OPTOMA ML500 LED 1280x800 - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #211 of 696 Old 09-06-2011, 10:36 AM
seph22's Avatar
Originally Posted by blee0120 View Post
This is a 2012 playing on my blu ray player on standard mode. The first 10 seconds is when the volume on mute with only the fan noise, then the video plays and stops again to show the fan noise
http://www.youtube.com/watch?v=zmFVjFqlRfk
That is still very noisy for me, My 5360 is 27db (so ML500 is a little bit more than DOUBLE the noise at 38DB)
Great for those who don't mind the noise though.
seph22 is offline
post #212 of 696 Old 09-06-2011, 10:57 AM
PoisonWolf's Avatar
Out of curiosity, how well is a cellphone's microphone in picking up sounds that are far away from the phone?
I would assume that microphones on cellphones should be designed to best pick up sounds that are closest to it in order to avoid picking up too much background noises when you're using the device.
In short, is a cellphone's microphone a good indicator of noise level?
Just some thoughts....still, thanks though blee, you are satisfying everyone's curiosity by being willing to entertain our questions!
Now please, back to enjoying your PJ
PoisonWolf is offline
post #213 of 696 Old 09-06-2011, 11:01 AM
DragonlordP's Avatar
Quoted: 25 Post(s)
Jesus people, can't you realise that you can only get an extremely vague idea through internet videos or sound samples? It depends on the seating position and... on the volume of your pc speakers! You can't hear how loud is xx dB from your speakers, because it's a matter of volume! I understand curiosity but this is getting a little silly by now...
DragonlordP is offline
post #214 of 696 Old 09-06-2011, 11:07 AM
Jartanyon's Avatar
over driving now...any proof?
No proof, but almost all of the high powered LED's are over driven anywhere from 350mA all the way up to 1000mA on some. This is why so much heat is created in the process. Considering how much light they are pushing out of these things, I would think these are definitely being over driven to some capacity.
The focus have not been a problem for me yet and the clarity of the text has been clear for me
Good to hear - thanks.
Jartanyon is offline
post #215 of 696 Old 09-06-2011, 11:22 AM
HenryDudley's Avatar
Your 5360 is also TWICE as tall.
HenryDudley is offline
post #216 of 696 Old 09-06-2011, 12:21 PM
eat meat's Avatar
This chipset operates way out of mA range, WAY OUT, It can loaf at 5 amps and operate at double that pulsed.
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #217 of 696 Old 09-06-2011, 12:38 PM
Jartanyon's Avatar
Nevermind - was looking at the wrong chipset...
post #218 of 696 Old 09-06-2011, 05:40 PM
seph22's Avatar
I didn't know that.
seph22 is offline
post #219 of 696 Old 09-06-2011, 07:18 PM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
Had it on for about 8 hours straight on standard mode and its not even that warm. The fan keeps it cool
blee0120 is offline
post #220 of 696 Old 09-06-2011, 07:34 PM
Raine0's Avatar
Quoted: 55 Post(s)
Blee, from watching the two vids you posted about fan noise, it seems that the fan noise in eco mode is actually louder than in standard mode. Is that true? Or it just came out that way?
Raine0 is online now
post #221 of 696 Old 09-06-2011, 07:39 PM
3DNewb's Avatar
I'd assume that Optomas statement that the ML500 is "DLPLink 3D capable; Compatible with 3D content at XGA (1024 x 768) and 120Hz through the VGA port" is a self imposed driver limitation. Since, the Qumi would do 1280x720 or 1280x800 3D gaming and has the same DLP chip. I'd still like to see a snapshot of supported resolutions and timings via monInfo. To confirm the highest supported resolution of the ML500 via it's released drivers. Never know it might been changed to 1280x720 at release time.
3DNewb is offline
post #222 of 696 Old 09-06-2011, 09:00 PM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
The standard mode is the loudest
blee0120 is offline
post #223 of 696 Old 09-07-2011, 07:29 AM
MCaugusto's Avatar
Quoted: 331 Post(s)
Liked: 204
blee0120 >>> If i remember correctly you mentioned the screen you're using is a Da-Lite HP in standard HD format/ratio of 16:9.
If you project an image using the full panel resolution of the Optoma ML500 (1280x800 pixels, 16:10 projection ratio) onto that screen and zoom the image to fit the screen horizontally without any overscan, doesn't the image overscan on top/bottom of your screen considering its ratio of 16:9 versus the 16:10 ratio of the HD Pico chip used on the Optoma ML500 ? Or am i wrong on this assumption ?
