ACER K330 LED 1280x800 - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #931 of 950 Old 11-23-2013, 06:49 AM
maelstromm's Avatar
Originally Posted by balazsharmath View Post
Hi,
Did you ever get the following message on the screen: "Factory Fan RPM is not ready. Please do Fan Calibration" ?
I did. And I haven't been able to figure out the menu to fix this. I managed to get to the Service Menu but can't find where to do Fan Calibration. Is this a sign of fan about to die?
maelstromm is offline
post #932 of 950 Old 11-23-2013, 09:20 AM
balazsharmath's Avatar
I did the calibration procedure and it fixed the problem, the message doesn't come up anymore, hopefully it will work for others too.
Fan Calibration Procedure
- Hold on “Menu” button then plug in Power Cord.
- Power LED will flash red and blue .
- Release “Menu” button once Power
LED flashes blue only.
- The Projector will power on.
balazsharmath is offline
post #933 of 950 Old 11-25-2013, 07:40 AM
maelstromm's Avatar
Thank you!! That worked perfectly.
For anyone that has mounted this on a ceiling, what mount have you used? Anyone tried a monoprice universal mount? If so, did you use risers to account for the 25mm long screw? Or have you used shorter screws?
post #934 of 950 Old 08-04-2014, 06:24 AM
Tehen's Avatar
Hi fellow K330 owners,
Does anyone of you tried the Acer K132 or Acer K135 projectors?
They seem to be a lot like our K330 but smaller.
I like my K330 but I may buy a second smaller proj to carry around so I was wondering how the K132/135 compare to the K330 in image quality.
Also, did anyone try the 3D EDID override with these smaller proj ?
Tehen is offline
post #935 of 950 Old 08-10-2014, 10:22 AM
kenoh89's Avatar
Quoted: 437 Post(s)
Liked: 83
Need help to open the service menu! Tried options above, none helped! I get message Factory Fan RPM is not ready, how do I fix it?
kenoh89 is offline
post #936 of 950 Old 10-18-2014, 12:26 AM
raj_rios's Avatar
Location: Currently in Northern Europe, from North America.
I'm sorry to revive an old thread, I recently bought a used K330 and need some help. The lenses were quite dirty inside, so I opened the lens housing and cleaned them all. I think I may have reversed the orientation of one or two of them, because although the image is now clean and sharp, there are red bars being projected just above and below the frame. Could anybody please describe or take photographs of the proper lens orientation for me? Thanks so much.
I'll be happy to return the favor by explaining how to get 3D to work over HDMI...
raj_rios is offline
post #937 of 950 Old 10-18-2014, 10:20 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
If you cleaned/moved multiple lenses or even one you may have knocked out of balance what is likely a precise alignment. What you are seeing may be severe chromatic aberration or it could be minimal chromatic aberration (no way to tell without a photograph). The lenses may need to be realigned by a professional or you may just not be accustomed to what is normal chromatic aberration on these projectors.
Post a screenshot.
Mik James is offline
post #938 of 950 Old 10-19-2014, 11:12 AM
raj_rios's Avatar
Post a screenshot.
Certainly. Unfortunately my phone's camera doesn't quite do the color justice, but in person everything looks exactly as it should (gamma and contrast could be better), excluding the bars above and below the screen of course. Keep in mind while inspecting the lines that it has diamond-cut pixels.
To elaborate, after I received the projector I opened and cleaned it, and everything functioned perfectly for several weeks. One night about two weeks ago the projector randomly died while watching a movie. The power light showed the blown bulb error. Knowing how unlikely that would be I opened the projector and reseated the LED calibration wires, and while I was in there dusted the lenses again. The projector came back to life, but now I have this red bar.
Pictures 1-5 show it now in current operation with descriptions in the title.
Pictures 6 and 7 show my current lens orientation.
I appreciate any advice.
Name:	1 Beamer Full.jpg
ID:	319810   Click image for larger version
Name:	4 Beamer Color.jpg
ID:	319818   Click image for larger version
Name:	3 Beamer Bottom.jpg
ID:	319826   Click image for larger version
Name:	2 Beamer Top.jpg
ID:	319834   Click image for larger version
Name:	5 Beamer Color 2.jpg
Name:	7 convex towards mirror housing .jpg
ID:	319850   Click image for larger version
Name:	6 Notch towards LEDs.jpg
raj_rios is offline
post #939 of 950 Old 11-15-2014, 07:57 AM
DonBrutto's Avatar
Cleaning
I have been wanting to clean my k330 for awhile now. I made filters but i still have dust blobs. Now I'm not sure i should. Anyone else done it? Anyone have any tips on how to disassemble?
