Viewsonic Pro8200 -- it exists. - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 1111 Old 03-18-2014, 12:52 AM
Zerguei's Avatar
My knowledge is limited too, but worth to try with what I have. As for the Power Boards, I think they`ve got a kind of common faults, i.e. capacitors or thyristors or something. So, I just decided to check them all and was Ok with capacitors. If replacing thyristors won't help, I will bring this Power Board to a service centre (hope to get circuit diagram from Tech Support before).
As you noticed, there are different power supplies from the Power Board. One is 12V and it powers the Main Board and looks like in my and your cases it works fine. But the High Voltage part (120-380VDC) is not Ok. That is why we have main board running (blue light comes from it), but it does not start LBD because of no power on the HV socket from the Power Board.
And I really hope it is that simple, will see.
Zerguei is offline
post #1082 of 1111 Old 05-02-2014, 08:53 AM
rz786's Avatar
Are any of you using the 12V trigger output on this projector? If so, what kind of cable are you using?
The trigger plug on the projector requires a 3.5mm DC barrel rather than like a 3.5mm audio connector that is common on most other projectors and screens.
rz786 is offline
post #1083 of 1111 Old 05-02-2014, 09:32 AM
plplplpl's Avatar
Liked: 24
You mean one of these?
I never looked. It's kind of a weird choice of plug, though.
In other news, I've now passed the 6,000-hour mark on the original lamp. At 6,135 hours now, it's definitely lost its initial brightness and I've boosted the brightness and contrast up to 70 to compensate in a fully lit, curtains-open daylight room. Evening viewing with the curtains closed is still fine, but I'm starting to miss the pop and shine of the first few thousand hours. I'm not complaining, as this is the best, brightest and longest lasting projector for the money I've owned since I brought my first one back in my luggage from Japan in the early '90s, but I am wondering when would be a good time to swap in a new lamp.
plplplpl is offline
post #1084 of 1111 Old 05-02-2014, 09:43 AM
rz786's Avatar
Yes, that kind. The product specs say it is "3.5mm (12V/1A)", but maybe the engineers didn't realize what kind of plug the product manager wanted? :)
I'm guessing if I replace one end of a 3.5mm audio cable with this plug, it should work.
rz786 is offline
post #1085 of 1111 Old 05-02-2014, 10:21 AM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
I would put a new lamp in it right now, maybe try to find the lamp only without the housing (save you $150 or so).
Edit:
I still own the Pro8200 and use it on occassion in one room. I just ordered a new lamp for $79.00. It says it is the original OSRAM bulb.
http://www.ebay.com/itm/for-VIEWSONIC-PROJECTOR-LAMP-RLC-061-PRO8200-PRO-8200-RLC061-ORIGINAL-OSRAM-BULB-/330776865874?pt=US_Projector_Lamps_Components&hash=item4d03d66c52
Access HERE from this thread
coderguy is offline
post #1086 of 1111 Old 05-02-2014, 11:38 AM
plplplpl's Avatar
Liked: 24
Thanks for the tip, which I saw just after ordering one here: http://www.aliexpress.com/item/Original-bare-Lamp-Bulb-RLC-061-for-VIEWSONIC-Pro8200-Pro8300-projector/1085431482.html. From what I can gather, they're both coming out of a (same?) factory in Guangdong, by way of Hong Kong.
I decided to try there, rather than from http://www.myprojectorlamps.ca/projector-lamps/Viewsonic/PRO8200.html, which I've been very satisfied with in the past and would recommend, for two reasons in this circumstance:
  1. I may want to upgrade to the Viewsonic PJD7820HD you recommend, also a light cannon plus 3D, in the near future.
  2. Sometimes, I let my inner cheap bastard out.
plplplpl is offline
post #1087 of 1111 Old 05-02-2014, 12:01 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
I bought a Benq w7000 lamp from Ebay and it was the true original lamp and have no issues, took about 30-45 mins to change it from the housing (mostly due to needing better longer and magnetized philips). This saved me $150.
