OPTOMA ML500 LED 1280x800 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 697 Old 09-05-2011, 07:25 AM
Raine0's Avatar
Quoted: 57 Post(s)
From a website selling the Acer, for reference.
Brightness
500 ANSI lumens (Standard mode), 400 ANSI lumens (ECO mode)
Noise level
35 dBA (Bright mode), 33 dBA (Standard mode), 29 dBA (ECO mode)
Raine0 is online now
post #182 of 697 Old 09-05-2011, 07:39 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
From my EVO, not perfect but close. Looks a lot better than the pictures
blee0120 is offline
post #183 of 697 Old 09-05-2011, 07:41 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
Small and has a little carrying case. I can put it in my GT720 gametime book bag
blee0120 is offline
post #184 of 697 Old 09-05-2011, 07:44 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
Watching G.I. Joe, didn't know 720p could look so good. It look better than my Marantz VP8600. I guess that's going up for sale.
blee0120 is offline
post #185 of 697 Old 09-05-2011, 08:26 AM
DLPProjectorfan's Avatar
Quoted: 21 Post(s)
Liked: 45
blee0120 ? would you say that this Optoma ML-500 would justify upgraded from the LG HX-300 ? would there be that much noticeable difference concerning other things than the higher lumens ?
I don't know if you had the LG HX-300 or know someone who did you have seen it in action.
Maybe many of us got ahead of ourselves when the LG HX-300 came out saying that " could this be the game changer " , now with these 500 Lumens and slightly more resolution, are we at the threshold that we can now say that this might be the game changer where the old bulb projectors are the thing of the passed ?
DLPProjectorfan is offline
post #186 of 697 Old 09-05-2011, 08:52 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
It looks really good. I don't know about a game changer. Pair with a 90-110in HP screen would be near perfect. For something so inexpensive, I don't know what would be better for less than $1000. I'm more excited out the picture quality than my RS40. Probably because I expect it from JVC, but not from this 2lb projector. I keep thinking out turning it off because of the lamp to maintain this vibrant picture, but I don't. Worth the $615 I paid for it
blee0120 is offline
post #187 of 697 Old 09-05-2011, 09:35 AM
winjones2's Avatar
blee0120
Rainbow? Approximate speed of the color wheel.
120hz 1280x720 VGA work?
Thank you very much.
winjones2 is offline
post #188 of 697 Old 09-05-2011, 11:01 AM
LeonZA's Avatar
Quoted: 16 Post(s)
How does the pixel structure look like? Diamond or Normal?
LeonZA is offline
post #189 of 697 Old 09-05-2011, 11:20 AM
PoisonWolf's Avatar
It has been discussed previously I believe. Qumi, Optoma, Acer, LG, Viewsonic all use the same 1280x800 chip. They are all diamond pixels.
TI didnt miraculously make a 1280x800 (between the Qumi and now) in square format unfortunately. If it was, it would be really hard to resist tearing another hole in my pocket.
PoisonWolf is offline
post #190 of 697 Old 09-05-2011, 01:15 PM
Wave_Runner's Avatar
Hi, Did you try to run MKV with subs?
Where did you bought the projector for $615?
I owned before the qumi. it was quiet enough in standard mode.
I hope someone tell me the difference between QUMI and ML500 or K330 in noise prespective...
Wave_Runner is offline
post #191 of 697 Old 09-05-2011, 01:15 PM
seph22's Avatar
Originally Posted by winjones2 View Post
blee0120
it doesn't do 120hz 1280x720
Optoma went cheap and it maxes out at 1024x768 for 3D-120hz, this is mentioned in the manual and amazon order page too
seph22 is offline
post #192 of 697 Old 09-05-2011, 02:08 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
I called provantage and they lowered the price. I only tried avi and mp4 files so far. I got a 2GB SDHC, so I'm going to pick up a 32GG SDHC later on
blee0120 is offline
post #193 of 697 Old 09-05-2011, 03:45 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
Another plus is that I can always have my HTPC or laptop on a 120in screen without worrying about a bulb anymore. Another plus with an led projector and I don't have to be in the dark
blee0120 is offline
post #194 of 697 Old 09-05-2011, 05:05 PM
afineman's Avatar
Hey All
Occasional poster, perpetual lurker, yet I have some thoughts.
