New Optoma HD33 HD3300 1080p 3D Projector Review - Page 178 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #5311 of 5382 Old 07-14-2014, 12:50 PM
robl45's Avatar
Quoted: 167 Post(s)
Originally Posted by ufsuperfly View Post
So I have had my HD33 since it released and it's time for a new bulb, but also I moved my screen a little so I need to remount my hd33. I was thinking of replacing my hd33 with a hd25e due to price and newer technology and hopefully not moving it again for 3yrs.... Picturewise would I be better off with just replacing the bulb?
Smallish room 135" screen with full ambient light control...
Bulb is like 95 bucks if you buy the bare bulb, I just changed one in my gt750 a couple months back.
robl45 is offline
post #5312 of 5382 Old 07-14-2014, 04:33 PM
ufsuperfly's Avatar
But is the picture or contrast or features any better with a hd25e or benq 1070 than my hd33? I know I love the simplicity of the hd33 3d glasses....
ufsuperfly is offline
post #5313 of 5382 Old 07-14-2014, 04:57 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
Yeah the HD33 is bright enough and it has the best color wheel RGB/RGB. The Benq has an RGB/RGB wheel but I'd still prefer the optoma for it's better black level.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #5314 of 5382 Old 07-16-2014, 03:04 AM
ufsuperfly's Avatar
Thanks so much for the information!! Another question I have is it easier or better to replace it with a bare bulb vs. The replacement lamp? Any gotcha or best practices replacing either? Thanks again for the help!
post #5315 of 5382 Old 07-16-2014, 05:12 AM
robl45's Avatar
Quoted: 167 Post(s)
easier to replace the replacement lamp because you take out a couple of screws pull out lamp, and put in new lamp. It costs like 2 to 3 times as much.
I got an osram bulb from ebay, pulled out the lamp assembly, unscrewed it and swapped the lamp, there was a video or something I think that showed how to do it, like 4 screws or so to take the cage apart. You just need to make sure you don't touch the bare bulb, only touch the base and use paper tower or something so your skin doesn't touch the glass and get oil on it.
robl45 is offline
post #5316 of 5382 Old 11-03-2014, 11:54 PM
Liked: 0
hd 33 info
1.Does hd 33 has any frimware updates
2.when i select 3d on remote side by side and top and bottom can be selected but frame sequential is unselectable
3. how to convert 2d into 3d read that in reviews optoma hd 33 can do this
raidenblood is offline
post #5317 of 5382 Old 11-04-2014, 02:42 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The HD33 is discontinued and when I had mine it was not user updateable you had to send it to Optoma. It has no 2D to 3D converter. Frame sequential will auto select when playing a like BR, the SBS/TOP bottom are user selectable because many of those files don't have the command to auto select those types of files.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #5318 of 5382 Old 11-05-2014, 04:17 AM
Liked: 0
THANKS A LOT
IS EDID OVERRIDE NESSCARRY FOR 120 HZ t 720 p
when it selects 3d automatically it says 720 60 hz instead of 120 hz
post #5319 of 5382 Old 11-05-2014, 03:05 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
HDMI 1.4 spec for frame sequential 3D 720p 60hz per eye and the screen refresh rate is 120hz. 1080p 24hz screen refresh rate is 96hz. Newer projectors have triple flash for 1080p 24hz screen refresh rate is 144hz.
rekbones is offline
post #5320 of 5382 Old 11-05-2014, 08:33 PM
Liked: 0
Let me be more specific
when ever i run a game or movie in 3d mode enable the projector says
1. 720P 60 hz shouldnt it be 720 p 120hz
and on default with 3d enabled it says 1080p 24hz
post #5321 of 5382 Old 11-06-2014, 02:53 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The HD33 to my knowledge (and most 3D projectors) can only accept for 3D frame sequential an input of 720p 60Hz or 1080p 24Hz. For 720p 120Hz the screen refresh rate would have to be 240Hz but the projectors max is 120Hz. For 2D or a SBS/TB it might be able to accept a 720p 120Hz signal but you would have to check the Manuel and it might not even tell you if its supported.
