My Epson 3010 projector just arrived! - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 03-06-2012, 04:30 AM
mankhan's Avatar
Dear falafala, xhonzi, and other 3010 users, please post your comments that how was your experience of watching HUGO and PUSS IN BOOTS 3D BDs on your 3010. On what screen size your watched, how much was ghosting or crosstalk, etc. Thank you.
mankhan is offline
Old 03-06-2012, 10:52 PM
falafala's Avatar
Quoted: 23 Post(s)
120" no ghosting with monster
falafala is offline
Old 03-07-2012, 12:20 AM
mankhan's Avatar
no ghosting at all. even the blu-ray.com review of these movies confirmed that there is crosstalk with these movies, how come you dont have same. I feel that Monsters are magical glasses, isn't it?
mankhan is offline
Old 03-07-2012, 02:59 AM
falafala's Avatar
Quoted: 23 Post(s)
No magic....pure science ! Just try them
falafala is offline
Old 03-07-2012, 02:12 PM
catmother's Avatar
Fry's special this week for the subject combo.
A tad under 1500.
Best price I have seen, bought Saturday.
Just projecting an a white blank wall for now and tested with "Under the Sea, "Avatar", and "Legends of Flight".
Like the performance.
I own ~ $1500 worth of calibration gear and an Iscan Duo and when the screen gets mounted I will do a complete calibration and report here.
But for now I will need to find an installer to mount the screen for me.
Anyone know of a reliable BBB rated installer in Sand Diego ?
I can not do this myself at age 84 and lacking the strength to mount a 25 lb screen in a somewhat difficult position in a room with a beam ceiling.
Certified HDTV junkie and AVS addict
U.S. Army FA WWII
catmother is offline
Old 03-08-2012, 04:09 AM
quickfire's Avatar
Catmother..is your room light controlled?....if it is then i cant wait to see the calibrated settings.
quickfire is offline
Old 03-08-2012, 09:23 AM
catmother's Avatar
Not really light controlled, but with vertical blinds on the patio door (20 feet) and venetian blinds and fabric panes on the 4 windows facing west it can be made reasonably dark in the day and of course quite dark at night.
The room is large and a combination kitchen and family room.
My current display is the LG 55LH90, LED back lit LCD with full local dimming calibrated to what I consider impeccable PQ.
U.S. Army FA WWII
Old 03-12-2012, 02:01 AM
mankhan's Avatar
Originally Posted by xhonzi View Post
Someone can correct me if they know better, but does the "3D Brightness" control on the 3010 actually affect the shut period on the glasses? It seems to me that it does. Higher brightness=glasses are open more=more crosstalk. Less brightness=glasses are shut more=less crosstalk.
Or is it actually affecting how much the brightness is boosted by the PJ in 3D mode?
Does that mean that 3D brightness=High = More crosstalk, is practically useless setting due to high crosstalk considering using Epson or other glasses except Monsters. Then what is the use of this "high" brightness 3D setting? Epson does not know that or what?
mankhan is offline
Old 03-12-2012, 09:17 AM
xhonzi's Avatar
Quoted: 21 Post(s)
As far as I understand it, it's offering you the ability to control the tradeoff. Since I don't need the extra brightness, I'll happily trade it in for less ghosting. If ghosting doesn't bother you, but you want the extra brightness, you can go that route as well. I'm guessing Epson understands that very well.
If I'm guessing correctly, the 3D brightness option won't affect the Monster glasses or any glasses using an external emitter because I think this option only affects the IR signal being sent to the epson glasses. The Monster emitter basically has the same trade off, but apparently gives you greater control of the tuning.
Continuing this line of speculation, I'd assume that the major difference between Monster and Epson/PS3 glasses isn't the glasses per se, but the ability to more precisely tune the timing for the emitter.
xhonzi is offline
Old 03-12-2012, 10:26 AM
falafala's Avatar
Quoted: 23 Post(s)
Yes, but they should have given a more finer slider control (like other settings) to give full control over this tread-off
confirmed
you got it
falafala is offline
Old 03-12-2012, 11:57 PM
though's Avatar
Hi all-
I just got this today and when I power it on, the red temperature light flashes red continuously. The lamp doesn't turn on, nothing. Is there something I can do to remedy this or is it a dud?
