The Offical Epson 8350 Owners Thread - Page 311 - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #9301 of 9308 Old 07-25-2017, 11:09 AM
Tesla1856's Avatar
Quoted: 191 Post(s)
Liked: 76
Originally Posted by ohliuw View Post
1. Thanks, I will try these settings.
2. There is nothing wrong, I just need to get the sound from my firetv to my Behringer mixer.
I don't have HDMI receiver, and can only input RCA or toslink to the mixer. Some projectors have audio out (mini jack), but not the 8350.
1. I guess I should also mention that I use Preset #1 Dusk about 90% of the time (even at Night and during the day with blinds closed). My multi-use room is not very light-controlled. IMO, the 8350 is a torcher.
2. I have an idea. I'll post later.
Living Room Home-Theater (Multi-Use Room):
Epson 8350 Projector (1080p @ 96") ~ Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR ~ Cisco 8742hdc DVR (Spectrum) ~ Panasonic BD60 Blu-Ray Player
AppleTV-4 (iTunes,Plex,DMA,Vudu) ~ Simple Control HA ~ Alexa Echo Dot
Harmony 670 Remote ~ HTPC (Kodi/Win10-64) Media-Server ~ Synology DS412+ 16tb Raid-5 NAS
Polk Audio Monitor Series-II CS-2 Center & 60,40 Pairs / PSW-505 12-Inch Subwoofer
Tesla1856 is online now
post #9302 of 9308 Old 07-25-2017, 11:30 AM
Tesla1856's Avatar
Quoted: 191 Post(s)
Liked: 76
I'm not sure what that is.
I just know that HDMI capable AVRs have been around for a while now, they are cheap, and IIRC ... the only way to get things like Multi-Channel PCM and Lip-Sync.
I use a ViewHD VHD-H2HSAs to extract analog stereo from my AppleTV-4 for Zone-2 audio.
Official Apple-TV (Gen4, ATV5,3 - 2015) Owners Thread
post #9303 of 9308 Old 07-31-2017, 04:38 AM
pinkfloydhomer's Avatar
Would the current HC3700/TW6700 be a noticable upgrade from TW3200/HC8350?
How much better is the black level and native contrast, for instance?
pinkfloydhomer is offline
post #9304 of 9308 Old 08-20-2017, 09:03 PM
Tesla1856's Avatar
Quoted: 191 Post(s)
Liked: 76
Mounting 8350 on ceiling ... finally.
For the past 6 years, we have had our 8350 sitting on the counter in the back of our large Multi-Use room.
Well, I just installed a new Minka-Aire ceiling fan with a 6-inch shorter down-rod in our Living Room. It's finally now possible to ceiling mount our projector. I even have wife-approval so I ordered a $30 QualGear QG-PM-002-WHT-L from Amazon.
Wish me luck.
post #9305 of 9308 Old 08-20-2017, 09:24 PM
Tesla1856's Avatar
Quoted: 191 Post(s)
Liked: 76
Good question, but the 3700 looks nice.
http://www.projectorreviews.com/epso...jector-review/
I'm not qualified to say how it compares to 8350, but the review and/or blog-posts do talk toward it. Interesting people are still talking about 8350 (it certainly made an impression on the scene).
I'm sold on Epson 3-LCD technology and their nice main-lens also. Yeah, my next projector would have to be as good or better than my 8350. But since ours still works perfectly, it's better if I don't look at new projectors reviews or epson.com right now.
We still mostly use the plasma during the day. But just about every day at dusk ... the Epson 8350 comes on.
post #9306 of 9308 Old 08-30-2017, 02:42 PM
ohliuw's Avatar
I got Epson to replace the projector. Much better picture now.
However, I am still looking at the sound out issue. I am a bit confused since there seems to be 2 types of extractor boxes - one type is AUDIO extractor (typically 1080p) the othertype is ARC extractor (4k).
I am looking to get audio out from my Firetv 2ng generation box and to be able to control the audio level from the remote of the firetv. Which type should I buy?
ohliuw is offline
post #9307 of 9308 Old 08-30-2017, 09:16 PM
Tesla1856's Avatar
Quoted: 191 Post(s)
Liked: 76
Red face QualGear QG-PM-002-WHT-L Projector Mount - $30
Wish me luck.
Install went fine.
It's installed on the ceiling (7ft from floor) behind couch about 16ft. from projection surface. Mount is mostly retracted to a 22inch length. It seems adequately sturdy and we have never seen any image shaking or vibrations. However, I guess it should be noted that this is a single-level residence (no walking on floor above projector).
I was just barely able to lift projector into place and hook on shaft by myself. Projector "balances" on mount nicely and then you just tighten the various final screws. You can make fine adjustments, but there are no actual "fine adjustment" knobs ... but it's not like you need them with the 8350. I just hold projector perfectly level, lens parallel to screen, and tighten all the screws down (fairly permanently).
Playing around with screen sizes, height, or position is easy with 8350 (nice lens and lens-shift), and no further adjustment of mount is required while messing-around with those things.
Since install, there has been no movement or drift requiring re-adjustment of mount. We like it.
On the back counter was fine, but I'm happy to finally have it on the ceiling.
post #9308 of 9308 Old 09-03-2017, 11:31 AM
Tesla1856's Avatar
Quoted: 191 Post(s)
Liked: 76
1. I got Epson to replace the projector. Much better picture now.
2. However, I am still looking at the sound out issue. I am a bit confused since there seems to be 2 types of extractor boxes - one type is AUDIO extractor (typically 1080p) the othertype is ARC extractor (4k).
3. I am looking to get audio out from my Firetv 2ng generation box and to be able to control the audio level from the remote of the firetv. Which type should I buy?
1. Excellent. That explains a lot ... didn't make sense that the "picture was bad" OoB.
2. I tried to help since I just bought a ViewHD device, but this IS a projector thread. A audio thread might be better?
3. That's a good question about the audio control. I control my Zone-2 Audio with a wall control near porch door. I think someone else will have to help you. I don't really understand your setup (using a mixer?) or your reluctance to get a HDMI AVR (especially in this day and age).
Epson Powerlite Home Cinema 8350
