Panasonic PT-AR100 MSRP$ 1,999 - 4000U replacement... kind of - Page 34 - AVS Forum | Home Theater Discussions And Reviews
Old 12-16-2013, 05:46 PM
flanntastic's Avatar
Originally Posted by Mr.G View Post
Try Provantage. They have the real deal.
http://www.provantage.com/panasonic-et-laa110~7PANP0T6.htm
i know you had asked for this a month ago but i waited as long as i could to change my bulb, ended up getting 2700 hours out of it, could have got more but i thought i might as well do it.
bought a bulb from the link above, and it came quickly, it came with full instructions and a new filter.
here is what it looked like out of the package (cell phone pics)
flanntastic is offline
Old 12-16-2013, 05:47 PM
forgot to say but changing the bulb was quick and painless, took two minutes
Old 12-17-2013, 07:58 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Thanks for the post. I was curious whether a replacement filter was still included with the lamp. I see Provantage is offering the lamp for $300. I'd order one but I'm only at 2350 hours and it's still quite bright.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
Old 01-06-2014, 07:48 AM
mym6's Avatar
I'm sure I'm breaking a cross posting rule but I'm not sure how many AR100U owners are watching both threads and I'm in a small bind. I contacted support about a uniformity issue with my projector and they claimed it was within the norm. I disagreed and they asked for more photos from other owners. Does anyone have the time and are willing to take some photos of an all white image?
Here is mine for comparison (using cinema):
Support also asked me to provide photos of the image in all output modes along with examples from others.
Linux based Apple file server made easy
ControlPlane - Make your mac context and location sensitive!
mym6 is offline
Old 02-12-2014, 05:55 PM
basecorvette's Avatar
Hello everyone. I'm configuring my devices to work with the xbox one & voice commands. Does anyone know what device to select that will send the PT-AR100 the double off command. A few work and send the single on command, but I can't find one that does the double off.
Thanks for any help you can provide!
basecorvette is offline
Old 02-13-2014, 10:57 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Don't think this question has come up before. Best chance of finding an answer is to contact Panasonic directly, either by phone, email, live chat or form submission.
Panasonic Contact Technical Support for Projectors:
Mr.G is offline
Old 02-16-2014, 07:09 AM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 306
Well I love the AR 100 but I guess I can count on spending $300 a year on a bulb unless I get a new PJ...which will prolly be the case anyway, soon. If you can start getting bulbs with twice the life that's obviously $150 annually, assuming a comparable $300 lamp cost. In a few years it starts to legitimize a ~$2,000 higher-performing alternative.
At just under a year of ownership I'm up to 2600+ hours and that's with 2+ months outside and ~10 hours a week viewing between August and the World Series. And while it's still fine with some light control, it's noticeably dimmer than last February. When it gets moved to a more permanent indoor installation surely I'll be near 3,000 hours within a year with my "tv-style" watching habits and a 3 year old home with my guidance-counselor wife during the summer.
For as much as I'd like to keep it for dedicated outdoor viewing and get another for inside I simply cannot justify it as I have but 4-5 months out of the year for such activity in Wisconsin. Sigh.
Oh well. Great PJ, it's just the pinch of 300 fazools every twelve months for me.
Take care, all.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is online now
Old 02-18-2014, 02:39 PM
iolmaster's Avatar
I have my AR100 for about 2 years and only have about 600 hours on it. I decided to check the filter and removed the cover. It looked very clean. (ceiling mount in a clean environment) I tried to take the filter out to look a bit more closely and was unable to pull it out. I don't have the best leverage due to the fact it is on the ceiling but I could not get it to budge. I checked the manual and it says pull it out. Is it really that simple? Any advise?
iolmaster is offline
Old 02-19-2014, 05:55 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
If it's your first time removing the filter, yes it's a pretty snug fit. The plastic tabs that hold it in place are slightly over-sized so it takes a good pull to get the filter unit out. It can be a little disconcerting at first.
Once you get it out you will see that filter unit has tabs for disassembling. This allows easy access to the gray foam filter (which can look clean but is usually loaded with a fine dust) which should be vacuumed clean. Underneath the foam filter is the electro-static filter which is white and pristine but should be vacuumed too. When vacuuming the foam filter be careful not to accidentally suck it into the vacuum cleaner. To get around this some people rinse the foam filter in water to remove the dust then blot it dry with a paper towel to remove all moisture. Reassemble the filter unit and replace in projector.
Some people like to use compressed air to blow out the dust. However this should be done outside so as not to introduce the dust back into the room air.
