Best Projector for a 9' throw - AVS Forum | Home Theater Discussions And Reviews
Old 04-09-2011, 07:57 PM - Thread Starter
xm41907's Avatar
I'm starting to plan out a projector setup and having trouble finding a good projector for my requirements. Due to a ventilation system, I'm limited to a 9' throw for the projector. I'm looking for a sub $1000 projector which can provide me about 100"-120" diagonal at a 9' distance. The projector will be ceiling mounted. Any good recommendations? I've been using the calculator, but can't find a good option.
xm41907 is offline
Old 04-09-2011, 09:26 PM
petern's Avatar
You'll almost certainly need a projector with a short-throw lens, which in your price range probably means looking at business / board-room projectors.
Check www.projectorpeople.com (forum sponsor) ... you can search for "short throw" projectors (http://www.projectorpeople.com/proje...tor-finder.asp) and get some model ideas there.
petern is offline
Old 04-10-2011, 10:07 AM
jem454's Avatar
jem454 is offline
