Small room (Bedroom) Keystone question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-26-2010, 12:37 PM - Thread Starter
rastargate's Avatar
Hello All-
Questions for you guys. In my bedroom I currently have a plasma on my wall and was thinking of replacing it with a projector/electric screen combo for aesthetics.
The issue I am having is that the room is small, its a timber loft so ceilings are 11'+ high. My plan was to mount a projector to the beam and Keystone correct the picture.
Is there an easy way to figure out if this will even work?
Ray
rastargate is offline
post #2 of 7 Old 10-26-2010, 02:08 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
Originally Posted by rastargate View Post
Hello All-
Ray
In general, people will tell you not to use keystone, but rather get a projector with sufficient offset and/or lens shift to project as you want. Keystoning alters the image and reduces picture quality; lens shifting affects the image imperceptibly, if at all.
fitbrit is offline
post #3 of 7 Old 10-26-2010, 02:11 PM
Jason Turk's Avatar
Hello All-
Ray
Generally tilting a projector is bad. Correcting that keystone with digital correction is worse. There are many with good amounts of shift, but 11' is pretty high if you want to drop it a lot. Why don't you just use an extension ceiling mount and lower it to say 8'? You still won't hit your head but that will allow for a much better result.
Jason Turk is offline
post #4 of 7 Old 10-26-2010, 02:47 PM - Thread Starter
rastargate's Avatar
That is what I did in my living room - works great. But wont work as it will be over my bed
Hmmm maybe plasma it is.
post #5 of 7 Old 10-26-2010, 06:21 PM
Jason Turk's Avatar
Do you stand on your bed? To me it sounds like being over your bed is a benefit, since no one could possibly bump into it...maybe I am not quite understanding...
post #6 of 7 Old 10-26-2010, 06:46 PM
TrickMcKaha's Avatar
I would think a single shelf mounted on the wall at the correct height would be best for a bedroom installation. Ceiling mount at 11' will be too high because it will require too much keystone correction- a little might have been OK. So I say hide the projector on a shelf, not up against the rafters.
TrickMcKaha is offline
post #7 of 7 Old 10-29-2010, 07:35 AM
chumpchange21's Avatar
Maybe he jumps on his bed
But yeah, a decent LCD would have enough lens shift, how about the 8350?
I Love Apple, BenQ, Samsung, and Acer Products = )
chumpchange21 is offline