For the overly cautious if the filter is going to be out of the projector for a long time drape a sheet of microfiber lint free cloth across the opening. Also turn off the furnace/air conditioner while cleaning the filter to minimize the movement of air in the room.
Mr.G is offline
Old 02-20-2014, 03:30 PM
iolmaster's Avatar
I did get it to come out. So, I vacuumed the two parts. They didn't look at all dirty and didn't look any different after vacuuming.
Old 02-20-2014, 06:25 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Yes, I'm not surprised that your projector filter wasn't that dusty after 600 hours. I guess it can go another 600 hours no problem. wink.gif
Mr.G is offline
Old 02-21-2014, 05:09 AM
iolmaster's Avatar
I think the recommended 100 hour interval is overkill for vacuuming the filter.
Old 03-07-2014, 05:39 AM
Bluedog225's Avatar
Putting it through the dishwasher works great.
Bluedog225 is offline
Old 03-07-2014, 08:02 AM
iolmaster's Avatar
Not sure if you are joking, but page 73 in the manual says not to wash the filters. I would not do that.
Old 03-12-2014, 05:49 AM
Bluedog225's Avatar
Not joking. It has worked well for years. I didn't know the manual indicated otherwise. Probably fine either way
Old 03-19-2014, 11:05 AM
kezug's Avatar
I currently have the PT-AX200u and its bulb is getting pretty dim. I have had this since 2008. I love this projector.
I am considering replacing this instead of purchasing a new bulb.
With that said, I have no use for 3D, but am currently torn between the AE8000u or the AR100u.
My room is light controlled to an extent. I am at 50/50 in terms of Movies vs nonMovies.
My room is setup to be lights out for Movies but some lights on for nonMovie situations like for watching TV, games, or video games or concerts.
You can see my room in my signature build thread.
I am wondering if the AE8000u is too much money especially if I am not using it for 3D.
What are your thoughts?
kezug is offline
Old 03-20-2014, 07:48 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
If you loved the AX200U and it fit your viewing requirements then you'll be happy with the AR100U. Brighter, better contrast and 1080p. As you probably know the AR100U is the successor to the AX200U.
http://panasonic.net/avc/projector/special/home_cinema_projector/
The AE8000U is designed for a true home theater environment ie. a bat cave. If you're not planning on using it that way then it's probably a waste of money. It's all subjective.
Mr.G is offline
Old 06-30-2014, 07:18 PM
sermad's Avatar
Hi all.
Has anyone taken one these apart? Like FULLY apart.
My HDMI 1 input stopped working so I removed the main board to check it out and doing so undid where the optics are. Yes yes I know. This was obviously a massive schoolboy error as I introduced dust somewhere - infact I think I touched one of the lenses. Again yes yes I know. OK.
Before I do the right (and probably costly thing) of sending it back to panasonic for a service...I was wondering if anyone had any tips of cleaning dust from the inside of unit - not where the bulb is..but where the actual optics are.
Also if anyone has photos of the interior - where to put the right screws etc then I would appreciate that.
sermad is offline
Old 07-01-2014, 08:21 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Originally Posted by sermad View Post
Hi all.
No one has posted information on how to clean out dust blobs or have taken their projector apart. Although this is a problem for all LCD projectors it hasn't been a major issue with the AR100U so far. As time goes I'm sure owners with dust blobs will become more common.
The only help I can provide is a copy of the AR100U service manual if you don't have it. PM your home email address if interested.
EDIT: This is no longer true. I recently had the misfortune of having a dust blob show up in my AR100U. For more information go to this link on the official thread on the AR100U.
The official Panasonic PT-AR100U Owners Thread
Mr.G is offline
Old 08-30-2014, 08:59 PM
p150's Avatar
Quoted: 16 Post(s)
Liked: 0
Hey - I'm in the same boat. I've also had the AX200u since 2008. It's showing some end-of-life signs. Did you upgrade to the AR100u? If yes, how do you think it compares?
p150 is offline
Old 08-30-2014, 09:48 PM
mtucker's Avatar
That is the same upgrade that I did..... AX200U to PT-AR100 in 2012 and I am glad I did. I had a ton of hours on my two bulbs for the AX200 and decided to buy the AR100. Although my room has almost total light control, it is still a great projector for me. in ECO mode the AR100 is brighter than the 200 (especially if your bulb is getting dim), but not overly bright. I couldn't get myself to cough up the extra money for the AE8000 or whatever was in that class in 2012. I was surprised how much bigger the AR100 is compared to the AX200. I had to put a larger shelf on the wall to hold her.
mtucker is offline
Old 08-31-2014, 05:52 PM
p150's Avatar
Quoted: 16 Post(s)
Liked: 0
Thanks. If you don't mind, a few specific questions on the two:
1 - How does the AR100 do in low-light scenes? I find the AX200U is at its worst when the scenes are dimly lit.
