Baseball, and College Football. This will make one hell of a SuperBowl projector!! Even with some ambient light, the picture looked surprisingly bright to me. Looking forward to getting the projector mounted tomorrow as I can't stand having it sit on a piano bench. No buyer's remorse for me!!
AVRoberts is offline
Epson Powerlite Home Cinema 8350
