OPTOMA ML500 LED 1280x800 - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #691 of 696 Old 04-20-2015, 07:34 AM
jeanmoulin54's Avatar
I resolved my problem of Fan Calibration but now i have a problem with White calibration
My white is not good. In menu of projector, white is good but white is not good in display projector. I try to calibration LED but he doesn't work
Please help me
Thank you
Jo
jeanmoulin54 is offline
post #692 of 696 Old 04-28-2015, 07:20 AM
I have the same problem of Nightnday and Patrick Bryant. About 2500 hours my projector went dim. My firmware is C14 and i try to restore factory defaults but it's not working
post #693 of 696 Old 04-28-2015, 03:31 PM
Liked: 0
I have a problem too. If i cahnge brightness or contrast it will change to defaults or even to 0 after reboot. Ive installed c15 firmware, but it did not help. Also, i have some lag with fan locked error, so i soldere wire between 2 fans (middlw wire) after that i did factory reset about 3 times, and now it is working ok. Just dont touch any settings, and everything is ok. I was trying to contact optoma, but i receive no answer. Also i called to korean service centre, but they did not have firware. But there you can see at the bottom of the page, that they have c17 firware, is it possible to find it? bbs.danawa (dot) com/view.php?site=0&board=28&seq=2222192&page=1&keyMet hod=content&keyword=%BF%C9%C5%E4%B8%B6+ML500&past= 1&snb=comm&search=y
Александр Мандренко is offline
post #694 of 696 Old 05-04-2015, 01:26 PM
Liked: 0
Hey I just Buy an Optoma m500. I used only 1500 hours and it went very dim, is not possible to use anymore , does anyone have the same problem? thanks
Ulises David is offline
post #695 of 696 Old 06-19-2015, 02:32 PM
rphdantas's Avatar
good night folks.
Sorry for my English.
I have an ML500 since 2011.
I had never given any problem until this year.
Since March were two problems:
1) In March this year introduced the FAN LOCKED ERROR. It was solved by changing the FAN which is next to the power connector.
2) yesterday presented a different problem. When I turn on the projector, it flashes blue led, but not playing any image to the screen. Spends about 2 seconds, and back pro red LED turns off. So far it seems to me something with the power board. I do not understand much.
Has anyone here passed by this second case? I would love to help, and also where to find this card.
I'm in Brazil.
thank you
rphdantas is offline
post #696 of 696 Old 10-01-2015, 07:52 PM
nightnday's Avatar
Does anyone know where I can find a replacement fan for fan 3 with the connector? My fan doesn't spin up well and I'm getting the fan error I believe cause of it.
nightnday is offline
Optoma , Optoma Projectors , Optoma Ml500 Led Projector
