AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Digital Projectors - Under $3,000 USD MSRP (http://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/)
-   -   HD71 or HD72 (http://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/1353578-hd71-hd72.html)
danrl88 08-12-2011 06:09 PM
I was wondering if I could get
some quick advice. I have the opportunity to pick up an HD72 used with a new bulb, and ceiling mount for $330. Or an HD72 fac. refurb with 1 year warranty for $550.
I will be using the projector in my basement, not a light controlled room but moderately dark during the day. Mainly movies and xbox 360.
Which would you recommend?
Thanks for your time and advice,
Dan
EDIT: Any information would be greatly appreciated - just some basic advice.
guitarman 08-13-2011 02:44 PM
Id get the cheaper one $300 into a PJ won't bother you too bad if it bites the dust. It's a pretty bright projector you won't have a problem, games should look great.
danrl88 08-15-2011 07:03 AM
Hey, thanks for the reply. I should clarify the $500 one is an HD71 not 72. That was a typo.
Would you still make the same recommendation.
I was leaning more towards the 72, because of the cost (this being a low budget introduction into projectors for me).
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