2 - Do you know if the AR100 has the flicker problem that the AX200u had? This has been a pet peeve of mine since 2009 or so when it first showed up. It's sporadic.
3 - How does the fan noise compare? The AR100 is apparently louder but is this a problem? My projector sits on a shelf not far from the couch.
p150 is offline
Old 09-02-2014, 10:42 AM
mtucker's Avatar
The AR100 is still a LCD projector so its black levels are so-so and the dark scenes don't have the best contrast. I don't think it is noticeably better at dark scenes / black levels than the AX200.
I saw flicker on the AX200 about four times. Each time running the bulb for a day at full power (non eco) took care of the flicker for me. I have not seen the flicker on the AR100 and I don't remember anyone complaining about flicker with it. I gave the AX200 to a friend who is still using it.
The fan noise (in eco) was louder on the AR100 than the AX200. My projector sits right behind where I sit mounted on the back wall a few feet above head level so I am very close to it. I remember thinking "wow, that is loud" when I first plugged it in and was calibrating it, but of course I never watched the AX200 without sound. Sitting there with no sound makes you more sensitive to fan noise. I get a movie going and I don't think about it, but it definitely seemed like it had more fan noise compared to the AX200. It isn't a problem for me, but people are sensitive to different things.
Matt
mtucker is offline
Old 10-14-2014, 07:49 PM
DB07's Avatar
Liked: 0
Hi guys. new owner here. Quick question regarding ceiling mount.
I know, that Mr. G recommended Peerless mount Peerless-PRG-UNV-W
I have 8ft ceiling, and I wonder if I need any extension pipe. If Mr. G could point me in a right direction I would appreciate.
DB07 is offline
Old 10-15-2014, 10:07 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I like to drop down any LCD projector I've owned to near the top edge of the screen. I also have an 8 foot ceiling in my home theater/family room.
EDIT: This is my personal preference since my AR100U is mounted near the back wall and not out in the middle of the room. There is more than enough lens shift in the AR100U to fit your screen even if mounted directly to the ceiling with the Peerless mount.
If you're going with the Peerless mount then I can recommend the Peerless 6"-9" adjustable column, something like this:
http://www.bestbuy.com/site/peerless...=1218719521571
You also need the Peerless ceiling plate, something like this:
http://www.bestbuy.com/site/peerless...late&cp=1&lp=1
For a DIY solution a few people like to use PVC pipe cut to the appropriate length for an extension column. You attach/cement 1 1/2 NPT male adapters fitting to both ends of the PVC pipe.
Mr.G is offline
Old 10-15-2014, 07:44 PM
DB07's Avatar
Liked: 0
Thanks Mr. G for checking in. I've tired to reply on your PM, but unfortunately my post count is too low.
For now I've decided to buy the ceiling mount only, and check if I need extension column or not. I' m gonna project on the wall, and don't want the top of the picture to be too close to the ceiling.
DB07 is offline
Old 10-20-2014, 03:36 PM
DB07's Avatar
Liked: 0
Mr.G did you use all four arms from peerless ceiling mount to attach your PJ. The reason I'm asking is, that the holes are not symmetrical, and i wonder what's your configuration.
DB07 is offline
Old 10-20-2014, 08:45 PM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
You will see in the AR100 owners thread - post 152 - that I centered the mount over the middle of the projector.
http://www.avsforum.com/photopost/da..._IMG_0437.jpeg
Mr.G is offline
Old 11-08-2014, 09:23 AM
Liked: 0
I just got my first Replace Lamp graphic and red lamp light last night at an even 2700 hours. I was hoping to get another 100 or 200 hours out of the lamp but its okay since I have a spare ready that I ordered from Provantage via the recommendations on this thread.
questions to those who have changed lamps....
Did you reset the timer with the old lamp in the unit within the 10min window or did you put the new lamp in only to clear the timer and have the PJ shutdown? Id like to avoid such a short startup on the new lamp if possible.
digiman30 is offline
Old 11-11-2014, 10:35 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I only reset the timer after inserting the new lamp and have never had any issues. But don't see any problem with doing a reset with the old lamp in place.
Mr.G is offline
