Optoma HD70 - Replaced Bulb and Now No Power - AVS | Home Theater Discussions And Reviews
post #1 of 6 Old 02-02-2011, 08:45 AM - Thread Starter
lewiedude's Avatar
Hello all! New here and I did search the forum for anything remotely close to this issue.
I have an Optoma HD70 and the "end of useful life" warning popped up last week. I purchased the correct replacement bulb, BL-FP200C. I followed the directions in the manual correctly(projector is ceiling mounted) to dismount, open and replace the bulb. When I went to remount the projector, I plugged it in as the last step(RBG and HDMI are the inputs I use) and the power light did not illuminate as I thought it would. Nothing. I tried everything, even reinstalling the replaced bulb(in case there was a wiring or other problem with the new bulb). Nothing. I switched to a different power outlet. Nothing.
Could there be a problem with the cord? Is it a standard cord?
Any suggestions are totally appreciated!!
Thanks a ton. Lewiedude.
lewiedude is offline
post #2 of 6 Old 02-02-2011, 08:52 AM
airscapes's Avatar
Quoted: 146 Post(s)
Liked: 150
In most projectors there is a micro switch that lamp cover pushes on when closed. If this switch is not making contact the projector will not power up.
Doug
Planar PD8150 paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 6 Old 02-02-2011, 12:39 PM - Thread Starter
lewiedude's Avatar
I'll get the old head lamp out and take a looksie...any ideas on where to specifically look? Or, does anyone out there have an online source for an HD70 repair manual??
post #4 of 6 Old 02-02-2011, 01:00 PM
Sheridan1952's Avatar
Look at the lamp door, there is a tab that depresses the switch.
Sheridan1952 is offline
post #5 of 6 Old 02-02-2011, 07:32 PM - Thread Starter
lewiedude's Avatar
I did, and it worked!
Thanks and I love this forum!!
post #6 of 6 Unread Today, 02:13 PM
Liked: 0
My lamp exploded last month and I ordered a new one. Today I replaced it and the projector won't turn on. I tried replacing it again, switched the power cable and played with the switch on the top of the lamp, still nothing. Is there anything else that I can do?
Edis Ed is online now