Please Help
though is offline
Old 03-13-2012, 01:03 AM
falafala's Avatar
Quoted: 23 Post(s)
Originally Posted by though View Post
Hi all-
Please Help
Call Epson, get free bulb
falafala is offline
Old 03-13-2012, 08:05 AM
Mr.G's Avatar
Quoted: 607 Post(s)
Liked: 312
Hi all-
Please Help
Send it back.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
Old 03-13-2012, 10:57 AM
though's Avatar
So when the temperature light flashes red, the lamp is bad most likely?
though is offline
Old 03-13-2012, 12:03 PM
xhonzi's Avatar
Quoted: 21 Post(s)
Or the lens caps was on. *shame*
xhonzi is offline
Old 03-14-2012, 05:32 AM
Lt.Aldo.Raine's Avatar
Can anyone tell me if an Epson 8350 ceiling mount will work with the 3010 ? Are the screw holes for the mount underneath the 3010 in the same place as the 8350 ? Thanks
BASEMENT HOME THEATER - EPSON 5030UB 2D/3D PROJECTOR W/ 100" ELITE SCREEN - RECEIVER - HARMON KARDON 1710 7.2
FRONT SPEAKERS - INFINITY PRIMUS P363 CENTER SPEAKER INFINITY PRIMUS PC351 - SIDES AND REARS POLK AUDIO 30'S + 40'S SUBWOOFERS PREMIER ACOUSTIC PA-120 650 WATT TITANIUM + POLK AUDIO PSW110
Lt.Aldo.Raine is offline
Old 03-14-2012, 07:25 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1774 Post(s)
Liked: 808
The Mounting hole locations are the same.
MississippiMan is offline
Old 03-14-2012, 03:52 PM
I have the 3010 coming Friday and i think not having lens shift will be a problem for me. I have my current projector (8350) is mounted from my ceiling and it pretty much points directly towards the top of my 100" fixed frame screen. My ceiling is real low about 7 ft. Do you think i will have to lower the projector so it will shoot straight at the screen. If i have to aim my projector down then i will be messing up the picture and i will have to use the keystone correction which i do not want to use... Also if i have to lower the projector to much it will be in the way. I cannot shelf mount because there is no where else to put it. Thanks
Here is pretty much where to lens height is...
Old 03-14-2012, 04:56 PM
action_jackson's Avatar
Quoted: 326 Post(s)
Liked: 114
The 3010 should be mounted so that the lense is centered and in line with the top of the screen when ceiling mounted. If your 8350 is already mounted in this location, replacing it with the 3010 should be a snap. I just replaced my HC 400 with a 3010 last week. Mounting holes line up and I only had to make minor adjustment to get the image to line up with the screen. I say put it up and see how it looks.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is offline
Old 03-15-2012, 07:43 PM
ulvy's Avatar
Electronic Expo has a combo that includes the 3010, 4 glasses and a Blu-Ray drive on sale
$1599
ulvy is offline
Old 03-15-2012, 09:11 PM
WestCoastD's Avatar
Quoted: 253 Post(s)
Liked: 96
is it technically okay if the lense is centered with the screen but maybe, say, 1ft below the top edge of the screen?
WestCoastD is offline
Old 03-16-2012, 11:28 AM
I just set up my 3010 and my PS3 is not recognizing my 3D blu rays...i have tried 3 of them. Is there something i have to do to the PS3.......I does not recognize my 3010 a being a 3D display...Is there a setting on the Epson that i have to use ?thanks for your help
Old 03-16-2012, 12:57 PM
mflanagan's Avatar
I just got my 3010 today and it looks great. However I cannot get 3d to work. I have an HTPC with an ATI 5700 card in it going directly to the 3010 via HDMI. I am using powerdvd 11 for the player. To test I downloaded some 3d MTV files. But for the life of me I can't get 3d to display properly. When I toggle the 3d button on the remote I get the "the current input image sittings do not display in 3d" any ideas that to try next?
