Viewsonic PLED-W500 LED 1280x800 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #181 of 295 Old 11-29-2011, 10:13 PM
3DNewb's Avatar
I'm out of town until after the first of the year, Pj is at home.
tatinko had problems with 1280x720P@120Hz on the Qumi
http://www.avsforum.com/avs-vb/showt...2#post21082872
"" Any 120hz capable graphics card can do it, 720p@120hz means 3D Ready, but I guess this was a marketing trick from Vivitek, because 720p@120hz is absolutly unwatch-able and blurred.""
I did not have this problem, nor did anyone else post that they had this problem, I think it's a result of his hardware/system not being capaple of handling the additional bandwidth required when going from 1024x768 to 1280x720 at 120Hz.
It was well known that the clones that did support 3D, were only going too do so at 1024x768. The Viewsonic was the wildcard, I speculated that it was going to be support 3D at 1280x720@120Hz as soon as the product page was posted and the VP3D1 was shown as an accessory. I've no idea why the 3D-XL did not work, I would have tried longer but had to send it back sooner than I would have liked due to having to leave town.
3DNewb is offline
post #182 of 295 Old 11-30-2011, 12:12 PM
jumbi555's Avatar
Originally Posted by Sisyphus View Post
Jumbi, or 3Dnewb, if you have a chance sometime could you try 720p 120hz via hdmi straight from PC to the Viewsonic? I'm guessing it won't sync.
Is the VP3D1 outputting a non standard, custom timing? Because right now it sounds like NONE of the 500lm clones will sync to 720p 120hz with standard timings.
One thing I'm curious of, if you connect a pc via hdmi @ 1024 x 768, what does the projector show the input as? 1024 x 768, or 1280x720 ? Maybe the projector is automatically scaling 1024x768 to 1280x720?
I've been "off the grid" for a few days - I will try this soon.
jumbi555 is offline
post #183 of 295 Old 11-30-2011, 06:50 PM
Sisyphus's Avatar
Sounds good. Not sure if I was clear in my post but 720p 120hz should be sent from PC directly to Viewsonic PLED-W500 projector. The VP3D1 should be disconnected.
If the projector syncs to the signal then we'll know there is some other reason the Optoma 3DXL wasn't working. Maybe as 3DNEWB mentioned the 3DXL is confused by the projector's EDID or slow sync time. This might be fixed with Gefen's HDMI Detective Plus, or the new HDFURY Dr HDMI, both of which can spoof other EDIDs as well as supply a constant signal.
Sisyphus is offline
post #184 of 295 Old 12-05-2011, 04:16 AM
andysm's Avatar
Here is a new but brief review of the Viewsonic:
http://www.reghardware.com/2011/12/0...500_projector/
andysm is offline
post #185 of 295 Old 12-09-2011, 01:48 PM
3DNewb's Avatar
So Jumi555, I'm curious if you were ever able to get over/under working with the VP3D1, did Viewsonic send you an update for it?
Are you and the wife, enjoying the 3D?
Which brand of glasses did you end up getting and how are they working out?
I know I enjoyed 3D gaming on my PLED. I wish one of the other clone owners would get 3D working at 720P, maybe they can, once the 3DFury releases, that's if the product is all that it claims to be. Prior HDFury products delivered as promised, from what I've read.
The Acer is on special promo sale for 500 bucks atm, I'd inform my friends, but they are waiting for conclusive reports on its 3D capabilities.
They'd jump on the PLED if it was similarly priced. I couldn't get them off of mine, when I was home. I'm still bummed that the 3D-XL did not work, I wish I had more time to mess with it.
3DNewb is offline
post #186 of 295 Old 12-09-2011, 01:58 PM
3DNewb's Avatar
Looking at the specs on the product page on the VP3D1, I see Top and Bottom is only supported at a 720P input. (1080P is, but only at 24Hz)
3D Mode Side-by-Side: 1080i / 60Hz, 1080i / 50Hz Frame-Packing: 1080p / 24Hz, 720p / 60Hz, 720p / 50Hz Top-and-Bottom: 1080p / 24Hz, 720p / 60Hz, 720p / 50Hz 2D Mode NTSC 480i/p, PAL SECAM 576i/p, HD 720p/1080i/1080p
3DNewb is offline
post #187 of 295 Old 12-11-2011, 07:24 AM
travis_bickle's Avatar
Quoted: 13 Post(s)
i am unsure about ceiling mount this little puppy. do you guys think or have expierence if such a cctv holder will do it?
http://www.amazon.de/Kamerahalter-MO...d_sim_sbs_ce_1
on the downside the projector has 1 hole for a tripod and three smaller holes for something i am not aware of. the stated mount holder above states it can handle up to 6,6 lbs. but what about the projector itselfs. the screw thread is placed around plastic. will it bear up with the projectors weight of about 2,6 lbs?