rekbones is offline
post #5322 of 5382 Old 11-07-2014, 03:21 AM
Liked: 0
here you go
now u can explain
post #5323 of 5382 Old 11-10-2014, 12:30 AM
Liked: 0
I have uploaded the manual pic (hd 33 ) pls explain following
1. In my screen resloution settings ----> advanced monitor not showing 120 hz as selectable
2. While sbs 3d and time sequential 3d (power dvd ) projector shows 720p 60 hz instead of 120 hz
post #5324 of 5382 Old 11-10-2014, 03:32 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The Manuel clearly states 720p 120hz is not supported. Only 1024 x 768 120hz is supported. I don't know if powerDVD is capable of such a resolution. I not sure what your question is. Your clearly using a PC so video card type, drivers and software are involved and add many variables.
rekbones is offline
post #5325 of 5382 Old 11-27-2014, 12:11 PM
falafala's Avatar
Quoted: 23 Post(s)
Thinking of buying HD25-LV
I have not visited this thread in last 2 years and surprised its still going!
I started out with a HD33 which I absolutely loved but returned it for a Epson3010 for its brightness, better warranty and many other extra features and lower price back in 2012.
Now both Optoma and Epson have released new models under 1K and my Epson bulb is getting dimmer on my 150" screen. Plus my TV is broken, so may just move my Epson onto a small screen (80") to replace my TV and buy a new PJ for my 150"
I want to re-live the magic of HD33 but with a newer model. Thinking of HD25-LV for its 3200 lumens. Do you guys think this is a worthy replacement or is there another model i should be looking at?
falafala is offline
post #5326 of 5382 Old 11-28-2014, 10:00 AM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The BenQ 1070 is the only close replacement for the HD33. Most of the new Optoma's don't have an RGBRGB color wheel and run at 2x. HD33 has 6x RGBRGB wheel with a DC2 chip and also FI. BenQ 1070 has no FI but is DC3 chip and 6x RGBRGB with triple flash 3D that's helps over come the missing FI for 3D judder. Some of the higher optoma models are about the same as the BenQ but at about 2x the price.
rekbones is offline
post #5327 of 5382 Old 11-28-2014, 04:56 PM
falafala's Avatar
Quoted: 23 Post(s)
Thats disappointing! So there is no budget successor for HD33 within Optoma line?
This review sounds encouraging.....
Optoma HD25 and HD25-LV owners
falafala is offline
post #5328 of 5382 Old 12-01-2014, 04:09 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The HD25 uses a 2x RGBRGB wheel (not the HD25e/lv) and is a very good replacement but it is discontinued also and hard to find. A refurbed HD33 would be in my opinion better choice than any of the new entry level optomas.
rekbones is offline
post #5329 of 5382 Old 12-01-2014, 04:26 PM
falafala's Avatar
Quoted: 23 Post(s)
which i want to avoid as i hated the lumens on HD33. Was hoping HD36/HG50 may fit the bill.
falafala is offline
post #5330 of 5382 Old 12-01-2014, 04:39 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
Sure they will work at 2 or 3 times the price of the BenQ 1070 and when compared in reviews are no better. I can't even find them for sale in the US.
rekbones is offline
post #5331 of 5382 Old 12-01-2014, 05:58 PM
kreeturez's Avatar
Quoted: 469 Post(s)
Liked: 354
The HD36 is unavailable in the US but marketed elsewhere (often as the HD151X). It's only marginally pricier than the W1070+; and it's very, very bright.
Kraine posted a review on the HD36 thread: out-the-box color accuracy isn't great, but it does calibrate reasonably well (gamma tracking isn't amazing though).
For raw lumens, it's a good choice if you don't mind sacrificing black levels, shorter lamp life and some image noise. It should best Optoma's other lower-end options (HD26/HD141X/etc) for image performance. For huge screens (or very bright rooms), I reckon it's a good option.
The HD50 on the other hand, is nice but a bit pricey for its image performance.
