My Epson 3010 projector just arrived! - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1981 of 2034 Old 10-11-2013, 02:13 PM
falafala's Avatar
Quoted: 23 Post(s)
My fellow 3010 proud owners!
Cant believe its almost 2 years since I got my 3010 and many of you also own it for that long.
How are you enjoying it? Are you itching for an upgrade? I for one want a 4k projector but thats not going to happen any time soon and am very happy with my 3010 so far.
In the last yer i ceiling mounted it and setup a 7.1 surround sound in my living room and installed a 150" and bought a Fusion Escape HT seating and have a poor mans mancave setup smile.gif
falafala is offline
post #1982 of 2034 Old 10-11-2013, 05:00 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
Can't believe I've also had mine for almost 2 years as well (in December). Still very happy with mine. Other than a noisy iris which I just leave off it's been problem free. I use it primarily for 3D and the iris isn't activated then anyway. I frankly can't see that having it on makes any difference in 2D anyway so I never bothered to try to exchange it. I also have a Viewsonic Pro8100 that I use for most of my 2D.
Happy viewing!
Ed
old corps is offline
post #1983 of 2034 Old 04-25-2014, 04:54 AM
sniiki's Avatar
Everyone in these thread has been cheering how amazing 3D this projector has so I'm wondering if my unit is somehow defective as the 3D in my TW6000 (European equivalent to 3010) is really lame. The effect is just really faint and there's now wow neither in depth or pop out.
I have 100" screen and viewing it from ~3,5m. Besides Epson glasses, I have X-pand X104's and there's no difference in 3D depth perception. I use HTPC and PS3 as source. Video is routed via Yamaha RX-V3060.
If I view the same material, using same source, with my cheap 55" Sony HX755 the effect is from another planet. It's immersive, clear and gives nice depth feeling.
So, as the video source is same, only difference can be the output device. I returned my projector once as the first unit had terrible problem with reddish picture on the other side edge and bluish on the other, but really can't say if my current unit has severe crosstalk or if it's within "normal crappy" limits. Besides the crosstalk, is there anything that could possibly affect to the 3D perception or the impressiveness of 3D material? Unit still has warranty and the iris is keeping so loud noise that I cant bare to use it so that would be one way to try to switch the unit to a new one in case there could possibly be some benefits to 3D quality as well.
Has anyone else (especially those who have replaced their units from warranty) noticed any difference in the 3D quality between different units?
sniiki is offline
post #1984 of 2034 Old 04-25-2014, 12:10 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
I'm wondering if you need to reverse the timing of the glasses. Just for kicks try turning your glasses upside down when viewing a 3d movie. If this happens to solve the problem go into the menu for 3d setup (page 45 of the U.S. manual) under "Inverse 3D Glasses" and change it. Note that you can't use this setting when 3d format is on Auto. Hope this takes care of the problem. Sure sounds like it might. I've had my 3010 for close to 2 1/2 years and it does 3d very well.
Good luck!
Ed
post #1985 of 2034 Old 04-25-2014, 01:42 PM
falafala's Avatar
Quoted: 23 Post(s)
Good luck!
Ed
Also there is a "3D brightness setting" that you can play with.
I don't see the annoying cross talk like i used to do before with my epson or ps3 glasses. May be replacing batteries fixed it.
But if you are seeing cross talk then the unit is defective and it will destroy the 3d effect.
falafala is offline
post #1986 of 2034 Old 04-25-2014, 01:45 PM
falafala's Avatar
Quoted: 23 Post(s)
I noticed my 2.5 year projector show slight flicker in some cases. Its not always there but once in a while the bulb seems to be flickering which changes the brightness over a few seconds.
I am running in ECO mode and also turned on hi altidue fan on and off but it does not seem to make a difference.
Has anyone seen this?
falafala is offline
post #1987 of 2034 Old 04-25-2014, 03:55 PM
action_jackson's Avatar
Quoted: 351 Post(s)
Liked: 131
[quot="falafala" url="/t/1366241/my-epson-3010-projector-just-arrived/1980#post_24648392"]I noticed my 2.5 year projector show slight flicker in some cases. Its not always there but once in a while the bulb seems to be flickering which changes the brightness over a few seconds.