For the most part, it's gotten easier to get REAL bulbs as long as it says Osram or Philips, but it used to be harder with lots of scammer misrepresenting, and there still are some, but not as bad.
It's fairly easy to tell if its the same bulb when you receive the lamp, just compare it to the original. Fakes will generally look different in the element or on the markings. There really is no reason to buy a new housing unless you scratched it or the housing has too many burn marks (happens sometimes from heat).
coderguy is offline
post #1088 of 1111 Old 05-09-2014, 12:24 AM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
Just replaced the lamp with the $80 Osram. Worked fine, overall the FILAMENT appeared physically to be the same bulb, but it was a different markings design on the back slightly (so some suspicion it could be a knock-off, but I don't think so). Appears to be the original, doesn't seem quite as bright as my original lamp was when it was new, but it could just be the room I'm viewing it in. Generally speaking, if the filament inside the bulb and the bulb itself looks identical, it probably is.
Replacing it from the housing wasn't too bad, but it was a little tricky. Took me about 45 minutes, but I was being careful. If I had to do it again, could probably do it in 15-20.
Anyhow, I think it's fine. Heck of a deal for $80.
coderguy is offline
post #1089 of 1111 Old 05-23-2014, 03:48 PM
plplplpl's Avatar
Liked: 24
Just changed the lamp, too: lamp only, since I let my inner cheap bastard get the better of me and didn't spring for the housing. I agree, it's a bit tricky if you've never done one before, so lamp + housing are recommended for cautious, uncertain and/or spendthrift types.
A couple of tips/ observations that might help anyone trying this:
  1. The place I ended up ordering from turned out to be OK. They actually have a kind of anti-ripoff, buyer protection plan whereby they hold your payment in escrow until you've received shipment and either confirm right away you're satisfied or let 10 days or so elapse after delivery without a complaint from the customer, then release the funds.
  2. Delivery was reasonably quick, considering the lamp seems to originate in a factory in Guangdong. I got it last week so it took about two and a half weeks. Not bad for free shipping.smile.gif
  3. If the lamps are not the actual OEM, they sure as heck look the part. The proof is in the pudding, though, so more on actual performance later. The original is on the left and the replacement is on the right.
  4. Just flying by the seat of my pants, I started removing all the 7 Phillips screws inside the bottom of the machine, thinking to get at the lamp. No go, of course, so I finally decide to RTFM (p. 38) and discover the single little black Phillips screw on the side to access the lamp housing. Trying to lift the plastic cover also wasn't working so I break down and yet again. The cover slides out toward the front of the projector.
  5. Once you unscrew the two more Phillips screws holding the housing down and gently pull it up and out, you'll need one or more good quality little tiny Phillips screwdrivers, because there are quite a few different little Phillips screws, some of them tiny and tight, that you need to remove, along with gently rocking the lamp's electrical leads out, in order to finally get the lamp itself out of the housing. As with any disassembling operation, take careful note of how everything is put together before you take it apart, so you can reassemble it correctly and completely later. One thing I wasn't sure about when putting the replacement lamp into the housing was which orientation the connecting leads should go, so I kept rotating the lamp clockwise and counterclockwise to make it connect back to the two wires positioned with what I tried to determine were their original bends and kinks. However, a saving grace was that there is actually a little notch in the lamp that sort of clicks into place into the thin aluminum frame (bottom left in the picture) holding the lamp inside the housing when it's positioned to put its four tiny screws back in.
  6. When I first put it all back together, put it back up, plugged everything back in and fired it up, it started to light up slightly, but I couldn't hear any fans spinning, and within 30 seconds the projector shut down and wouldn't power up anymore. I tried unplugging the power cord, plugging it back in and starting the projector up again three or four times, but it did the same thing. Great, I thought, either I got a dud or defective knockoff lamp, or I've killed my Pro8200 with my homespun maintenance. Then, I kind of jostled the projector and it finally started firing up properly. Whew!