Keep in mind that your old HD33 only calibrated to around 900 lumens: the BenQ rekbones mentions is nearly double as bright; so it'd still be a big improvement in brightness. It's also very color-accurate out-the-box with better black levels than the HD36 and longer lamp life and cheaper lamps (with no image noise); so it's a good option if you think it'll be bright enough (for most people, it is).
Otherwise get the HD36.
BenQ HT2050 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #5332 of 5382 Old 12-01-2014, 07:58 PM
falafala's Avatar
Quoted: 23 Post(s)
Darn! Missed a deal on Amazon today for $639 for 1070
falafala is offline
post #5333 of 5382 Old 12-25-2014, 11:39 AM
audionewer's Avatar
i have a problem with my HD33 pj. When i watched tv shows with my hd33, it flashes bright light. i watched tv show with my htpc.
i have a nvidia video card (GT520).
do anyone know how to fix this problem?
ty
audionewer is offline
post #5334 of 5382 Old 02-24-2015, 01:46 PM
sfc wx1's Avatar
3D Image splits into left/right image
My Optoma HD 33 projector has trouble projecting 3D movies. It will beginning to show the 3D image correctly. After about 5 minutes the image will begin to flicker and then splits into the left and right image. I must shut the projector down in order for it to reset. It will begin showing the 3 D image properly after the reset. However, after five minutes the problem begins again.
Does anyone have a suggestion to resolve the problem? I have contacted Optoma and they want $110 to perform a diagnostic check. Before I send it in, I thought I would ask forum members for suggestions.
sfc wx1 is offline
post #5335 of 5382 Old 02-24-2015, 02:39 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
I would try a full factory reset, its in the menus some where but I can't remember exactly where. If that doesn't work its most likely has a problem
rekbones is offline
post #5336 of 5382 Old 03-23-2015, 03:40 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
I've had good luck cleaning ribbon connectors on all types of electronics, even my computer it was dead slow a shot of Deoxit 5 on the ribbon from the main board to the hard drive fixed it. If your handy look for any ribbon connections take the ribbon out spray it with D5 work it in a couple of times. Allot of times electronics are just not communicating clearly.
Fixed a marshal amp like this, a Marantz SR7200 just this week. Owner said analog volume control was broken. D5 on the large ribbon going from knob to the main board fixed it. See what I mean
Tom/guitarman
VideoDementia
post #5337 of 5382 Old 03-23-2015, 08:01 PM
frrypol's Avatar
Having never owned or installed a projector, how much of an issue does the ceiling layout present? The projector would need to be mounted where the higher ceiling begins to be in the center of the room, and be aimed parallel to the lower ceiling which runs the length of the room. From the projector to the display wall is about 16ft. The corner in the photo is the corner of the mechanical closet in the layout.
frrypol is offline
post #5338 of 5382 Old 03-31-2015, 05:31 PM
Nuieve's Avatar
Quoted: 86 Post(s)
Liked: 26
Can someone tell me if tilting HD33 is feasible in attaining a decent picture? Will keystone help?
I have a floor-to-ceiling 165" screen in my new room and while I'm waiting to purchase a better projector I'm thinking of bringing this one temporarily (it's mounted at my other place) and just tilting it up from a high mounted shelf.
I need to project from about 18ft (recommended placement is about 13" ABOVE screen, and I will put it about 13" BELOW screen top)
I don't really want to bother dismantling it unless there's a chance of more or less normal looking picture.
Nuieve is offline
post #5339 of 5382 Old 04-01-2015, 02:47 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
Keystone correction will degrade the picture. Is it unwatchable, no of course not but your are effectively lowering the resolution of your 1080p projector to closer to 720p
rekbones is offline
post #5340 of 5382 Old 04-27-2015, 09:20 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
Got a new tip, you want even better blacks use the Standard gamma instead of film, blacks get 40 percent better. Grayscale tuning will stay the same. On mine grayscale setup went easy minus one on the red gain and plus 3 on the blue gain, rgb bias stays at zero's, I also use pure detail at 2. Give it a shot see what you think. Watching Gotham right now and blacks plus detail look the best ever. Pretty great projector.
Tom/guitarman
VideoDementia
Optoma Hd33 1080p 3d Projector , Projectors
