The official Epson 8700UB thread - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2251 of 2952 Old 01-17-2012, 11:05 AM
Mitch P.'s Avatar
Grrrr, the unit (less than 20hrs) takes a long time to start up and now I have a flashing red light for bulb...it'll start after 3-4 attempts, but I just gave a call into Epson and they are fed-ex'ing a new bulb out. I hope it's the bulb and not the unit itself.
On a different note, last night I was calibrating with the AVSHD and I had to set my Lenovo (pc) to RGB limited, and PJ to HDMI expanded to see the bars. After I did this, brightness and contrast were still very close to 0, 0 and the image is slightly washed out. I see better shadow detail, but it still is a bit washed out. Am I missing something here or is it due to my defective bulb?
Mitch P. is offline
post #2252 of 2952 Old 01-17-2012, 02:34 PM
domingos38's Avatar
Quoted: 22 Post(s)
Liked: 37
Originally Posted by bassage View Post
Just got my 8700. How do I register for my 2 year warranty? I didn't see a registration card or anything to send in? Do I have to do anything?
go to epson.com
u will need serial #
did u get the voucher for free lamp?
domingos38 is online now
post #2253 of 2952 Old 01-17-2012, 10:04 PM
Mitch P.'s Avatar
I'm trying to set black levels...I am supposed to reduce brightness to the lowest level where I can still see bars 17-25 flashing right? Even with my pc set to RGB limited, and the PJ to hdmi expanded my brightness is at 0. This isn't correct is it?
Mitch P. is offline
post #2254 of 2952 Old 01-17-2012, 10:26 PM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Originally Posted by domingos38 View Post
go to epson.com
I registered online. I did get my free lamp voucher. I'm mailing it tomorrow.
bassage is offline
post #2255 of 2952 Old 01-17-2012, 11:06 PM
stepyourgameup's Avatar
Liked: 29
what do the serial numbers start with?
Alcohol. The cause of and solution to all of life's problems.
stepyourgameup is offline
post #2256 of 2952 Old 01-18-2012, 08:47 AM
FendersRule's Avatar
It can do that when the bulb needs to cool down from prolonged use.
FendersRule is offline
post #2257 of 2952 Old 01-18-2012, 09:34 AM
Mitch P.'s Avatar
This happens upon first power up. I'll receive a new bulb today and I'm betting it will solve it.
Mitch P. is offline
post #2258 of 2952 Old 01-18-2012, 02:24 PM
whiteypeterson's Avatar
Does the 8700UB support HDCP?
I recently replaced a 7 year old Infocus which did not.
If it does, I guess I should have ordered 2 DVI to HDMI converters instead of one that I did.
whiteypeterson
whiteypeterson is offline
post #2259 of 2952 Old 01-18-2012, 07:27 PM
mbrennem's Avatar
whiteypeterson
Pretty much every HD display with HDMI input sold in the last 5 years has supported HDCP and the 8700 certainly does as well. Otherwise nobody would be getting a picture from their Blu-ray players via HDMI!
mbrennem is offline
post #2260 of 2952 Old 01-18-2012, 09:11 PM
jayfsee007's Avatar
Does anyone have the SwitchResX settings for 8700UB outputting 1080P?
I've searched the forum and online and haven't been successful in locating them.
I basically want to hook my iMac up to the 8700 and use Plex to watch movies.
Any help or direction on how to figure this stuff out would be highly appreciated.
John
jayfsee007 is offline
post #2261 of 2952 Old 01-18-2012, 09:19 PM
chong67's Avatar
Do you all use 60 hz or 24 hz on this projector?
When I put it in 24 hz, the motion becomes jerky.
So do you set your video card to 60 hz or 24 hz?
chong67 is offline
post #2262 of 2952 Old 01-18-2012, 09:22 PM
chong67's Avatar
At 60 hz, the 4-4 pull down is grey out. When I put it back in 24 hz on my video card, the 4-4 can be changed.
Ok, the manual on page 39 tells me nothing about what 2-2 and 4-4 means.
Please explain if you know. Thanks.
chong67 is offline
post #2263 of 2952 Old 01-18-2012, 09:25 PM
chong67's Avatar
I see you can reset your lamp.
Because of this reset feature, nobody is going to believe what is the real hours on the lamp anymore when you sell it.