  7. And now -- drum roll -- the results:
    Although I very much appreciate that the original lamp went for about 6,500 hours, this replacement lamp change is TOTALLY worth it. Even with ECO mode now back on, which it hadn't been for the past couple thousand hours, the original brightness and pop are absolutely back.
    Pop, pop, pop!
    Hop on pop!
plplplpl is offline
post #1090 of 1111 Old 09-26-2014, 12:15 PM
Liked: 0
My projector started having some trouble yesterday. It had some visual artifacts (colors missing, lines) and then it shutdown. It restarted fine after a while and then the same repeated. After this the projector wouldn't power up anymore. The power light lights up but the fans don't start to spin and the lamp stays dark. After a while the projector shuts itself down. I was wondering if anyone here has had similar problems. I've tried some jostling like plplplpl but it didn't have any effect. Should I order a new lamp or is i more probable that the whole projector is broken? The warranty has just ran out, about two months ago. Zerguei seems to have the same problem. Did you manage to fix it somehow?
Odingod is offline
post #1091 of 1111 Old 12-29-2014, 02:51 PM
Liked: 0
I've been enjoying my pro8200 for a little over 3 years now (bye bye warranty).
Recently, I've been having what appears to be overheating issues. I suspect the exhaust fan is not working as well as it should.
When I start the projector, the exhaust fan seems to be stuck. If I tap on the projector above it, I can usually get it to start. Once it was spinning, it kept spinning. For a while this was working, but after a while, even when I got the fan running, the lamp would shut-off (it was getting super hot). So I put a small floor fan on the other side of the projector now, and if I get the exhaust fan started, this setup allows me to use the projector without it shutting down. This all leads to me to believe there's a problem with the exhaust fan.
I checked my lamp life, and was just over 5000 hours, so I know I have to change the bulb soon, but didn't want to invest the money unless I knew that was the issue.
Does anyone have any ideas? How can I access that exhaust fan? I've tried removing the 8 or so screws on the bottom, but there must be something I'm missing bc I can't get the thing open, almost, but not quite, didn't want to break it.
Could the old lamp be causing any overheating issues? I'd like to open it up and mess with the exhaust fan, maybe its just got some small hairs or something causing it not to start right away.
Appreciate any advice
bwatts is offline
post #1092 of 1111 Old 12-30-2014, 08:32 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
This thread has been pretty inactive of late. Coderguy used to reply to posts in this thread.
If you are intent on trying to repair the fan in this projector you can pick the service manual for $20 here:
http://www.servicemanuals.net/Servic...01/detail.aspx
I've dealt with this online service before and they are reputable.
Next you have to locate the replacement fan which seems to be available on the ViewSonic site.
http://www.viewsonic.com/us/
Go into the Support section to search for your fan. They list three different fan parts.
Good luck with your project.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #1093 of 1111 Old 01-02-2015, 12:24 PM
Liked: 0
thanks, this is very helpful! glad to know about service manuals too. On further thought, I've decided to have a local projector repairman come out (there are several in Atlanta). Sounds like he can fix for 75-150 if all goes well. ($50 diagnostic goes towards parts and labor.).
Then, I may try my hand at the bare bulb setup in existing housing when i get a new lamp soon. If I can get away with 200-300 maintenance to get this back working well, it will be worth it to keep it running another 2-3 years. it's still a quality projector
bwatts is offline
post #1094 of 1111 Old 02-03-2015, 01:17 PM
SpinControl's Avatar
Originally Posted by SpinControl View Post
ISSUE:
I dropped my projector attempting to ceiling mount it. Nothing rattles in it.
