Ceil Mount a TableTop Projector - AVS Forum | Home Theater Discussions And Reviews
Old 10-06-2010, 08:51 PM - Thread Starter
rajeevnair's Avatar
I have an Optoma tabletop projector which I am very happy with. I am building a new Home Theater and I would like to use this one (rather than buying a new one), but would like to Ceil-mount it.
Any ideas?
Note: This one is manufactured only to be used as a Table-top, so it does not come with any off-the-shelf accessories.
rajeevnair is offline
Old 10-06-2010, 08:57 PM
lewke's Avatar
Quoted: 26 Post(s)
Whats the model number, most projectors can be ceiling mounted....
lewke is offline
Old 10-08-2010, 06:37 AM
chumpchange21's Avatar
Any news on the model number sonny?
I Love Apple, BenQ, Samsung, and Acer Products = )
chumpchange21 is offline
Old 10-09-2010, 09:50 AM - Thread Starter
rajeevnair's Avatar
The model number is Optoma DV10. The one with the DVD player in it.
This is the one I am talking about:
http://www.google.com/products/catal...d=0CDcQ8wIwAg#
Old 10-09-2010, 11:10 AM
Sheridan1952's Avatar
That model is not designed to be ceiling mounted. There is no option in the menu to flip the image. So if you need to mount a projector to the ceiling, you'll have to get another one. Besides, I rather think that having to climb UP to the projector to change the DVD would get old real quick.
Sheridan1952 is offline
Old 10-10-2010, 09:27 AM - Thread Starter
rajeevnair's Avatar
That is what I also learned.
But if there was some way for mounting it, it would have been better. I am not particular about using the in-build DVD player. I would use it as a regular projector.
Old 10-10-2010, 09:40 AM
Please read my first reply. There is NO option for flipping the image to accommodate mounting on the ceiling. If you did find a way to mount it, the image would be upside down. And because of the way the projector throws the image, if you were to mount a shelf up there, the image would be on the ceiling.
Bottom line, you CANNOT use the DV10 for ceiling mounted applications.
Old 10-12-2010, 01:31 AM
I think you popped his hope bubble
New projector for your new HT room
