My Epson 3010 projector just arrived! - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2011 of 2034 Old 12-27-2014, 10:04 AM
rhinomike's Avatar
Quoted: 34 Post(s)
We have had our home theater system for about 2 or 3 years. Never had a problem. We love it. Turned it on today and on the right side of the screen it is blue. Like from the bottom up the screen about 3/4 of the way everything is blue. The picture is still there but everything is the color blue. Any ideas as to what it could be? Could my bulb be going out?
I have an Epson 3010. 1433 hours on the bulb.
rhinomike is offline
post #2012 of 2034 Old 12-27-2014, 10:05 AM
rhinomike's Avatar
Quoted: 34 Post(s)
Another pic. Sorry I can't get the pic turned correctly. The blue stripe is on the right hand side of the screen.
post #2013 of 2034 Old 12-29-2014, 11:00 AM
Liked: 0
action_jackson
is your projector issue fixed? mine started doing the same.
Luis Gonzalez is offline
post #2014 of 2034 Old 12-29-2014, 02:54 PM
action_jackson's Avatar
Quoted: 353 Post(s)
Liked: 131
Originally Posted by Luis Gonzalez View Post
action_jackson
Yes, mine is fixed. I replaced the old filter with a new one and everything has been good for the last couple of weeks. I had cleaned the old filter regularly, but it just had too much build up in the fabric to allow enough air to pass through. I found the filter on the wal-mart website and had it shipped to store.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is online now
post #2015 of 2034 Old 12-29-2014, 03:05 PM
Quoted: 353 Post(s)
Liked: 131
Mine is doing something similar, but not as bad as yours. I have my projector mounted on the ceiling so it is inverted. The trouble with mine is on the lower left corner of the image. When I first power the projector on it is very noticeable, but after it warms up it fades. It used to fade away completely after about 10 minutes, but now it never entirely fades away anymore.
At first I was not worried about it too much, but now it is getting annoying. I read in another thread that it was caused by something in the light path, not the bulb or the LCD pannels, but something else. I have had similar issues with my last two projectors, the Sanyo PLV Z2 and the Epson HC 400.
post #2016 of 2034 Old 12-30-2014, 08:36 AM
falafala's Avatar
Quoted: 23 Post(s)
Folks, if your 3010 needs a bulb replacement or a repair, I highly recommend you to look into upgrading to one of the many new DLP projectors. I was a big fan of 3010 3 years ago as it was the only PJ that combined many goodies like 2-year warranty, brightness, vibrant film-like image quality, excellent 3D performance with minor cross talk. Now that the bulb aged rapidly even at 1800 hrs, the cross-talk has become unacceptable. I am quite upset with this degradation as bulb aging should only make the image dimmer but not destroy the quality.
Now i am cross roads of plunking in $300 for a new bulb and instead I decided to switch to Optoma HD25LV for $600 more (included 4 year square trade warranty). Its a HUGE upgrade in every conceivable way. The image is super bright even in ECO mode and even in 3D. The razor sharp ZERO-cross-talk 3D is a thing to behold.With 3010 I had to consciously ignore the layer of cross talk that corrupted the image in the background and double image in foreground. Now I can see endless amount of detail and perceive the amazing layering in many of the previous 3D movies. Even in 2D, if you tune it properly using something as simple as Disney WOW, the image quality is superb.
If the bulb costs on 3010 fall, I may buy one just to get the film-like image that I quite loved about 3010, but otherwise, I see no reason to go back to it.
falafala is offline
post #2017 of 2034 Old 01-23-2015, 09:41 AM
falafala's Avatar
Quoted: 23 Post(s)
Folks I also got to check out 3000 lumen Optoma HD141X which you can get on Amazon for ~550$. For just 250$ more than the stupid bulb cost of 3010 this DLP projector beats the crap out of 3010 in 2D, brightness, sharpness, picture quality and most importantly offers awesome 3D with ZERO crosstalk that does not degrade as bulb ages as in 3010. The only reason I prefer the more expensive HD25-LV are for the extra lumens it gives in 3D for my 150" screen. If you have smaller screens I would think 141x would be a great upgrade over 3010. I will NEVER EVER buy another LCD PJ after seeing what I have seen with these newer DLPs.
falafala is offline
post #2018 of 2034 Old 01-29-2015, 01:22 AM
mankhan's Avatar
falafala, you comments are duly noted with interest, however, I would like to ask that to please confirm that your DLP optoma, does deliver sharp picture images as of 3010 or not really. I really doubt that these DLP projectors can deliver sharp images otherwise what so hard for Panasonic or Epson to change their projection systems to DLP. Also one has to put DLP far back from the screen to get desire image size as compare to 3010? Is that correct. Also since 3010's lamp fades out with time, our eyes get used to of the dimmer image with time, if you just place the new lamp in 3010 its image will astonish you at once with brightness and sharpness together.
mankhan is offline
post #2019 of 2034 Old 01-29-2015, 11:28 AM
falafala's Avatar
Quoted: 23 Post(s)
If you laid your eyes on these DLPs, you will never look back. They offer laser sharp images which are super bright and most importantly zero cross talk 3D that LCDs cant come close. For example, on the test grid on 3010, the colors do not even line up while on DLP you see pure white lines which gives an amazing POP and sharpness to the images.