The blue LED is lit when plugged in. Now, when I turn it on, it'll give me a whirl sound (color wheel spinning?), and in 15-20 secs it turns off by itself with a click. I press the button again, same story. I press the button again, and the lamp will fire and the fan will whir, and all will be good. Sometimes during the initial turning itself off, the lamp will have fired (per the lighted rectangle on the lens; however, no image on the screen), but it will shut off - no fan.
Does this sound like I damaged the lamp? Damaged the fan?
If it's the lamp, would people buy...
1. bulb alone
2. lamp assembly
3. lamp assembly in housing
Spin
Well, the projector finally wouldn't fire 100%. Light would come out of the lens, but it'd shut off after 5 seconds.
I sent it in just in case I damaged something before the warranty expired. I don't know what the lamp time was. Maybe 3000?
Well, Viewsonic sent it back stating that it was the lamp (needed a new one). I saw the comments on the RMA before getting it back, so I ordered a new bulb.
Lo and behold, the projector fired up when Fedex delivered it!
Viewsonic, you the bomb (giving me a bulb)! Cost me $12 to ship it to them.
I'll swap out the bulb with the one I just bought and keep theirs as a backup, but what great Customer Service. I'm going to buy Viewsonic every chance I get from now on. KUDOS, Viewsonic!
SpinControl is offline
post #1095 of 1111 Old 02-12-2015, 01:55 AM
ro2207's Avatar
Quoted: 18 Post(s)
I think my projector exhibits similar behavior described by Zerguei. It won't fire up !
Power on:
1.- Power Blue LED stays solid
2.- After a couple of seconds Lamp red LED flashes once.
3.- 20 seconds later I hear a loud relay type of click.
4.- <5 secs another click, Power LED turns off.
During this process I never hear the whir sound (fans fail to start).
I replaced the lamp's bulb with a brand new without success.
Does anyone have a fix for this?
ro2207 is offline
post #1096 of 1111 Old 02-13-2015, 08:12 AM
ro2207's Avatar
Quoted: 18 Post(s)
I will have the service center check my PJ. In the meantime, I might purchase a second PRO8200 and leave the other one as backup if I manage to fix it.
I do have the following concerns:
1.- Is the current firmware reliable? I was one of the first owners back when it was just released and my unit always had problems resetting to factory settings (image inverted, quick power off changed to ON, eco mode reverted to normal, etc).
2.- Is it true that shadow detail and picture quality was decreased in newer versions?
ro2207 is offline
post #1097 of 1111 Old 02-15-2015, 07:26 PM
ro2207's Avatar
Quoted: 18 Post(s)
Today it fired. I got into the service menu but couldn't spot anything wrong. At least I know my new bulb works.
It could be the fan that pushes air into the lamp module. Any time the projector doesn't fire the fan does not spin at all.
When it does fire, the fan starts immediately after pressing power. Nonetheless, this doesn't rule out a power supply issue. Once the projector fires, it never shuts down by its own
ro2207 is offline
post #1098 of 1111 Old 02-16-2015, 10:15 AM
I would recommend this ^. They are more equipped to swap components in and out to determine the issue. If your warranty is up, you might try a local place that has a lot of experience with projectors/PCB boards/etc.
Interesting. This started happening to me about 6 months ago. My wife called about the inverted screen. I got home and all my settings (minus the video calibration) was changed to factory (ECO, fan, screen). I never had an issue with the projector reverting to factory settings before. I thought it was a power issue. Now you have me thinking.
I'll see if this occurs again since I got my unit back from the factory. I have made changes to ECO, slow fan cool down, mounted projector for inverted image, keystone changes.
Mine did this too for about 13 months. I'd get intermittent firing; light would come out of the lens, but then shut down. It finally got a point where if I didn't move the unit, it would work fine, so I just kept my fingers crossed and barely touched the thing. Finally one day, the PJ would seem to fire and then click off and shut down. No fan would go on. That's when I sent it back thinking it was a fan. Nope. It was the bulb. Since I got it back from Viewsonic, everything fires right up when I press ON now.