Has anyone seen this?[/quote]
In my experience, this means the bulb is at the end of its life. Mine started doing this at about 4500 hours. I switched to using living room color setting and out of eco mode until about 5000 hours and the flickering was not present. Went ahead and put a new bulb in a couple of weeks ago and retired the old one.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is online now
post #1988 of 2034 Old 04-25-2014, 04:07 PM
falafala's Avatar
Quoted: 23 Post(s)
In my experience, this means the bulb is at the end of its life. Mine started doing this at about 4500 hours. I switched to using living room color setting and out of eco mode until about 5000 hours and the flickering was not present. Went ahead and put a new bulb in a couple of weeks ago and retired the old one.[/quote]
Thanks a lot for response. I thought this thread is dead and no one would respond smile.gif
Are you saying i should use it in one of the high power modes like living room or dynamic?
The brightness is plenty even in Cinema mode, which i use all the time as living room is too bring for me. The picture brightness has not gone down but it flickers (as if someone is shaking the projector) .
Is there any harm in letting the bulb die on its own?
also could you please post a link on where to get the bulb and how much?
falafala is offline
post #1989 of 2034 Old 04-25-2014, 04:52 PM
Quoted: 351 Post(s)
Liked: 131
I had a warranty through Best Buy and they sent me a replacement bulb. I would order direct from Epson or a certified dealer. I think they run about $299. I'm not sure about running the bulbs until they expire, my parents had a couple explode. That could have been because mom was turning it off by using the button on the surge protector...
Mine stoped flickering in the brighter mode, I guess you have to choose between flickering or the image being too bright. I chose the brighter mode as I found the other annoying.
post #1990 of 2034 Old 04-25-2014, 06:16 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
I got another lamp directly from Epson. It IS $299 but they periodically offer 10-15% off on their website. I got mine for $255 with free shipping-15% off. They just had 10% off but I think it's over now.
Ed
post #1991 of 2034 Old 04-25-2014, 06:39 PM
falafala's Avatar
Quoted: 23 Post(s)
Thanks for the feedback on lamps. I will also try the high power mode next time it starts to flicker.
I am tempted to go cheap
http://www.amazon.com/V13H010L68-ELPLP68-V11H421020-V11H450020-Projectors/dp/B00FDRCAD0/ref=sr_1_1?ie=UTF8&qid=1398476298&sr=8-1&keywords=epson+3010+lamp
5 months warranty!
falafala is offline
post #1992 of 2034 Old 04-26-2014, 02:43 AM
ashyt16's Avatar
Quoted: 37 Post(s)
Are you sure you have your 3d settings correct? What is your 2D source Bluray, SBS, OU?
You say you have a HTPC and PS3 as source, so are you saying the PS3 is somehow routed through the PC and you are using a software player?
ashyt16 is offline
post #1993 of 2034 Old 04-26-2014, 06:16 AM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
5 months warranty!
Good luck with cheap. My experience with aftermarket lamps (not for the 3010) wasn't good but some get lucky.
Ed
post #1994 of 2034 Old 04-26-2014, 09:40 AM
sniiki's Avatar
Thanks for suggestions everyone.
Old coprs, yes the timing is correct and 3D effect is there, but it's really lame compared to other 3D output devices. Hard to explain but like said, it's just not that impressive at all like it's on other devices, even small TV screens. For instance in Gravity 3D where pieces fly towards viewer I feel a need to dodge when watched in 3D theater or even using my 55" Sony. With Epson it's just... well really poor.
falafala, yea I've experienced with 3D brightness with different films but doesn't seem to make any difference to the depth effect. Only helps to fade away that crosstalk. Crosstalk is really noticeable, even with lowest brightness. Maybe that's the reason for poor effect as, if I adjust "depth" (separation) with my sony, I get really bad crosstalk on Sony too and 3D effect suffers heavily. Would be nice to have such setting on this projector too.
ashyt16, yes my settings should be correct and like said, same film with same source with different output device looks like it should. I have 2 HDMI outputs from my Yamaha, other one going to my Sony TV.
