22 FL too much? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-05-2011, 07:13 PM - Thread Starter
BlackSS's Avatar
I'm looking at projector for a relatively small dedicated HT room.
Screen will be 110" diagonal, viewing distance will be 12'.
The calculator on the manufacturer's (Optoma) web page says I will be at 22 foot lamberts. Will that intensity be too much?
BlackSS is offline
post #2 of 12 Old 10-05-2011, 08:11 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
The lamp will DIM over time, but it will be a bit much for a while. All you have to do to prevent eye strain is turn a tiny bit of light on in the back, not direct light. Once the lamp wears in, you should be fine after 200-300 hours of usage.
Access HERE from this thread
coderguy is offline
post #3 of 12 Old 10-05-2011, 08:23 PM
Brad Horstkotte's Avatar
Liked: 68
You can always adjust brightness on the projector, or add a filter in front of the lens if its too bright for you. Too bright is a nice problem to have.
Brad Horstkotte is offline
post #4 of 12 Old 10-05-2011, 08:24 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
Doesn't it have an ECO mode that lowers the light output?
You could get low gain gray screen to.
2016
42Plasmaman is offline
post #5 of 12 Old 10-05-2011, 10:51 PM
chumpchange21's Avatar
That's what I was thinking too.
What projector are you thinking of getting anyway?
I Love Apple, BenQ, Samsung, and Acer Products = )
chumpchange21 is offline
post #6 of 12 Old 10-06-2011, 08:31 AM
Michael Sargent's Avatar
Quoted: 179 Post(s)
Liked: 164
Sunglasses?
Honestly, this is probably the first time anyone has ever posted anywhere about a projector being too bright. Congratulations!
Michael Sargent is offline
post #7 of 12 Old 10-06-2011, 11:41 AM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
If it's the Optoma hd33, there is a good chance that is the minimum he can bring the projector down to on a small screen, it's super-freaking-bright.
coderguy is offline
post #8 of 12 Old 10-06-2011, 06:24 PM - Thread Starter
BlackSS's Avatar
I'm looking at the new Optoma HD3300.
I think being on the bright side will be beneficial for 3d viewing. If anything I will get a filter instead of a screen with a lower gain as removing the filter is much easier than changing screens.
We close on the house tomorrow, so the HT project will begin soon.
BlackSS is offline
post #9 of 12 Old 10-06-2011, 06:34 PM
Wouldn't you want to see if you can get some deals in the next 2 month holiday sales? Is there a reason for the rush?
post #10 of 12 Old 10-06-2011, 08:32 PM - Thread Starter
BlackSS's Avatar
I plan on waiting for the holiday sales. I have plenty of other stuff to do before I by the big ticket items.
BlackSS is offline
post #11 of 12 Old 10-06-2011, 08:49 PM
BobL's Avatar
Liked: 56
Most people don't complain about it being too bright until >40 ft/l. 22 is fine, we usually recommend 25-30 for a new bulb to maintain a minimum of 12 ft/l as the bulb ages.
BobL is offline
post #12 of 12 Old 10-06-2011, 09:39 PM
Airion's Avatar
Liked: 61
I recently upgraded to a 2.6 gain screen and calculated the FL for my two projectors.
Mitsubishi HC3800: Guessing the lamp has dimmed to 75% and 1.5 gain from my seating position I get about 30 FL in best mode.
Acer H5360BD: Fresh lamp, 2.5 gain from my seating position, I get 67 FL in 3D mode.
I actually run both in eco mode, so I'm not actually getting that much. In a dark room, I think the brightness is for both projectors looks great and doesn't bother me at all. Of course for the Acer that 67 FL gets cut down significantly by the 3D glasses, and the result is vibrant, appropriately bright 3D, much better than when I used a 1.0 gain screen.
So my opinion is that no, 22 FL will not be too bright. In fact if you use the HD3300 for 3D, you might find the brightness lacking, though probably acceptable.
Airion is offline