I believe this is the first LED projector blee0120 has (Please correct me if I am wrong), assuming I am correct, any one going form a bulb projector will be very impressed with their first LED projector (color WOW factor).
Color depth can not be beat when using an LED projector (heck look at the "very close to accurate" photos I posted in 09 using the LG HS201), the big question is.
Noise (remember, if this is his first LED projector he may be willing to take the noise for the great color), heat and focus (I was one of the first to ask if others has the same focus problem I had with my Qimi, most said no (at that time), I thought I had a bad unit) should be the main questions.
There is no doubt LED projectors will become the main stay, there is no doubt the color from a LED projector rivals a bulb projector, but we need to focus on a few things besides "That WOW".
I sit here and type this on my computer using my 20 month old HS201 and am still WOWed by the color. yet I was disappointing by the Qumi because of the focus (I sent mine back), so the higher res and color depth did not blow me away (because, I expected those WOWs).
Anyone going from a bulb projector to a LED projector (my opinion)will get a WOW and NOT get the same WOW when going from 1 LED projector to another.
Having said that (so everyone knows where I'm coming from), I want to know about resolution, heat, color control, and noise.
Currently my HTPC has more fan noise than my LG HS20 (less than an arms distance away) so noise is important to me, I have a well (Light) controlled room (so the 201 in normal mode is bright enough), so the only things I'm looking for is higher res and good color control. my current projector has many hours on it (it has already paid for its self in bulb savings) so as long as I get a few years out of it, it is break even for me.
Just some random thoughts
AFM
afineman is offline
post #195 of 697 Old 09-05-2011, 05:44 PM
Raine0's Avatar
Quoted: 57 Post(s)
Originally Posted by afineman View Post
Hey All
AFM
afineman, there seems to be different numbers going around for the noise level of the LG HS201. What is it exactly?
post #196 of 697 Old 09-05-2011, 05:53 PM
seph22's Avatar
If noise is important then wait for ACER K330 if not then OPTOMA ML500 seems like a good deal,
OPTOMA ML500 is noisy no other reviews will change that, 38DB is a lot for me personally, my Desktop fans all of them is below 30db including CPU, While gaming GPU max out at 40DB and i consider that VERY loud but i don't mind it for "gaming" but during movies with silent moments/scene hearing the fan noise buzzing would annoy me a lot.
seph22 is offline
post #197 of 697 Old 09-05-2011, 08:04 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
Hey All
AFM
I don't think I'm wowed by the colors because its my first led projector. I'm wowed by it because I'm throwing a 120in picture with 350 lumens at almost max gain on my 2.4 HP screen with great color. I think if I went up to a higher resolution that is 1080p, I would have that wow again. I'm amazed by it because I paid just over $600 for this and it perform similar to most of my projectors even my panny ae3000 and ae4000. The fan noise doesn't bother me because I will not be watching TV and sports in silent. I also think if I came from a LG HS201 with about 100 lumens and a resolution of 800x600, I would have been ecstatic with this Optoma still.
blee0120 is offline
post #198 of 697 Old 09-05-2011, 08:11 PM
zombie10k's Avatar
Quoted: 3724 Post(s)
Liked: 3853
I'm using a 119in Da Lite 2.4 HP screen. I just measured again and I'm getting 351 lumens on standard mode. The fan is noticeable but not a big problem like yesterday. It doesnt get really hot. Yesterday I had it on for 3 hours and it was warm. I like the PC mode the best out of all the settings. Out of the box with this mode is great. It looks like my RS40 will be getting much needed rest.
have you see that you tube video, it's not really that loud, is it?