I've done these tests with all those source materials you mentioned (bluray discs, PS3 games, SBS and half-SBS). On HTPC I've used PowerDVD 13 and MPC-HC.
sniiki is offline
post #1995 of 2034 Old 04-26-2014, 11:18 AM
sniiki's Avatar
Not sure if this is helpful at all but here's two shots from Gravity 3D bluray through X-pand X104. First with 3D Brightness set to high and in second set to low. Crosstalk can be seen clearly in subtitles and it's equal bad in higher contrast scenes. Gravity isn't the best example material as the 3D in the film is subtle and therefore it doesn't suffer from crosstalk that much. Eventho, the 3D experience with Epson was relatively lame.
sniiki is offline
post #1996 of 2034 Old 04-26-2014, 07:05 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
Very strange, don't know what else to suggest but something is amiss. 3d on my 73" Mitsubishi TV is very good. On my 120" screen with the 3010 it's great.confused.gif Best of luck!
Ed
post #1997 of 2034 Old 04-27-2014, 10:09 AM
falafala's Avatar
Quoted: 23 Post(s)
Just when I was thinking I was the only one fluttering brightness I come across this
http://www.avsforum.com/t/1501609/epson-3010-fluttering-brightness
falafala is offline
post #1998 of 2034 Old 06-11-2014, 11:39 PM
Liked: 0
epson result is the absolute , me the use product their, absolute much
minhngoc233 is offline
post #1999 of 2034 Old 06-12-2014, 08:06 AM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
WOW! Really???
Ed
post #2000 of 2034 Old 07-15-2014, 11:02 PM
hoopsbwc34's Avatar
Hey all... did Epson ever release a firmware update for the 3010? I had hopes they would since it was the first generation but the Epson website doesn't show anything.
I found a link earlier in this thread here but it's not active:
hoopsbwc34 is offline
post #2001 of 2034 Old 07-16-2014, 06:49 AM
Mr.G's Avatar
Quoted: 744 Post(s)
Liked: 423
You are going to have to call Epson support to request the firmware update.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #2002 of 2034 Old 08-06-2014, 05:13 PM
CaliCool's Avatar
Hello guys! The thread's alive and kicking.
Just wanted to ask (especially falala) your viewing distance from the PJ and how many inches you've set it?
I recently foudn out that sitting farther from the PJ at 100", the Crosstalk seems to be reduced. I have a hybrid HT set-up, the second row elevated by a custom made platform. It seems like sitting on the second row gives us lesser crosstalk, though sometimes it's still really noticeable.
I have to set it to 3D Brightness: LOW in order to reduce some of the really bad crosstalk. Games have no hope either.
And also, could you guys share your settings? Having the PJ for 2 years now kinda bores me, just something to keep the "fire" alive you get what I'm saying?
Thank you all!
CaliCool is offline
post #2003 of 2034 Old 08-06-2014, 05:58 PM
CaliCool's Avatar
Sad that my set has horrible 3D. Tried the Panasonic 3rd Gen and EPSON Glasses... funny that it seems seating distance plays a part on the crosstalk as I've recently discovered. I have a hybrid HT (sometimes it serves as a karaoke room, a must here in our country) so I have pretty much controlled lighting. When I sit further, crosstalk seems to be minimized but it still there.
My only option is to turn the 3D Brightness to LOW, anything higher will display obvious crosstalk.
Last resort: heard about the PS3 glasses that seems to work well with EPSON and some have said (on other forums) that they reduce crosstalk. After that, I give up on 3D on this set if it's still horrible.
Also another note to users of this projector, turning on ECO mode for a long time will result in "flickering brightness". Someone offered me a more scientific explanation on this one, but basically the solution is to turn it to Normal Mode for several hours before switching back to ECO.
The flickering brightness will still be there though, so if your PJ has it, it will be a recurring problem. Shame that knocking the brightness down to ECO offers respectable blacks.
My post on another forum. FYI to all.