i am very thankful for any useful response
travis_bickle is offline
post #188 of 295 Old 12-12-2011, 12:48 PM
fatalfury's Avatar
Hi guys
just wondering something about the sound on the viewsonic. I know theres only a 3.5 audio in jack . If i attached my creative speakers through this (
i use this setup for my laptop via the headphone input) , will it disable the onboard speakers ? will the sound from the viewsonic travel through and play on the extra speakers ?
any help appreciated.
fatalfury is offline
post #189 of 295 Old 12-12-2011, 02:48 PM
3DNewb's Avatar
I have mine on a tripod. you can refer to these posts http://www.avsforum.com/avs-vb/showt...1#post21257871
http://www.avsforum.com/avs-vb/showt...5#post21252555
Originally Posted by fatalfury View Post
Hi guys
I tried it using an Altec Lansing Orbit speaker that has a 3.5 audio lead, it did not work. Suprisingly, this is what a Viewsonic Tec told me would work in an email. He told me speakers with a USB lead would not work, but I'm not so sure.
Link to speaker I have, that I was told would work, but did not.
http://www.amazon.com/Altec-Lansing-...3726269&sr=8-4
Link to speaker I think would work
http://www.amazon.com/Altec-Lansing-...726269&sr=8-14
3DNewb is offline
post #190 of 295 Old 12-12-2011, 02:59 PM
3DNewb's Avatar
I'm out of town, so can you guys tell me if
When using the Magnify function of the remote, does it do the whole image? or just a portion of the image? In otherwords, is it a zoom function for sizing the image to the screen?
I can't remember, I was too busy gaming when I was at home.
3DNewb is offline
post #191 of 295 Old 12-12-2011, 08:32 PM
madrid64's Avatar
hey I have a little experience mounting this kind of beamer, this is the link where I post what kind of ceiling mount I used, and how I put everythig together; http://www.avsforum.com/avs-vb/showt...304775&page=60
madrid64 is offline
post #192 of 295 Old 12-13-2011, 05:21 AM
Quoted: 13 Post(s)
so as you state in the linked post many people use this kind of security camera holders.
i think i'll give it it try with the one i posted earlier and give you response about how it matches and if it feels save and sturdy.
the three small holes would give me an ever worse feeling of sturdiness. when one thing breaks the others would drop too.
the only alternative to me would be to build something as a shelf mounted by brackets to the wall. but then i would've to lay the projector updside down on the wood and theres a risk someone tumbling about hdmi or power cable and let the projector drop.
post #193 of 295 Old 12-13-2011, 01:45 PM
3DNewb's Avatar
In the first link I gave it showed a picture from the Acer K330 manual showing that the manufacturer suggested mounting for ceiling applications was via the use of the 3 point mounting
I specifically stated "When in doubt, take the safe route imo."
The posters that had used security camera mounts were Qumi owners, the Qumi only has a single mounting hole.
While these projectors are not very heavy, I'm unsure if the use of the tripod mounting hole would cause any problems.
Regardless of how you mount it, if there's a possibility of someone tripping over the feed cable, you'd want to secure both the PJ and cable so securely that the damage is inflicted on the person and not the hardware.
They do make shelf mounts as well that you could use. http://www.amazon.com/s/ref=nb_sb_no...elf+wall+mount
3DNewb is offline
post #194 of 295 Old 12-27-2011, 02:35 PM
PatrickB101's Avatar
3dnewb picked one of these up on your recomendation! Looks nice. Looking around for a cheap fixed frame screen. Do you guys think I could make a 16:9 screen work correctly with this projector? or just buy a 16:10 screen as well?
http://www.overstock.com/Electronics...1/product.html
looking at something like that.
PatrickB101 is offline
post #195 of 295 Old 12-27-2011, 02:41 PM
post #196 of 295 Old 12-28-2011, 01:38 PM
fiocco's Avatar
This projector is compatible with dongle USB wifi ?
fiocco is offline
post #197 of 295 Old 01-26-2012, 09:44 AM
pabmas's Avatar
yes, with ViewSonic WPD-100
www.viewsonic.com/products/wpd100.htm
pabmas is offline
post #198 of 295 Old 02-05-2012, 03:44 AM
djloozer's Avatar
Can anyone confirm whether the PLED-W500 will do 1280x800/720 at 120hz over hdmi or vga so that it can be used with Nvidia 3d Vision as a generic monitor with the edid hack?
Actually would the above work for any of the three clones, I know it's been confirmed they can all do 3D at 1024x768 over vga with the dlp glasses but I'm planning to use the nvidia glasses and emitter instead.
djloozer is offline
post #199 of 295 Old 02-07-2012, 01:22 AM
fiocco's Avatar
djloozer, i have this projector but how i can to do that ? with the edid hack for 120 hz, plz thx.
fiocco is offline
post #200 of 295 Old 02-07-2012, 02:23 AM
eat meat's Avatar
use a dvi to vga adaptor, remove the to x marked pins on the dvi side,they send the edid data.it will show up as a generic or crt monitor now to the card.
