Optoma ml500 Vs Acer K330. What's better??? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 73 Old 10-21-2011, 07:25 AM
rapsac's Avatar
Originally Posted by spuernase View Post
Under no circumstances I would buy a projector with a heat dissipation above 100 watts. Something like the Vivitek Qumi with 17 watts in eco mode would be best.
My flat (in a low energy building) would actually overheat with any of these stupid projectors producing 200 or more watts of heat.
One person generates 100W in heat, i wonder what will happen in your flat during a party :P
It takes a big man to admit he's wrong... I'm NOT a big man! (Fletch)
rapsac is offline
post #62 of 73 Old 10-21-2011, 07:54 AM
spuernase's Avatar
Actually the heating energy (at -15°C outside) is calculated with 10 watts/m² (a so called Passive House), so a party during summer would make some problems indeed (especially when using a projector with to much heat dissipation). During winter, you could open the windows a little to get rid of the heat.
spuernase is offline
post #63 of 73 Old 10-25-2011, 05:06 PM - Thread Starter
Ir bass's Avatar
Are you guys talking about led projector or bulb????
And tell me what you guys think about Mitsubishi Hc 4000??
Thank's
Ir bass is offline
post #64 of 73 Old 10-31-2011, 09:35 AM
hanselda's Avatar
BTW, I am also considering buying one of these two. However Optoma lacking the audio output is really annoying. Since all these 500 Lumen projectors are so similar, I tend to think they also have similar hardware inside. Optoma might already have audio-out pins on its PCB but simply not used.
hanselda is offline
post #65 of 73 Old 11-02-2011, 01:35 PM
snoche's Avatar
Hi guys, I bought the Acer K330.
In general I am very pleased with it but I can't found a way to use the 3D Ready.
I tried to talk to "Nvidia support" and "Acer support" , they are just pointless telemarketing guys who didn't know what they are talking about, and nobody cares to help me.
Nvidia told me is not compatible with their Nvidia vision glasses. But in Acer manual it tells me to buy a Nvidia glasses I call this Scam. I have been 3 weeks messing around and no clue what I am doing wrong, too many 3d formats and ********.
Does anyone tried to use 3D with his projector?
I have an Nvidia 580 gtx, 8gb ram, sandbridge 4cpu, and I connect the projector with a dvi cable to vga input on the projector. I have the second monitor as 1024x768 120 hz and use as a primary monitor.
I have a Nvidia Vision glasses,
I have installed latest drivers 285.62-desktop-win7-winvista-64bit-international-whql
But didn't reconice the projector in 3D wizard.
Also Nvidia told me to install 3dTV and same luck ;(
Anyone has a clue? anyone tried 3D with this projector?
Please help, I am getting crazy
Thanks in advance,
David
snoche is offline
post #66 of 73 Old 11-02-2011, 02:02 PM
eat meat's Avatar
try the dvi to vga adapter hack(you cut 2 pins off of adapter,how to in the qumi thread i think)I wont send edid data then you pick generic crt 1024x768@120hz in your nividia menu.
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #67 of 73 Old 11-02-2011, 02:06 PM
eat meat's Avatar
also wont work with 2 displays hooked up also probably, try with just the pj hooked up.
(fifth element)
eat meat is offline
post #68 of 73 Old 11-02-2011, 03:43 PM
3DNewb's Avatar
It's a shame that it just doesn't outright work with Nvidia, but there is also TriDef and iZ3D that you can use, both have free trials. But you may need DLP link glasses for them, TriDef may still work with Nvidia glasses by choosing one of the Display types as, if I remember right, Stereo3D.
Meat is right, if you remove the display ID pins, it will be seen as a generic CRT monitor. Here's an article on it http://3dvision-blog.com/how-to-use-...ith-3d-vision/
You can also do an EDID override using the .inf file from an Acer 5360.
If you felt you were misled, there are laws against deceptive business practices. IMHO these projector companies as well as Nvidia are certainly in the grey area. Their out, I'm sure is that you could always use anaglyph. But there is an argument for customer assumptiom/expectations.
3DNewb is offline
post #69 of 73 Old 11-15-2011, 12:41 PM
3dprojector's Avatar
Quoted: 140 Post(s)
Liked: 63
Hi guys
my ML500 cannot be connected to a desktop using hdmi cable,any idea?
thanks
3dprojector is online now
post #70 of 73 Old 11-15-2011, 02:22 PM
HenryDudley's Avatar
Which page would that be? I certainly can't find it. I can't find anywhere where they claim 3D Vision support or recommend it.
HenryDudley is offline
post #71 of 73 Old 09-24-2012, 01:07 AM
user192's Avatar
Hi
I want to buy a video-projector for occasional movie watching and playing games.
I have to choose between Optoma ML500 and Acer K330.
They have the same price, same spec (don't really need the audio out from acer).
Thanks in advance for the replays.
user192 is offline
post #72 of 73 Old 09-24-2012, 06:45 AM
RPS13's Avatar
Liked: 31
They're roughly the same since they basically have the same guts. I'd say the ML500 has a more attractive case if that helps. smile.gif
RPS13 is offline
post #73 of 73 Old 09-24-2012, 07:34 AM
user192's Avatar
thank you
i was just wondering if the lens are different or the firmware that makes the difference, but probably not...
if anyone has something else to say, please say your opinion. i will buy it next week
user192 is offline