Reading plplplpl above, his new bulb didn't fire right up but eventually did. I wonder if your new bulb didn't experience something similar? I guess only time will tell. I have yet to swap out my bulbs, so I'll report back if I experience a similar effect.
post #1099 of 1111 Old 02-16-2015, 02:03 PM
plplplpl's Avatar
Liked: 24
Just to add, except for that intial time, it's been firing up without fail ever since. I'm already up to over 3,000 hours on the new bulb.
plplplpl is offline
post #1100 of 1111 Old 02-16-2015, 07:34 PM
ro2207's Avatar
Quoted: 18 Post(s)
The reset issue is very unpredictable. Sometimes settings will be retained for over a week while I've also had my unit reset twice in a row in less than 24hrs, several times (my Viewsonic is attached to a UPS so black outs shouldn't be a problem). Do you know the pj's manufacturing date? Mine's from late 2010. This is a big drawback for us since I installed this unit at my parent's house and every time I visit them the quick power off setting is set to ON which is probably why the lamp has never reached 3k hours.
Our original bulb lasted 2.6k hours. I replaced the bare bulb 14 months ago. After that first change I experienced the same thing that happened to you. It wouldn't fire until I placed the small screw that holds the lamp's lid in place. It then worked without any shutdowns for 1.2k hours. When my parents called me about the pj I assumed the bulb was the problem so I bought another one from a different supplier w/ 8 month warranty. Before changing the bulb, my dad was able to use the projector one last time with the 1.2k bulb (once I had already ordered the newest bulb), but the non firing issue was not fixed with the latest bulb.
I don't know if it could be my lamp housing; it stills looks in good condition and the terminals are making good contact with the bulb. Maybe switching the polarity or making them grasp the bulb tighter could fix it.
I'm puzzled about this since I also own a Panasonic AE900 which sometimes fails to fire when I don't use it in a long time (it's ceiling installed in my old room at my parent's house). Even if the lamp on the panny does not strike the first time, the fans DO. I normally tap gently the projector and it fires on the second attempt. I've tried tapping the Viewsonic (also fixed-ceiling mounted) to get it going but it makes no difference. It either starts fine by its own, or both fans and bulb remain completely dead when it doesn't - hit or miss.
I'd prefer not to spend $250 on an original lamp module unless I find evidence that indicates that plastic housings are prone to malfunction on VS units.
Thanks for stepping up
ro2207 is offline
post #1101 of 1111 Old 03-16-2016, 05:07 PM
voopy's Avatar
Quoted: 17 Post(s)
I can get one of these, made in March 2013 so I think I am good in terms of issues.
However, I want to ceiling mount it and it is not clear to me if this will work out for my room.
My ceiling is 8' so the projector would probably end up being around 7.5' or so. The wall I want to project on is 17' high so plenty of room but I need to make sure the bottom of the image is at 55" from the floor.
Does anyone know if it will be possible to do this with this machine considering it doesn't have lens shift.
voopy is offline
post #1102 of 1111 Old 04-25-2016, 03:54 AM
Liked: 0
My fan started making this weird chirping sound, so I opened up the projector and replaced the fan. Now the projector won't turn on at all. I made sure all the cables were attached before putting the cover back on. The blue LED light when the projector is just plugged in doesn't even turn on. Anyone have any clue what could be the issue?
TheMadMan007 is offline
post #1103 of 1111 Old 05-31-2016, 07:55 AM
voopy's Avatar
Quoted: 17 Post(s)
Long shot if anyone is still reading this thread...
I have a good working 8200 but no remote. The unit is installed over 8' high and I have to get on a chair to turn it on and off.
Wondering if
1; anyone has a remote they might be interested in selling and
2; if anyone knows how I could wire up a little remote power switch so I don't have to get on the chair each time I use it
3; or, if someone might have the remote code which I could program into another remote I might already have.