00000000 o o
00000000 -----
00000xx0 o o
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #201 of 295 Old 02-08-2012, 01:09 AM
fiocco's Avatar
In 2012 ? used a DVI adaptor ?! it's a joke !
fiocco is offline
post #202 of 295 Old 02-19-2012, 09:38 PM
brand2's Avatar
Tigerdirect on ebay has w500 for $399.99
brand2 is offline
post #203 of 295 Old 02-21-2012, 09:47 AM
Miwo's Avatar
What kind of screens are you all using for this projector? What combination works? Should I go with a High Power Screen, High Contrast.... Gain? Looking for a 74-82" diagonal 16:9 screen to pair up with the PLED-W500 I snagged on the Tigerdirect deal.
Miwo is offline
post #204 of 295 Old 03-07-2012, 12:24 AM
Mayuyu's Avatar
my red is not red at all, max red only "tomato-like" only. black level seems a little worse than my Qumi
Mayuyu is offline
post #205 of 295 Old 03-28-2012, 08:14 PM
swerveddy's Avatar
Hi All,
I just ordered one of these units with the TigerDirect.ca deal they had going for 469, not that bad since the acer unit and optoma units I was looking at were quite a bit more.
I have a question regarding the 3d vision. I have an acer aspire laptop 5745DG that came with the 3dvision emitter built in and a pair of the 3d vision glasses to do some modest gameing and 3d bluray watching. I'm wondering If these exisiting glasses will be compatible with this projector.
I understand a few of you have got the 3d working. Does the projector have an emitter or should I just use the one that comes with my laptop.
Wondering if I need to buy any additional hardware for this function? I have the wireless p854 3d vision glasses.
swerveddy is offline
post #206 of 295 Old 03-28-2012, 11:07 PM
scurrier's Avatar
Hi Guys,
Thanks for supplying all of the great information in this thread. After reading it and going down a few of the rabbit hole links, I'm sitting here two hours later and wondering... can the clones all do 720p 120Hz 3D with DLP link glasses from an NVidia GTX570 via DVI to VGA adapters?
I think so, but I'm somehow unsecure in this even after all of the reading. I understand that I may have to fool with EDID spoofing.
scurrier is offline
post #207 of 295 Old 03-31-2012, 02:42 PM
snugglebuddies's Avatar
Hi all,
Thanks for tons of great info so far about this projector. I took the plunge this weekend and am fairly happy with the purchase.
My question whether or not to keep this projector is bouncing around in my head. First, the lense has some very small scratches on it which I'm 99% sure aren't from me and 99% sure make no noticeable difference that I could discern in picture quality. Also, some light leakage and barely detectable lighter spots at the outside of the actual projected area, like up where my playstation gives no data but is probably within the projectors projectable area.
In a nutshell I feel like I'm struggling with expecting a low end piece of equipment to perform like a high end piece of equipment. It looks good but I'm not sure what I should reasonably expect from these led clones and whether to return it, try another one, or lighten up about my plastic lensed toy.
Don't want to go crazy obsessing about the small stuff if that's just part of the experience at this price range.
This is also my first projector.
Thanks! Any advice appreciated.
snugglebuddies is offline
post #208 of 295 Old 04-03-2012, 02:02 PM
Xperience's Avatar
I tried to connect the pled w500 directly from a PC with ATI HD5450 graphics card via hdmi and the PC would only put out 1024 X 768 @ 120 Hz.
Next I tried with another PC with nvidia GeForce 9600GT via a DVI cable and DVI-HDMI adapter. Again the PC would only list 1024X 768 @ 120 Hz in the display modes.
So in both PCs it was NOT possible to get true 720p output to projector @ 120Hz.
This is probably an EDID issue and the reason why 3D-XL also failed to work with the pled w500. I think that the VP3D1 probably ignores the EDID portion that mentions the capabilities of the monitor @ 120Hz and sends out a 720p signal @ 120Hz to the pled w500 based on model (or other parameters).
Anyone here know any EDID hacks to get 720p @ 120Hz from a PC for 3D viewing at 720p?
Tehen likes this.
Xperience is offline
post #209 of 295 Old 04-03-2012, 04:40 PM
nigroandres's Avatar
Same problem here, 120hz only 4:3 from hd5450
I wrote viewsonic support, whith no response
I set windows to 1024x768 120hz, set proyector force to 16:10, and increse horizontaly size in mkv ...
Size original * 1.6 / 1.333 = new size
nigroandres is offline
post #210 of 295 Old 04-03-2012, 09:33 PM
Sisyphus's Avatar
Cool. Thanks for testing that! Not too familiar with Nvidia but there should be an option for creating a custom resolution of 720p @ 120hz.
I wonder if you could use the Gefen HDMI Detective to capture the edid information from a projector like the Optoma HD66 or GT720 and connect it between the Optoma 3DXL and Viewsonic W500 or Acer K330.
Sisyphus is offline
Viewsonic Pled W500 80 Inch 720p Front Projector Black , New Led Projector 1280x800 500 Lumens 3500 1 Pled W500
