Your Panasonic PT-AE4000 Throw and Room size? - AVS Forum | Home Theater Discussions And Reviews
Old 07-26-2011, 06:48 AM - Thread Starter
filetandrelease's Avatar
As the title says, whats you Panasonic PT-AE4000 Throw distance, screen size and Room size? Thanks fells.
filetandrelease is offline
Old 07-26-2011, 09:54 AM
Quoted: 14 Post(s)
Room size 22 1/2X 17 1/2 (basement) 2 windows
Projector shelf mounted 6' of the floor
distance from screen 15'
Screen size 129x54 scope 140''
Currently using drywall as my screen, planning on using the MAXXMUD V.2 (spray)
HiDef Lover is offline
Old 07-26-2011, 10:52 AM
jskibo's Avatar
19'4" x 16'8" room
15' throw
138" Elite Scope screen
jskibo is offline
Old 07-26-2011, 12:07 PM - Thread Starter
Perfect,wanted to go 138" but wasnt sure,sounds like that acceptable for my space. 15x24x8'
Old 07-26-2011, 12:48 PM
tsantanni's Avatar
Me:
138" Scope screen
15' Wide x 29ft Long
Ceiling mounted
14'5" throw.
If you can fit the big screen do...I LOVE mine.
tsantanni is offline
Old 07-27-2011, 01:49 PM - Thread Starter
Originally Posted by tsantanni View Post
Me:
138" Scope screen
Ceiling mounted
14'5" throw.
Sounds like the plan then!
Old 09-30-2011, 06:50 PM
2-Dogs's Avatar
bump
What would be the optimal mounting distance for an AE4000, flush mounted (8ft ceiling), projecting onto a 120" 16:9? The screen is 59 x 108, the top is about 4" from the ceiling.
Panasonic's guide suggests between ~12ft and 24ft. The room is 24ft long.
2-Dogs is offline
Old 01-17-2012, 05:59 PM
sivartk's Avatar
Me:
138" Scope screen
Ceiling mounted
14'5" throw.
Thanks, this is good to know. I'm looking at this projector and a 125" scope screen. Their formula comes out to 12 feet 11.4 inches. I should be able to do this distance, but always like a little wiggle room (at 13', I would have 1 foot between the back of the projector and the rear wall) and my goal is to set it at 13' 2-3", but the +/- 5% disclaimer on the formula was scaring me a little.
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is offline