Thanks very much.
voopy is offline
post #1104 of 1111 Old 05-31-2016, 11:07 AM
kreeturez's Avatar
Quoted: 469 Post(s)
Liked: 354
Wondering if
Thanks very much.
You could perhaps pick up a Logitech Harmony universal remote (lower end models are cheap) and program it using just the projector model number.
I see this projector is supported:
You can check for device support at this link:
https://support.myharmony.com/en-us/compatibility
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #1105 of 1111 Old 06-04-2016, 01:36 PM
voopy's Avatar
Quoted: 17 Post(s)
Thanks, yes, I did buy a Harmony but am still interested in finding the original remote if at all possible. There seem to be a lot of these which people have stopped using so hoped someone in this post might be interested in selling their remote which is kind of useless without the PJ.
voopy is offline
post #1106 of 1111 Old 09-13-2016, 08:37 PM
plplplpl's Avatar
Liked: 24
After over 6,800 hours of faithful service, my lamp started winking out today. I got the projector to start up again, but within a few minutes the lamp would shut off and the screen went black.
So, thanking the me from last November who had the foresight to order a spare lamp as a contingency (bare lamp, no housing, for $65), I pulled it out of the closet, took down the projector and set up to perform the lamp transplant. Fortunately, a decent fellow had posted a helpful how-to here, a while back in this thread, so it was a breeze. Only hiccups were the first time I fired it up after changing out the lamp, I had a dreaded dust blob. . I took out the housing and carefully vacuumed in every nook and crevice I could easily and safely get into. Then, when I had almost put it all back together, I accidentally vacuumed that last little black screw for keeping the sliding cover in place. I had to tear open the toxic, dusty vacuum bag and sift through it all by hand , but I finally found it.
Now, everything works great again, and I even get to enjoy that fresh, out-of-the-box pop of revivified colors for the next couple of thousand hours again, I hope.
plplplpl is offline
post #1107 of 1111 Old 09-14-2016, 07:29 AM
w84no1's Avatar
Glad to hear you got that many hours out of yours. I put about 100 hours on mine in my old theater before we moved. It has been in its box for 4+ years. Hope I can get at least half as many hours as you did. Maybe I will look for a replacement bulb now so that I can quickly switch it out when the time comes.
w84no1 is offline
post #1108 of 1111 Old 09-15-2016, 04:42 PM
Liked: 0
Hey everyone, I opened up my 8200 and ripped the ribbon cable that connects the top control board to the main part of the unit. I am really not qualified to be opening up my unit but it might be a costly lesson learned. Hopefully not.
I bought a replacement cable (20624) just in case I ruined the old one. I plugged the new cable in at both ends and attempted to turn the unit on. (I did not put the cover back on yet.) Nothing. No lights on the control panel, no power to the unit.
I am super bummed right now and could really use some troubleshooting advice if anyone has any. I know some of you have opened up your 8200's so maybe you have experienced something like this?
I think I've put the cable in the right way. I've attached pics of the ribbon.
Any advice would be greatly appreciated.
ID:	1662825   Click image for larger version
Sasha Alexander is offline
post #1109 of 1111 Old 09-15-2016, 06:57 PM
Liked: 0
Not sure how to edit my last post so I'll just add:
I just tested the first and last pins from socket to socket with a continuity tester (with the ribbon cable in of course.)
The cable seems to be connected correctly. I'm not able to test all the pins because they are so small I can't see them, but the ribbon seems to be connected ok.
Any ideas of what it could be? The projector was working before (though I was having some intermittent picture fuzz but thats a different issue.)
post #1110 of 1111 Old 09-15-2016, 07:25 PM
plplplpl's Avatar
Liked: 24
Never opened mine up, let alone had to reconnect a ribbon cable, but the first thing I'd try is to close the unit back up again completely, putting the cover back on, etc., then try to fire it up. There may well be something that prevents it from turning on while it's still open. Other than that, you'd have to ask someone who's opened one of these up before.
plplplpl is offline