DonBrutto is offline
post #940 of 950 Old 11-15-2014, 08:12 AM
DonBrutto's Avatar
EDID overide
I just got a new Emotiva Fusion 8100. I have always used an edid override for an acer h5360 so i could play video games with my nvidia gtx650. Now it screws up my receiver. If i apply the override nvidia renames the connection from "Kontron Fusion 8100" to"h5360" and i am unable to select audio through the hdmi in the set up digital audio screen. Then it starts disappearing from the windows audio screen as if i have no device at all. Still has picture though. Anyone encounter anything like this before?
post #941 of 950 Old 12-22-2014, 06:33 PM
Liked: 0
K330 shuts down
Hi K330 owners, I can get my hand on a cheap unit, which shuts down after booting.
At youtube you can find a video about it with ID aIrmXVYa2TY
Some service guys from a repair store sad the LED have to be replaced.. am not sure. Might cleaning fans or some simple maintenance trick solve the issue? The unit ran over 5K+ hours already.
Please give me some advice.
Dahero is offline
post #942 of 950 Old 12-28-2014, 03:34 AM
fiocco's Avatar
Originally Posted by Rugrash View Post
Yah that file is for HDMI 1.4 Displays using side by side or over and under.
Try this one, it's for a VGA connection. Acer H5360 analog 1280 720 120 native.zip 1k .zip file
I updated the native resolution to report 1280x720@120Hz which is 16:9 and what you want for movies.
It still has the H5360 color profile, but should work ok. I have one with an updated color profile for my PLED-W500, but it's on another computer.
For games using Nvidia, the display must be spoofed to show it as supported. For file playback, it is not necessary. but some playback software will only enable 3D in a "fullscreen" at "native resolution".
alt+enter are fullscreen hotkeys in windows.
Hello, can you do a same to HDMI 720 native with open input hdmi sound 5.1 or 7.1 ? please thank you
fiocco is offline
post #943 of 950 Old 02-04-2015, 01:45 AM
Liked: 0
Two problems:
1. Can't get into the settings. When I press Menu button - it reacts the same way as I press Power button.
2. Can't turn the projector off after it's been working for 15 minutes or more.
Please wait 10 seconds for LED calibration.
[Yes] and [No]
I'm not able to choose any option - see 1).
Please help.
When I tried to put my SNID to Acer contact page, it tells me:
Country: US
Warranty Type: SMW-1 yr (MI or CI)
Warranty End Date: 6/13/2013
Your system is no longer eligible for free phone support. Please use one of the alternative support links as seen above.
Please advice.
dreamventure is offline
post #944 of 950 Old 02-11-2015, 11:15 PM
Liked: 0
Originally Posted by dreamventure View Post
Two problems:
[Yes] and [No]
Please help.
Please advice.
anyone?
post #945 of 950 Old 03-10-2015, 08:26 PM
Liked: 0
UP
post #946 of 950 Old 03-10-2015, 09:04 PM
Liked: 0
Forgot to mention: I don't have a remote. I tried buttons on the projector itself.
Thanks anybody who might be helpful.
post #947 of 950 Old 03-11-2015, 10:39 AM
Liked: 0
I might solve the problem (may able to go to settings and do that LED calibration) by just getting remote for my projector.
I have EY.JCN01.008 [K330] model.
Would someone know if I can program Comcast or AT&T universal remote or not? I have tried to find the right code for Acer remote, but Google keeps silent.
Any advices would be appreciated.
post #948 of 950 Old 06-12-2015, 02:15 AM
Liked: 0
Lamp red light on
Hi there.
I am new here and I have been reading some of the posts. I don't really understand most of them as I am not very keen into technology, but I love my K330, or I used to love it because 2 days ago the signal has become extremely weak and there is a red light on the main control that says LAMP.
I have read here that by accessing to SERVICE MENU some of the problems are sorted but I don't know how to access to this SERVICE MENU. Can you help me to find it?
I have called ACER and I didn't understand very well what they said but probably changing the lamp is their solution. Anybody know how much would it cost me? Does it worth to be replaced? How difficult is to replace it by myself (I'm not very handy)? Where can I purchase the new lamp (United Kingdom)? Acer said that the cost for the diagnosis is £50 and then they will tell me what is wrong in the projector. I am very disappointed because my lamp was supposed to last for 20000 hours and I would say that the projector has been On less than 5000.
Thanks in advance for your help.
racafo is offline
post #949 of 950 Old 06-12-2015, 12:36 PM
Liked: 0
Hi there.
racafo is offline
post #950 of 950 Old 03-04-2017, 04:27 PM
Liked: 0
Hi i have small problem with my k330, it kind of went very dark, like less then half of brightness, cant do LED calibration cos setting in menu is dimmed to dark and its like this setting is switched off completely. when i go to service menu and want to calibrate leds from there i get COMM_ERR message. Anyone knows what can be wrong?
Mateusz Szymanski is offline
Acer K330 Portable Home Theater Projector , Projectors , Led Hdtv