MCaugusto is offline
post #224 of 696 Old 09-07-2011, 08:00 AM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
I use a HD format. I haven't zoomed horizontally. I just fill the screen with 16:9. I'll try later to see if its possible
blee0120 is offline
post #225 of 696 Old 09-07-2011, 08:32 AM
MCaugusto's Avatar
Quoted: 331 Post(s)
Liked: 204
Thanks, blee.
BTW, you might want to check out my thread on the "Four LED Clones" as i just added the results of the test report on the Optoma ML500 done by ZOL.com to the comparison chart on page 4 of the thread.
Of course the review is also available online but i thought it useful to have that comparison chart with all relevant figures posted for the clones plus the Vivitek Qumi.
post #226 of 696 Old 09-07-2011, 08:32 AM
Raine0's Avatar
Quoted: 55 Post(s)
Blee, how many modes are there in the Optoma. There's eco and standard, is there also a bright mode? Thx!
post #227 of 696 Old 09-07-2011, 08:48 AM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
There's bright, pc, cinema, photo, and user mode. PC and Photo are my favorite modes.
blee0120 is offline
post #228 of 696 Old 09-07-2011, 08:49 AM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
Thanks, blee.
Thanks, I saw it
blee0120 is offline
post #229 of 696 Old 09-07-2011, 09:43 AM
mbw23air's Avatar
Quoted: 160 Post(s)
Liked: 152
Blee,
I think he is asking what modes there are for the led not the different presets.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Oppo BDP-93 blu-ray player Panasonic UB-900 UHD blu-ray player
mbw23air is offline
post #230 of 696 Old 09-07-2011, 10:16 AM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
Oh, well just Eco and standard
blee0120 is offline
post #231 of 696 Old 09-08-2011, 12:38 AM
Jartanyon's Avatar
Well, despite my reservations, I just pulled the trigger on this one - should be arriving here Friday evening.
post #232 of 696 Old 09-08-2011, 12:45 AM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
Great, let me know how you like it. I been watching mines for about 10hrs a day, never thought that was possible with a projector without thinking about burning through the bulb too fast.
blee0120 is offline
post #233 of 696 Old 09-08-2011, 03:07 AM
Wave_Runner's Avatar
Hello.
First, the right no. for bright mode is 36dB as written in the new spec.
Now, You can't do the experiment unless it is relative to another LED projector . Qumi vs ML500 vs ACER K330. not a bulb PJ because all the bulb PJs are low noise PJs.
Lets wait until somone got them both.
Wave_Runner is offline
post #234 of 696 Old 09-08-2011, 03:34 AM
seph22's Avatar
Originally Posted by Wave_Runner View Post
Hello.
New specs where? everywhere i see it listed as 38DB we don't need people to test them to tell that 38db is very noisy for mmost people
seph22 is offline
post #235 of 696 Old 09-08-2011, 03:57 AM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
It does say 36db tho
blee0120 is offline
post #236 of 696 Old 09-08-2011, 06:07 AM
I don't know why people don't searc hthe web.
http://www.optomausa.com/products/detail/ML500
Now, I saw that there is a WIFI display option the ML500 remote.
Does it have a USB dongle like the ACER K330?
Do you have it?
This is the first time I saw it.
post #237 of 696 Old 09-08-2011, 06:38 AM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
That's the remote I got for it, its too small in my opinion. I have big hands
blee0120 is offline
post #238 of 696 Old 09-08-2011, 06:57 AM
Do you have it?
Sorry guys. This is the parallel/twin PJ from Optoma CN to the ML500.
It is called by the name: DH5101.
http://product.ccidnet.com/art/3397/...2722597_1.html
I don't know why Optoma didn't insert the WIFI display option like Acer did.
post #239 of 696 Old 09-08-2011, 08:36 AM
eje0100's Avatar
Can you do a small picture with this like 32"?
eje0100 is offline
post #240 of 696 Old 09-08-2011, 10:14 AM
mbw23air's Avatar
Quoted: 160 Post(s)
Liked: 152
It is nice turning the led projector on and not worrying about lamp life. Also being able to turn on/off as much as you want as well. I am sometimes too paranoid with my bulb projector as I don't want to burn it up or cause the lamp life to be shorter.
Mike
mbw23air is offline
Optoma , Optoma Projectors , Optoma Ml500 Led Projector
