The Offical Epson 8350 Owners Thread - Page 290 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #8671 of 9252 Old 05-28-2014, 11:08 AM
kehakas's Avatar
I'm looking for some feedback on an issue I'm having since I installed a new lamp. Photos are attached. Epson is convinced the projector is at fault and they're sending me an in-warranty replacement, but I'd still like to figure out what the deal is, because I'm curious like that. Here goes:
My old lamp died. I bought an original Epson lamp from B&H to replace it. I installed the replacement lamp, which is something I've done before with no problem. During installation, I changed nothing about the projector itself, or the software settings. When I fire up the new lamp, the image has a horizontal line through the middle, something I'd describe as a "fold" or a "bevel." There's also a faint horizontal line near the top, which you can see in the 25 percent gray image. The image above the line seems to be a little more saturated. The image below the line is less saturated, and also maybe kinda grainy?
I'm 99 percent certain it's the same issue as these people had: http://www.avsforum.com/t/1358521/epson-8350-bulb-replacement-and-now-picture-problem
I guess I'm just wondering if anyone here knows what's going on. I'm a little worried about Epson sending a replacement, because I've read these boards a lot, and it seems like replacements are usually refurbished, and it's a crapshoot whether you'll get one with good convergence, etc.
If a lamp is just a light source, then I don't see how the lamp could be at fault here, but it's also the only thing I changed about the projector so I can't imagine what else it could be.
Thanks for your time. I'm really grateful for these boards and the helpful people on them.
Also, just fyi, the second image is from The City Limits on Vimeo, which I find to be a short and sweet demo video when I'm showing off the PJ:
EDIT: Found another thread about it: http://www.avsforum.com/t/1186545/epson-1080-ub-horizontal-split-image-problem
EDIT: Pay no attention to the discoloration in the gray image; that's a separate issue I detailed here.
kehakas is offline
post #8672 of 9252 Old 05-28-2014, 11:53 AM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
It appears to be a malfunction in the digital processing circuit. It seems too exact to be an optical-light-engine problem. Maybe circuit is being damaged when bulb blows or it's just a common failure. There might be two video sub-processors that each work half the screen. Normally, they get stitched together pixel perfect (but not now).
I think Epson Level-2 Techs would have to get involved and maybe capture a bad unit. However, they might already know about it. that's why they are sending a new unit because it's a non-bulb-issue. Also, on this bad unit, be sure to try a different 1080p source, with new HDMI cable, into other HDMI-2 Input.
If you had two 8350's (one working perfectly) ... you might be able to swap bulbs and see where the problem follows.
I would be very interested to see what happens on this (here, or in the other thread).
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
post #8673 of 9252 Old 05-28-2014, 12:08 PM
kehakas's Avatar
Originally Posted by Tesla1856 View Post
Also, one this bad unit, be sure to try a different 1080p source, with new HDMI cable, into other HDMI-2 Input.
Yeah, I got the same results on a different HDMI port, different cable, different source (iPad vs. PS3). So I suppose it could be a problem with both HDMI inputs.
If I learn anything from Epson, I'll share it here.
kehakas is offline
post #8674 of 9252 Old 05-28-2014, 12:13 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Good thinking to try it already. Sorry, but had to ask (never know people's skill level here).
Right, or past all HDMI inputs ... in main video processing circuit.
post #8675 of 9252 Old 05-28-2014, 01:26 PM
kehakas's Avatar
Just for kicks, I played with the projection settings (Front, Front/Ceiling, Rear, Rear/Ceiling) but the effect never got flipped or inverted, so it's independent of that.
kehakas is offline
post #8676 of 9252 Old 05-28-2014, 04:36 PM
kehakas's Avatar
Can anyone offer insight on whether a lamp could cause a defined horizontal line on the image? Or is the lamp just a light source?
kehakas is offline
post #8677 of 9252 Old 05-30-2014, 12:52 AM
penusmeanly's Avatar
I had this exact issue with a new lamp, the image is slightly dark in the top 50% of the screen creating a horizontal line in the middle of the screen.
Theres a thread about it here :
After about 50 hours use in Normal mode the line appears to have gone......i hope
penusmeanly is offline
post #8678 of 9252 Old 06-03-2014, 12:50 PM
faxmonkey's Avatar
I'm about to order an OEM Epson lamp from Provantage, from a link in a previous post.
At checkout I noticed that the description states the following:
EPSON Replacement Projector Lamp Unit Home 6100 6500 7100
There's no mention of the 8350. I called Epson and they told me that the part # is ELPLP49. Provantage couldn't reference that.
Could someone shed some light into this matter?
Link from a previous post:
http://www.provantage.com/epson-v13h010l49~BDYM905T.htm
faxmonkey is offline
post #8679 of 9252 Old 06-04-2014, 10:06 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
If you click the Specifications tab you will see the reference to ELPLP49. Epson has been using this same lamp in many of their projectors going back to 2008 as evidenced by all the different models.
http://www.epson.com/cgi-bin/Store/ProductQuickSpec.jsp?BV_UseBVCookie=yes&oid=63079290&category=Products
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #8680 of 9252 Old 06-04-2014, 01:26 PM
faxmonkey's Avatar
Thank you!
post #8681 of 9252 Old 06-10-2014, 08:26 AM
norymeoreason41's Avatar
Hi everyone! Thank you all for sharing your knowledge and experience with this projector. I've been using it for about a 1.5 yrs with very few complaints. Great projector for the $.
