VIVITEK QUMI LED 1280x800 - Page 74 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2191 of 2197 Old 07-27-2016, 03:26 AM
sappy's Avatar
Originally Posted by JDAstro View Post
I have never managed to get 3D from my Nvidia "3D Ready" Dell XPS L502 laptop to play on my Qumi2. It should work - but I have not found the right setup yet. I downloaded a 3D player - Stereoscopic - which outputs in a large array of 3D formats. One big difference is the Dell has no VGA output - only HDMI, so only 60Hz. But even then I pipe the output through a ViewSonic 3D adapter, output at 720p, 120Hz.
So good luck there Sammy. Let us know if you find a solution.
i still haven't find a solution yet. Does anyone else able to get 3D working?
sappy is offline
post #2192 of 2197 Old 04-27-2017, 02:45 AM
Liked: 0
Good afternoon. Tell me where you can buy led-lamps for the projector vivitek qumi 5? Or RGB module to it? And how much will it be?Thank you
Сергей Ненашев is offline
post #2193 of 2197 Unread Yesterday, 05:35 PM
Liked: 0
Replacement Remote Q3 Plus
Hello,
I recently bought a Qumi Q3 Plus from Amazon Warehouse, but it didn't come with a remote, and I'm having a heck of a time finding a replacement online. It's part # XX5040003100.
I bought an Android Air Mouse remote, and it works great with the projector, but I still cannot enter it's settings menu, or change the input source.
I was wondering if anybody knows if the much more common Qumi remote Model Number: QRC1VVK would work, or some other universal remote, or even a way to get into the projector setting through the Android operating system.
Sniktad
sniktad is online now
post #2194 of 2197 Unread Today, 08:46 AM
crashbot's Avatar
Quoted: 23 Post(s)
Liked: 24
If it was supposed to come with a remote, you should take it up with Amazon as faulty goods.
crashbot is offline
post #2195 of 2197 Unread Today, 10:38 AM
Liked: 0
I did. They offered to either refund me, or take 40% off the purchase, which would make it $138 for the Q3 Plus. I would like to keep it if I can only find a way into the projector settings menu, or get a replacement remote...
post #2196 of 2197 Unread Today, 10:42 AM
crashbot's Avatar
Quoted: 23 Post(s)
Liked: 24
Ah, so you reap what you sow!
If it's any help, a Q1 remote works with a Q2 (and vice versa). It is also possible to program a Logitech Harmony remote to operate them.
crashbot is offline
post #2197 of 2197 Unread Today, 05:50 PM
Liked: 0
Thanks for the help. I actually got through to VivitekUSA today, and they are going to send me a replacement remote! Very happy.
Vivitek Qumi Q2 300 Lumen Wxga Hdmi 3d Ready Pocket Dlp Projector White
