The Offical Epson 8350 Owners Thread - Page 301 - AVS | Home Theater Discussions And Reviews
 10Likes
post #9001 of 9021 Old 01-21-2015, 02:20 PM
coaldigger's Avatar
I have it set on Econo mode and on Dynamic. I just read today that High Altitude would run the fan a little longer on shutdown so I made that change this afternoon. I always felt that the fan should run a little longer but the big case for this unit doesn't seem Our basement is pretty cool even though I close the AC vents in the summer and sometimes don't open them all year. I put in two rows of reclining seats this year and build a riser that is 13" and the back row is under the ceiling mounted unit and I do not hear the fan until the sound is off and I am focusing on it to shut the power off from a switch on my wiring bridge. I try to remember to keep the filter clean and carefully remove it to vacuum a couple times a month otherwise I don't disturb the projector. I figure power surges, heat and vibration are the enemy and I try to avoid them as much as possible.
coaldigger is offline
post #9002 of 9021 Old 01-22-2015, 07:18 AM
Liked: 0
I just installed my new 8345, and I'm a little confused about the main power swith. Do I leave it on all the time and use the regular on and off. Or do I shut the main power off when not in use.
Jim nt is offline
post #9003 of 9021 Old 01-22-2015, 07:26 AM
coaldigger's Avatar
My unit is ceiling mounted so I installed a switch in the line going to a receptacle near the projector so I leave the switch on the projector ON but cut the power when the fan stops on shutdown.
post #9004 of 9021 Old 01-22-2015, 07:43 AM
Liked: 0
So once the fan stops the main power should be turned off.
Jim nt is offline
post #9005 of 9021 Old 01-22-2015, 08:01 AM
jayn_j's Avatar
Quoted: 47 Post(s)
Liked: 34
That is kind of your option. If the main switch is on, the unit will continue to draw a very small amount of current to feed the circuits controlling the remote sensor. Turning off that switch will disable those circuits. Saves a bit of power at the cost of some convenience.
What you don't want to do is remove power wile the lamp is on or the fans are still running as that will shorten bulb life.
jayn_j is offline
post #9006 of 9021 Old 01-22-2015, 08:29 AM
jayn_j's Avatar
Quoted: 47 Post(s)
Liked: 34
Originally Posted by HTPC_Dude View Post
Hi Coaldigger, thanks for posting up your good experience with the 8350. I am curious if you run ECO mode at all on your projector? What viewing mode do you run (Cinema, Dynamic, etc) 2999 hours doesn't sound terrible for lamp life if you run in normal mode with above average brightness.
My experience has been generally positive. I did get the AutoIris error a few times on the 8350, I changed out to the 8345 and have not had any issues other than a bit more fan noise than my old 8350.
I don't actually have an 8350. I have the very similar previous model, the 8100. My bulb blew at 4225 hours. I replaced it with genuine Epson after reading the horror stories about cheap clones. In my mind it was worth paying the $230 it cost from an authorized online dealer. It now has another 2000 hours and is going strong.
I run in ECO mode for most of the life, but switched to normal when it started darkening. I run a custom profile based on cinema that I periodically set using a calibration disc. I also run high altitude mode. My theater is a totally light controlled cave with dark indigo walls, but the projector, mounted 19' back on the wall is plenty bright. I do clean the filter every 3 months but have not replaced it. I really should.
jayn_j is offline
post #9007 of 9021 Old 01-22-2015, 09:29 AM
Liked: 0
Makes sense. Thank you.
Jim nt is offline
post #9008 of 9021 Old 01-23-2015, 06:33 AM
robertw11's Avatar
Quoted: 63 Post(s)
Got the replacement setup, appears to better. White images are white, uniformity looks about the same. Only thing that I might not be perfect is the sharpness, this replacement doesn't look as sharp (small text) than the one it replaced, but I'll have to do some more testing.
Kuro'd
robertw11 is offline
post #9009 of 9021 Old 02-07-2015, 06:12 AM
panzer55's Avatar
Epson 8350 purchase - WOW!
I recently upgraded my Mitsubishi DLP projector which I have been very happy with over past few years with the Epson 8350 projector. I must say WOW - I cannot believe the overall picture quality. I thought my last projector had a nice picture. It is amazing how many things that are now clear and visible in many dark scenes that were not visible before. The vivid colors are amazing, skin tones excellent, and w/ additional lumens I can actually have some lighting in room which the wife likes. I have not made any adjustments with any of the calibration settings as of yet and am not that familiar with them nor do I want to degrade current picture.
This is my second projector and I am an entry level do-it-yourself individual. There is alot of info out there, but are there any quick basics that I should look. A few observations(surprises) that I did have after receiving and setting up the projector is that it is physically huge compared to my old Mit's. I also feel that the cooling fan is really loud compared to what I am used to. The picture quality though easily covers for these negative aspects. Appreciate everyone's comments as I spent alot of time reviewing comparisons prior to purchase.
panzer55 is offline
post #9010 of 9021 Old 02-18-2015, 02:26 PM
robertw11's Avatar
Quoted: 63 Post(s)
You bought the wrong projector bud. The 8345 is the projector you should have bought if you needed the 8350's range and lens shift. And I hope you have a dust free room, these things love to pick up any bit of dust so be on the look out for green dust blobs, you'll probably see a few pop up at around 250-300hrs. Enjoy!