zombie10k is offline
post #199 of 697 Old 09-05-2011, 08:37 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
They had to record it right next to the projector. I sit about 18in away and its not that loud. I cent hear it unless the sound is silent. If it was that loud, I would be returning it tomorrow. I'll post a video from my sitting distance when I get home later or in the morning
blee0120 is offline
post #200 of 697 Old 09-05-2011, 09:12 PM
zombie10k's Avatar
Liked: 3853
thanks! the QUMI isn't exactly silent either but it doesn't bother me since it's just for TV viewing.
post #201 of 697 Old 09-06-2011, 05:56 AM
MCaugusto's Avatar
Quoted: 362 Post(s)
Liked: 224
blee0120 >>> Have you tried to input a native 16:9 content dvd/blu-ray disc AND displayed it natively on the ML500 ? You should get two very thin black bars on top and bottom of image indicating there isn't any forced scaling to its native 1280x800 resolution. A buyer of the LG HW300T in Europe reported that his unit scales all 16:9 content to full panel display, without any recourse offered to the user !
Also, does the remote control use AAA batteries or watch "cell" batteries ?
Thanks....
MCaugusto is online now
post #202 of 697 Old 09-06-2011, 06:44 AM
Ir bass's Avatar
36 dB
Hear it for yourself
[url="http://www.sidewindercomputers.com/tecar.html"]
You will have your conclusions
Ir bass is offline
post #203 of 697 Old 09-06-2011, 07:45 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
Thanks....
It comes with cell batteries. I looked at a dvd yesterday and I didn't notice any black bars
blee0120 is offline
post #204 of 697 Old 09-06-2011, 08:14 AM
MCaugusto's Avatar
Quoted: 362 Post(s)
Liked: 224
Thanks, blee0120, although i should have written "does the pj do 1:1 mapping correctly" since i didn't specify the screen ratio...
The LG HW300T owner reporting the problem said that the pj always scaled any 16:9 content to the native 16:10 picture ratio of the 1280x800 Pico chip, thus round objects/circles appear slightly oval due to vertical zooming from 720 to 800 pixels.
I wonder if the only way you could ascertain that on the Optoma ML500 would be to input any test pattern with circles in it, just like the owner did, otherwise it would be difficult to notice ?
post #205 of 697 Old 09-06-2011, 08:15 AM
Jartanyon's Avatar
blee0120 - have you noticed any issues with the focus? How about the clarity of text on the screen?
I am personally waiting for the Acer because I am not a fan of Optoma's customer support, but I wonder if all these clones are all really going to vary between fan noise. The LED's have to be able to dissipate heat in order to keep their longevity. When overdriving something such as this, it makes me wonder if their life and brightness will truly last that long.
Jartanyon is offline
post #206 of 697 Old 09-06-2011, 08:44 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
This is the fan noise on Eco mode playing a video from the SD card slot. The first ten seconds is when the volume is turned down to hear the fan, then the video plays to show how it affects the videos. Then, the video stops again with just the fan noise on at the end.
http://www.youtube.com/watch?v=g-THZSm3Zyc
blee0120 is offline
post #207 of 697 Old 09-06-2011, 08:46 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
The focus have not been a problem for me yet and the clarity of the text has been clear for me.
blee0120 is offline
post #208 of 697 Old 09-06-2011, 08:49 AM
eat meat's Avatar
over driving now...any proof?
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #209 of 697 Old 09-06-2011, 08:56 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
This is a 2012 playing on my blu ray player on standard mode. The first 10 seconds is when the volume on mute with only the fan noise, then the video plays and stops again to show the fan noise
http://www.youtube.com/watch?v=zmFVjFqlRfk
blee0120 is offline
post #210 of 697 Old 09-06-2011, 09:09 AM
mbw23air's Avatar
Quoted: 194 Post(s)
Liked: 167
Ok, now your videos aren't as loud as the other Youtube video. That makes me feel better. I bet the other guy was just trying to show off picture quality and had the mic real close to the projector. I am interested once again. Damn this obsession.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is offline
Optoma , Optoma Projectors , Optoma Ml500 Led Projector
