replacement filter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-24-2011, 01:23 PM - Thread Starter
newmember1's Avatar
I have a old sony projector, vpl-x1000u. The filter is about 1/8 inch think and it's black foam material.
Nonetheless, it's time to get a new filter and don't know what to replace it with.
Any suggestions?
newmember1 is offline
post #2 of 10 Old 08-24-2011, 01:42 PM
Sheridan1952's Avatar
Rinse it out and reuse it. (after it's dry, of course)
Sheridan1952 is offline
post #3 of 10 Old 08-24-2011, 05:34 PM - Thread Starter
newmember1's Avatar
Its falling apart and has a small hole in it.i've been washing it every couple months
does anyone know a material that would work for it?
the filter is completely flat, and a black foam like material about 1/8 inch. I think some newer projectors still use similar filters.
post #4 of 10 Old 08-24-2011, 05:43 PM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Have you Called Sony to see if the filter is available?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 10 Old 08-24-2011, 05:46 PM - Thread Starter
newmember1's Avatar
The projector was released in 1998 and hasn't been made for years.
post #6 of 10 Old 08-24-2011, 06:01 PM - Thread Starter
newmember1's Avatar
post #7 of 10 Old 08-24-2011, 06:44 PM
mjg100's Avatar
You can buy microfiber filter and cut to size. It is a much better filter than the foam that comes with the projector. That is what most of the guys that own the Viewsonic Pro8100 do. Here is a post with a link. http://www.avsforum.com/avs-vb/showt...9#post18230949 Look under insufficient dust filter work around.
mjg100 is offline
post #8 of 10 Old 08-25-2011, 07:07 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I replaced one in an old Panasonic with a vent filter (that goes at the outlet, not at the furnace) I think it was also electrostatic for dust collection. I could cut one into about 10 small filters, and can toss it out every few months.
lespurgeon is offline
post #9 of 10 Old 08-26-2011, 05:43 AM
Bohanna's Avatar
Liked: 24
for a quick fix go to Home depot Lowe's or maybe even wally world and look for frost king Polyurethane Air conditioner filters. They are 30 PPI (pours per inch), Ideally you want a filter that is 100 PPI. If you have the projector permanently mounted I would look for a square shaped auto air filter available anywhere. They are by FAR the best if you can fit the projector with one. I have a Fram on my Sanyo and its great. It lasts a LONG time cleans easily and allows for great air flow
Bohanna
Bohanna is offline
post #10 of 10 Old 08-27-2011, 09:32 PM - Thread Starter
newmember1's Avatar
thanks for the advise mjg100, lespurgeon, and Bohanna
I picked up vent filter material at lowes. and it seems to do the job.