Kuro'd
post #9011 of 9021 Old 02-18-2015, 03:23 PM
eyekode's Avatar
I don't have a dust free room and have had no dust problems and it has been1.5 years or so. Just another data point.
(Knocking on wood).
Salem
eyekode is offline
post #9012 of 9021 Old 02-19-2015, 10:42 AM
Itsdon's Avatar
(Knocking on wood).
Salem
Same here. My projector is 3 years old, I hardly ever dust, have 1,500 hours on the lamp and it is flawless and blob free. Just sayin....
"Life is a toy, play with it"
Itsdon is offline
post #9013 of 9021 Old 02-19-2015, 12:09 PM
ben38's Avatar
Quoted: 295 Post(s)
Liked: 148
2400+ hours and no dust problems so far.
ben38 is offline
post #9014 of 9021 Old 02-24-2015, 01:05 PM
bwilberg266's Avatar
Thumbs up New to the family
Just received my (new to me) Epson 8350 that I bought from nano_machine here on the classifieds. Can't wait to get it fired up to test it out tonight! It will be a couple weeks till I really get to dig in as we are closing on a house on Friday and the setup will be in the basement there, but super excited to finally have a projector!
bwilberg266 is online now
post #9015 of 9021 Old 02-26-2015, 05:12 AM
detroit1's Avatar
Quoted: 21 Post(s)
Liked: 27
I am ready to buy another bulb
please let me know the best low priced $50 bulb to buy for the 8350
I know some on this forum have used these lower prices bulbs
detroit1 is offline
post #9016 of 9021 Old 02-26-2015, 08:44 AM
Kilgore's Avatar
Quoted: 329 Post(s)
Liked: 248
Mine has 2600+ hours and no dust as well. I have since moved on to the 5030 (still have the 8350), and it also has no dust after 800 hours.
I should also add that both have been shelf mounted and often, my cat sleeps on it.
Kilgore is offline
post #9017 of 9021 Old 02-27-2015, 07:32 AM
F12Bwth's Avatar
The cat is soaking up all the dust. Good idea.
Home Theater Subreddit: http://www.reddit.com/r/hometheater/ AV Recommendations Subreddit: http://www.reddit.com/r/zeos
F12Bwth is offline
post #9018 of 9021 Unread Yesterday, 07:09 PM
Liked: 0
I've had an 8350 for quite a few years(July 2011) and suspect that one of my fans has gone out. I am getting a periodic overheating message and the filter on the back is clean. I just don't know what fan has gone bad. I do know that the high altitude option when turned on does nothing. So if that controls just one of the fans can anyone tell me which of the 5 it is inside?
It seems like the front exhaust vent is putting out the normal amount of air but the rear intake vent is very light and feels like barely any air is getting sucked in.
If anyone can help me that would be great.
swhitefl is offline
post #9019 of 9021 Unread Yesterday, 09:14 PM
gingus's Avatar
Quoted: 16 Post(s)
I'm starting to get oval halos in the upper right and left. I had this problem on my previous PJ. Any suggestions?
gingus is online now
post #9020 of 9021 Unread Today, 08:20 AM
joeags's Avatar
Originally Posted by joeags View Post
I also purchased the genie lamps replacement, albeit at $62 back in November. I had 1136 hours on my projector over 2.5 years. I also see the lamp as being comparable in brightness to the original, but can't be certain. No beeps or any other sounds from the projector. Best I can say is I am pleased with it, would recommend it at this point, and hope for it to last a decent length of time past the 150 day warranty.
Ok, final post on this lamp (http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1). Purchased and installed in November, 2013. I haven't had any issues with the bulb. Install was fine, everything worked right from the start. I noticed decreases in brightness at about the 1400 hour mark, where I moved up to Living Room mode. 2000 hour mark, I had to move up to Dynamic mode. 2100 hours, bulb is dead - I saw the flashing red light for the bulb on the projector, and replaced it at that time. Putting a new bulb in, and it just blows my mind how much the bulb had dimmed.
Still, for $62, I feel I received my money's worth. I had close to 1.5 years of usage out of the bulb. Color and brightness were fine. I had a quick trip to the US in December and would have purchased a second of the same bulb, but they had none with prime 2 day shipping, so purchased a glamps version instead (http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1). I'm perfectly happy with this bulb for the first 10 hours, and will see how it performs. Purchase price on this one was a whopping $38 at the time (December, 2014).
joeags is online now
post #9021 of 9021 Unread Today, 09:03 AM
gingus's Avatar
Quoted: 16 Post(s)
Also, where is the filter on this. I can't seem to find it.
Epson Powerlite Home Cinema 8350
