with this calculator, what am i seeing when you turn lens shift on? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-11-2011, 04:03 AM - Thread Starter
stegen's Avatar
Quoted: 93 Post(s)
Liked: 84
http://www.epson.com/alf_upload/land...ce-calculator/
Looking to get a 8700 or 4000u in a few weeks. using the 8700 calculator, being my floor to ceiling is only 6'10" or so i need lens shift. when i turn the lens shift on in the calculator it brings up a blue box. how do i decipher this thing? what am i looking at?
stegen is offline
post #2 of 2 Old 02-11-2011, 06:31 AM
Coolme's Avatar
The white rectangle in the blue box is your screen. Lens shift allows you to shift your screen in the designated blue region without physically moving the projector. So for example you can move one time the height of your screen up or down as fits your need, this is vertical lens shift. The same applies horizontally, only this time it's only half the width of the screen. If you want to do both at the same time you can watch this on the calculator and see you are more limited, the blue lines being the limits of how far you can go.
Coolme is offline