With that said, there is one issue I've kind of dealt with since day 1, and am curious if others have the same experience. When viewing bluray through PS3, the image quality is excellent with great shadow detail and contrast. My problem is when viewing content from my cable box (U-Verse). Aside from the obvious resolution/artifacts you'd expect from cable, shadow detail takes a huge hit. Almost to the point where I feel like I miss parts of dark scenes. For example, on this week's Game of Thrones episode - much of the fighting occurred in a very dark setting and I could barely follow what was going on. It was watchable, but just barely. If I try to increase the brightness, it just makes the same picture, only more gray instead of black.
Has anyone experienced this? Any tips on improving picture quality from a cable box as the source?
Thank you all again!
norymeoreason41 is offline
post #8682 of 9252 Old 06-15-2014, 12:30 PM
jdag's Avatar
Hello. I recently purchased the 8350 to replace a BenQ W1000. I haven't watched much yet, but overall happy with the upgrade.
Does the 8350 have user-upgradable firmware? I've done some searching and have yet to find any mention of firmware.
Thanks in advance, John
jdag is offline
post #8683 of 9252 Old 06-16-2014, 08:37 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Nope.
Mr.G is offline
post #8684 of 9252 Old 06-16-2014, 08:44 AM
jdag's Avatar
Nope.
Thank you for confirming.
jdag is offline
post #8685 of 9252 Old 06-17-2014, 06:38 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
anyone hear a clumping noise on and off from the 8350
VRD Monoblocks Totaldac Twelve System Music Storage NAS SSD - Dedicated Router - (2) Paul Hynes SR-5 Linear PSU - Controlled by Ipad
Speakers :Joseph Perspective's Cables : Antipodes reference Speaker / IC's - Wywires Silver Juice II - Totaldac D1 USB
All Furutech GTX-D Gold Receptacles
a1usedcomp is offline
post #8686 of 9252 Old 06-17-2014, 11:44 PM
F12Bwth's Avatar
Quoted: 17 Post(s)
Liked: 44
The new look... NOOOOOOOO!
F12Bwth is offline
post #8687 of 9252 Old 06-18-2014, 08:34 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Try turning off the auto iris to see if the sound goes away.
Mr.G is offline
post #8688 of 9252 Old 06-18-2014, 11:45 AM
Bumping to see if anyone has experienced this before. With this projector or any other. . .
post #8689 of 9252 Old 06-18-2014, 12:33 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
I did that last night and it stopped , but do I want this option off
post #8690 of 9252 Old 06-19-2014, 07:17 AM
rakstr's Avatar
Quoted: 125 Post(s)
Liked: 64
Just curious, I'm getting close to end of life for my bulb and am looking to order the replacement in advance of the "blow out", which we all know would happen in the middle of movie night or worse yet, Buckeye football
I'm seeing some substantial price variations. Is there any reason to NOT buy these? Rakuten I believe is formerly buy.com which I used to frequent!
http://www.rakuten.com/prod/epson-po...FQIT7AoddFcAkQ
http://www.projectorlampsworld.com/e...FUcV7AodzXsAGg
https://www.interlight.biz/light-bul...FQIT7AoddFcAkQ
rakstr is offline
post #8691 of 9252 Old 06-19-2014, 12:02 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I did that last night and it stopped, but do I want this option off
Some people with the auto iris set to off say that they hardly notice a difference in picture quality.
Your other option is to send the 8350 in for repair, which means getting a refurb from Epson.
Mr.G is offline
post #8692 of 9252 Old 06-19-2014, 12:10 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I think you've proven the projector is fine, but you leave out pertinent details on your setup. Do you run all of your HDMI connected devices through a receiver? Are you running more than one HDMI cable to the projector?
It's also possible that the cable box is defective. Try exchanging it for another and possibly an improved model.
Mr.G is offline
post #8693 of 9252 Old 06-19-2014, 12:16 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
They are all clones or generic replacement lamps with no mention of the type of bulb used. That's why they are inexpensive.
The choice is yours. Buy the more expensive OEM lamp or roll the dice with one of these.
Mr.G is offline
post #8694 of 9252 Old 06-19-2014, 01:48 PM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
are you saying the 8350 should be noise free at ft ?
post #8695 of 9252 Old 06-19-2014, 03:36 PM
rakstr's Avatar
Quoted: 125 Post(s)
Liked: 64
Given there's been a number of years behind these lamps and the 8350, are there not any report outs of using these lamps? By now I'd think that we'd have some reviews!
rakstr is offline
post #8696 of 9252 Old 06-20-2014, 09:36 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Here's the problem, there are many many vendors that sell clone lamps. So there is virtually no track record on any one seller.
And the reviews on the inexpensive lamps are usually negative. Occasionally you'll see a review in this thread from someone who is satisfied with their clone lamp purchase but they are the exception. If you are intent on buying a clone lamp at least make sure the bulb inside is Osram or Philips which is what is generally used in OEM lamps. However I doubt very much you find a clone lamp with an Osram or Philips bulb for under $100.
Mr.G is offline
post #8697 of 9252 Old 06-20-2014, 09:40 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I'm sorry, I don't understand your question.
Mr.G is offline
post #8698 of 9252 Old 06-20-2014, 09:42 AM
a1usedcomp's Avatar
Quoted: 55 Post(s)
Liked: 32
noise free at 5ft away sorry
post #8699 of 9252 Old 06-20-2014, 09:48 AM
rakstr's Avatar
Quoted: 125 Post(s)
Liked: 64
Just trying to understand, that's all. I haven't seen many reviews so I need to dig in to see what the trend is. Longevity? Color correctness? Uniformity?, ... I'm always curious when things range 3-4X in price!!!!!
rakstr is offline
post #8700 of 9252 Old 06-20-2014, 10:07 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Projector reviews for the 8350 list the dB noise levels as 28 dB in standard mode and 22 dB in eco mode. So no, it's not totally silent.
Mr.G is offline
Epson Powerlite Home Cinema 8350
