How to remove dust in Panasonic PT-AE900U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-09-2011, 10:23 AM - Thread Starter
mbilderb's Avatar
I have a PT-Ae900U that I just replaced the original bulb. Inside, the prism was filthy, so I wiped it gently with a cloth. When I started up the projector, I noticed there was still a lot of dust on the inside of the lens.
Is there a way that I can clean off the dust?
On the old bulb, there was burning or discoloration, resembling the corosion found on a tintype that was in the sun. I fear that a similar fate may exist inside my lenses. Is that possible? If so, how do I go about cleaning it?
Also, where can I find a safe download of the Service Manual to aid me in my task?
mbilderb is offline
post #2 of 5 Old 10-09-2011, 12:03 PM
dragonbud0's Avatar
Quoted: 121 Post(s)
Liked: 64
Try this and see if it would help, though a different Panny model. It worked for my old ae500.
http://www.avforums.com/forums/proje...b-removal.html
dragonbud0 is offline
post #3 of 5 Old 10-09-2011, 07:21 PM - Thread Starter
mbilderb's Avatar
[quote=dragonbud0;21058160]Try this and see if it would help, though a different Panny model. It worked for my old ae500.
Thanks, I will give it a try.
mbilderb is offline
post #4 of 5 Old 10-14-2011, 07:34 AM - Thread Starter
mbilderb's Avatar
I tried opening the case and blowing canned air through the three holes where the ribbons attach. I carefully vacuumed everwhere I could. I also tried to blow as much with canned air as I could, without taking anything other than the lid off of the unit.
I still have a build-up of dust inside the lenses. The projector is now 5 going on 6 years old, so it isn't under warrantee.
Any suggestions on how I can get the dust from inside the lenses? I doubt there is a service center nearby, but if there is, how much would I expect to pay to clean it up?
mbilderb is offline
post #5 of 5 Old 10-14-2011, 08:18 AM
Sheridan1952's Avatar
You keep saying "inside the lens". Is this dust that you actually see inside the projection lens? And do you see dust in the image?
Sheridan1952 is offline