CaliCool is offline
post #2004 of 2034 Old 09-04-2014, 06:21 AM
mankhan's Avatar
Hello everyone. Hope every body is still enjoying 3010 like I do. It is great projector. OK. I live abroad and I need to buy 3010's lamp and I went through some websites who are selling this lamp and have international shipment but the issue is that on some websites lamp's price is as low as 89$ and on some websites lamp price is 299$ so i am bit confused and all claim these to be genuine lamps. Can any give me advise on this issue that which lamp I should purchase. These low priced lamps i guess are after market then why they claim that these are genuine? Does any one here had experience with aftermarket lamps and are they working good so far??
mankhan is offline
post #2005 of 2034 Old 12-04-2014, 11:22 PM
Liked: 0
Powerlite 3010 Audio Cuts out
Hi Guys, I'm hoping someone can help me with this:
The Audio randomly cuts out for a few seconds. Sometimes it happens infrequently so that you just miss a couple words in the show here and there, other times it happens every 1-2 seconds so you can't even watch anything. Unplugging the HDMI and reconnecting it seems to help a little for a short time. I have used several different high quality (according to the dish tech) cables. This started happening a couple months ago and I have replaced the dish receiver twice which helps for a few days. This problem does not occur if I watch movies from my cpu connected by hdmi. it also doesn't happen if the dish receiver is connected to a traditional tv by hdmi. It only happens when the dish receiver is connected to the projector. Video is fine, no problems there. I have also checked that the outlet is wired and grounded correctly. Does anyone have any other ideas?
dohert20 is offline
post #2006 of 2034 Old 12-07-2014, 05:43 PM
Quoted: 351 Post(s)
Liked: 131
My projector recently started overheating. I noticed the filter was a little dusty, so I cleaned it and it overheated again the next day. The projector shuts down and both the lamp and temp lights flash red. Anybody have an idea what might be going on?
post #2007 of 2034 Old 12-10-2014, 05:04 PM
Quoted: 351 Post(s)
Liked: 131
Hopefully I have solved this problem. I installed a new filter in it today and so far it is working fine. I guess these filters don't last forever, just wish they were not $20 each. It seems a little steep for such a small filter.
post #2008 of 2034 Old 12-12-2014, 04:46 PM
falafala's Avatar
Quoted: 23 Post(s)
My 3010 bulb is getting dimmer off late of 3 years of daily use.
I now switched to NORMAL mode and even living room mode for extra brightness at night. I want to delay buying a bulb as long as possible and so may even go to Dynamic mode if needed. Its nice to have such a range of brightness to chose from.
However offlate the cross-talk is getting worse and its taking me away from a true 3D experience. I am now exploring DLP projectors for an upgrade and there are tonnes of choices for 2000+ lumen DLP projectors now a days compared to 2011 when the only competitor was Optoma HD33.
falafala is offline
post #2009 of 2034 Old 12-15-2014, 12:38 PM
falafala's Avatar
Quoted: 23 Post(s)
I just got HD-25LV and am completely blown away with its brightness on my 150". Even in ECO mode its too bright in 2D and for 3D the extra brightness is just superb. The quality rivals the amazing 3D projection I saw in theaters with super sharp, super bright 3D with ZERO cross-talk.
After seeing what a true cross-talk free 3D would look like, i now realize how much I have been missing with my beloved 3010 LCD which is prone to cross-talk. Even in many movies where you don't see a clear double-image, there is always a layer of cross-talk that is not obvious to the eye but it basically distorts the image that takes you away from whats possible with DLP.
After seeing this, I realized that any one who is not watching 3D w/o cross-talk is doing a disservice to themselves. As much as I loved 3010 for all the goodies it offered 3 years ago, its clearly outdated compared to the new breed of projectors. If you are a true 3D fan, I urge you to check out these new models.
falafala is offline
post #2010 of 2034 Old 12-22-2014, 02:19 PM
falafala's Avatar
Quoted: 23 Post(s)
replacement bulb
Folks my 3010 has only 1800 hrs on it and its already very dim. yesterday i had to switch to Dynamic Mode to get the last bit of brightness left before I am forced to buy a bulb. At this point I am wondering if I should invest in the bulb or just retire it and just upgrade the projector. The Optoma HD25LV I got is supeb in 3D (3 frigging thousand lumens in 3D is heaven) but I find 3010 has a better looking 2D image and so a thinking of keeping both.
Does anyone have the same problem with their bulbs are are you still chugging along with your original bulb. Also any opinions on the cheapo 3rd party bulbs on Amazon for $35?
http://www.amazon.com/V13H010L68-ELP...pson+3020+bulb
falafala is offline
Epson , Epson Powerlite Home Cinema 3010e Full Hd 1080p 2d And 3d Home Theater Projector With Integrated Spe , Projectors