Then why did Epson put this reset feature on it?
chong67 is offline
post #2264 of 2952 Old 01-18-2012, 09:49 PM
Liked: 29
You can still see how many hours are on the PJ if you get into the hidden menu. They put it in there so you can reset the lamp hours when you get a new bulb.
post #2265 of 2952 Old 01-18-2012, 09:52 PM
Liked: 29
4-4 pulldown only works with 24fps content. It is supposed to help motion blur. However, if you don't like it then you can use the creative frame interpolation instead. Consequently, CFI will make the movie look like a soap opera.
post #2266 of 2952 Old 01-18-2012, 10:06 PM
bommai's Avatar
Quoted: 194 Post(s)
Liked: 49
John
How old is your iMac? My 2007 iMac running lion has no problems running in 1080p with my Epson 1080ub. No extra sw needed.
bommai is offline
post #2267 of 2952 Old 01-18-2012, 11:29 PM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
My open box 8700 only has 24 hours on the lamp, I was expecting a lot more. Nice.
bassage is offline
post #2268 of 2952 Old 01-19-2012, 12:51 AM
jayfsee007's Avatar
Hey thanks for answering.
My iMac is model 7,1 - Mid 2007.
The problem is that 1920 X 1080 is not a listed resolution.
It was the same when I bought my Panasonic 720P projector. I had to use SwitchrezX to generate a custom resolution of 1280 X 720.
I'm running Lion.
John
post #2269 of 2952 Old 01-19-2012, 11:04 AM
chong67's Avatar
I see. I thought 60 hz vs 120 hz help with motion blur.
I put my video card to 24 hz and I see jitter when people are walking. Hence I put my video card back to 60 hz.
chong67 is offline
post #2270 of 2952 Old 01-19-2012, 11:05 AM
chong67's Avatar
Did you go to the hidden menu to see the real lamp hours? See a few post up and I dont know where the hidden menu is.
chong67 is offline
post #2271 of 2952 Old 01-19-2012, 11:56 AM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
I don't know where the hidden menu is, but I'm assuming this is the real number. If someone was going to reset it, wouldn't they send it to me with 0 hours? Why would they reset it, then run it for 24 hours, then send it to me?
bassage is offline
post #2272 of 2952 Old 01-19-2012, 12:08 PM
tommyv2's Avatar
Nope, and making it a seemingly-random number like 24 is actually a pretty sneaky move
If it's actually around that time, then it might be a blessing, since the first few hours have been broken-in for you. You're now closer to 100 hours, when the bulb settles down and dims to what it will be like for the long time.
=Tommy v2=
tommyv2 is offline
post #2273 of 2952 Old 01-19-2012, 01:00 PM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
It wouldn't matter if they did reset it to trick me. I have the full 2 year Epson warranty, so if anything goes wrong, I get another one. I got it from Crutchfield, so it's not like I bought it from some shady guy off craigslist or something.
bassage is offline
post #2274 of 2952 Old 01-19-2012, 01:49 PM
tommyv2's Avatar
Exactly - and 24 hours is nothing, anyway. You'll get a new bulb every time you get a replacement from Epson. In the next two years, that might be a lot of them, and they'll probably upgrade your model, too.
=Tommy v2=
tommyv2 is offline
post #2275 of 2952 Old 01-19-2012, 02:03 PM
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Yeah, I'm wondering if I'll end up with a 5010 before my warranty is up. That would be nice for movies, but terrible for games with that lag problem and all.
bassage is offline
post #2276 of 2952 Old 01-19-2012, 02:28 PM
tommyv2's Avatar
It'll always be an option for you. I went from a 6100>8100>8350 in a span of a month, and the 8350 was new and not refurbished. Epson's customer service is amazing - their quality control is terrrible. If you're lucky, it's not a bad combination!
=Tommy v2=
tommyv2 is offline
post #2277 of 2952 Old 01-20-2012, 09:12 AM
chong67's Avatar
My leftside is not straight but my right is. Is there a keystone on this projector? I dont see it in the manual.
chong67 is offline
post #2278 of 2952 Old 01-20-2012, 09:56 AM
tommyv2's Avatar
Your projector isn't square to the screen. It's a lot of work to get it just right! If you're projecting onto a wall, make sure it's straight, too. Appearances can be deceiving!
It took me almost an hour adjusting the X-Y-Z axes to get it just right, but it's worth the work. You'll get the best focus that way, too.
=Tommy v2=
tommyv2 is offline
post #2279 of 2952 Old 01-20-2012, 03:02 PM
chong67's Avatar
Are the XYZ axes the 3 knob at the bottom of the PJ? I have done that. It is just not a little straight on the left side.
chong67 is offline
post #2280 of 2952 Old 01-20-2012, 05:43 PM
ofctom's Avatar
Can somebody give me advice about my new home theater set up? I am using the Epson 8700ub with a denon 3808ci receiver and I am trying to decide on a good blu ray player. I am looking at the oppo 93, can anybody tell me if that would be a good choice for the projector or should i look at a different model. Thanks in advance for replies.
ofctom is offline