Thx
Edit* My Monoprice HDMI splitter is the problem. Monoprice says it wont pass 3D from a video card (ATI 5700) even tho the splitter is 3D capable.
Flan's Theater!
Xbox Gamertag: Darth Flan
mflanagan is offline
Old 03-16-2012, 01:58 PM
mankhan's Avatar
can anyone advise that after how many hours one should clean filter on 3010
mankhan is offline
Old 03-16-2012, 02:42 PM
junda's Avatar
Originally Posted by stuart628 View Post
okay so my mount for my projector sits back 13 feet from my 100" 1.1 gain screen....would this mount work for the epson 3010?
http://www.amazon.com/Atdec-TH-WH-PJ...9510990&sr=8-3
I know it has to be situated right...my hd33 fits perfect right now, so I am hoping if I get a 3010 it would just slide right in there with no extensions or anything needed
I can confirm it works with 3010.
junda is offline
Old 03-18-2012, 02:21 AM
Quoted: 326 Post(s)
Liked: 114
When I first connected mine, I went into the setup menu on the PS3 and let it auto-detect the appropriate settings for the resolution. If you have not done this, do this first.
Are you connected directly to the projector, or are you going through a receiver or switch between the PS3 and the projector? Try connecting directly to the projector and see if that solves the problem.
Old 03-18-2012, 02:36 AM
Quoted: 326 Post(s)
Liked: 114
Placing the projector anywhere but the recomended location will skew the image. I currently have mine about 6 inches to the right of center and the left side of the image is about 2 inches taller than the right. It is not very noticeable unless I have my computer desktop pulled up because the icons across the bottom are halfway onto the border. If you place the projector below the recomended height, it will have to point up which will cause the bottom to be narrower than the top. The term for this effect is called keystone because the image takes the shape of a keystone in the center of an arch. If you have decent masking you may not notice it too bad, it just depends on how picky you are about it. You can also use Keystone correction to adjust the image back to normal dimensions.
Old 03-18-2012, 03:44 AM
ggrajan26's Avatar
Hi, today i received my Epson 3010 projector.
My setup is
Media pc with ATI Radeon HD5570 graphic card and withPowerDVD with 3D plugin
Connecting to Pioneer VSX 920 3D ready receiver
Connecting to Epson powerlite 3010
When I turn on 3D on my PowerDVD for a 2D movie, PowerDVD is detecting the display.
Same time Projector is not getting any 3D signal.
When playing 3D movie, still powerDVD not detecting the display type.
please help.
Thank you.
Govind
1 803 580 7410
ggrajan26 is offline
Old 03-18-2012, 09:04 AM
mankhan's Avatar
I am not familiar with ATI but i am also using 3010 with my HTPC using nVidia 520 GT. In nVidia control panel there is 3D settings which one has to activate before using 3D. See your ATI settings for your video card there must be some 3D settings, etc. just play with those settings and see if your PowerDVD detects and post your results. Also ensure that from your PC to Pioneer and Pioneer to Epson you are using HDMI 1.4 cable.
mankhan is offline
Old 03-18-2012, 12:41 PM
WestCoastD's Avatar
Quoted: 253 Post(s)
Liked: 96
thanks "Mr Jackson", gives me better insight.
The reason I ask about this (proper centering of projector) is because the rear-wall of my theater room has a heater/air-conditioner vent positioned at center, mounted on the ceiling surface, approx 6.0in out (see image below).
My plan, or hope, is to mount the projector using a (Peerles) wall-mount assembly, such that the projector will be maybe 1.0 or 2.0 feet below vent:
http://www.amazon.com/14-Projector-W...&sr=8-11-spell
I'm concerned the vent could be intrusive on the projector (especially if heat is flowing out onto projector), I'm wanting to position the projector somehow away from the vent. Not sure how best to position the projector in this situation?
Epson , Epson Powerlite Home Cinema 3010e Full Hd 1080p 2d And 3d Home Theater Projector With Integrated Spe , Projectors