Also the throw ratio has nothing to do with DLP vs LCD. I loved the film like LCD look in 2D, no doubt, but in 3D the cross talk (even if everyone claims its minimal) is unacceptable and Epson is getting away with it only because 3D is only a small fraction of users. Also if someone is prone to rainbows in DLP, they would prefer LCD, so there is a market for that. If you are a 3D fan, DLP is the way to go for best bag for the buck offlate (not in 2011 when Epson was the king).
Sure I did consider plunking in $300 on 3010 bulb and I have no doubt the image brightness will impress me as it did when i bought it 3 years ago, but I am sick of the cross talk that degrades as bulb ages.
I highly recommend upgrading to DLP for just another 250-300$ more. You will thank me for that
falafala is offline
post #2020 of 2034 Old 01-31-2015, 11:56 AM
mankhan's Avatar
Thanks. So which DLP you are using now.
mankhan is offline
post #2021 of 2034 Old 01-31-2015, 01:45 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 91
I've got a 3010 and can honestly say that having viewed over 100 3d movies I've experienced cross talk one time. That was on a surfing movie set in Hawaii-can't recall the name of it. I have less than 1K hours on it so possibly it may develop the problem eventually.
I've recently picked up an Epson 5030ub and it's an excellent upgrade. Love the awesome blacks & razor sharpness, especially with Super Resolution. Still using the 3010 as well and it continues to be an excellent lower end pj.
JMHO
Ed
old corps is offline
post #2022 of 2034 Old 01-31-2015, 03:18 PM
falafala's Avatar
Quoted: 23 Post(s)
I am now settled with HD25LV (~$820)which puts out 3500 lumens of awesomeness in 2D and 3D on mt 150" in echo mode. In Bright mode, its blinding at night but worth it in day time.
I also recommend the cheaper 3000 lumen HD141x ($550) if you have a smaller screen as its brighter than 3010 but I found 3D to be darker than HD25LV for my screen.
old corps likes this.
falafala is offline
post #2023 of 2034 Old 01-31-2015, 03:18 PM
falafala's Avatar
Quoted: 23 Post(s)
JMHO
Ed
I envy you
falafala is offline
post #2024 of 2034 Old 02-03-2015, 04:23 AM
mankhan's Avatar
Can you please upload some screenshots of the best picture possible from your HD25LV
mankhan is offline
post #2025 of 2034 Old 02-05-2015, 02:55 PM
falafala's Avatar
Quoted: 23 Post(s)
I dont have a good camera. But will try to show a comparison of sharpness between DLP and LCD when I mount both.
falafala is offline
post #2026 of 2034 Old 02-11-2015, 01:11 AM
riddle's Avatar
Quoted: 12 Post(s)
Thats will be greate, thanks
riddle is offline
post #2027 of 2034 Old 02-11-2015, 01:28 AM
riddle's Avatar
Quoted: 12 Post(s)
I have offer from one guy for PT-AT 5000E for price cca 900 EURO with 1000 hour on lamp and still 6 months in warranty. What you thinks? Its bether choice than upgrade for HD36/151x from Home Cinema 3010/EH-TW6000.
riddle is offline
post #2028 of 2034 Old 03-30-2015, 11:11 AM
Liked: 0
I have the 3010 and looks very sharp in the center, but going to the sides,looks a little soft. I dont have a edge to edge full focus and im tired of people saying that issue is not noticeable in video and only in text....so whats the meaning of full hd? a focus loss is the worst enemy for HD. I want to open my pj and take out the lens, i see some holes around the lens that maybe can focus the left and right of the image better, but im affraid of getting it worse. If anyone wants HQ pics of the pj opened, i have some.
I just need some optic help, maybe we can fix this problem instead of returning it and receive another with worst focus, even the 5020 have some problems with that.
Daniel Ramirez is offline
post #2029 of 2034 Old 12-17-2015, 10:58 PM
Liked: 0
PowerLite 3010 / EH-TW6000W Keystone Problems
Hello to everyone. I am new to the forum so forgive me if this posting is on the wrong place.
I have an Epson EH-TW6000W (it is the European version of PowerLite 3010) three years old only 263 hours on the lamp, so you understand that it is rarely used. Suddenly 15 days ago the manual "H-Keystone slider" stopped working , and the H-keystone slips to +55 by itself. When I try to correct the H-Keystone manually from either the remote control or the control buttons on top of the projector to it returns by itself back to +55.
When I set the automatic H-keystone to OFF from the menu I continuously get a message on the Screen "This Operation cannot be performed. Please set the automatic H-keystone to ON". I reset the settings of the projector from the menu and still the same.
I took the projector to an Epson authorized repair center and told me I need a new optical engine!!! which costs more than the projector. However I do not think (or do not want to believe) that this is the situation.
Any ideas, anyone had this problem before?
Chris MC is offline
post #2030 of 2034 Old 06-15-2016, 02:22 AM
Quoted: 353 Post(s)
Liked: 131
I've put around 13,000 hours on my Epson 3010 so far and it has developed a blue green cast on the left side of the image. It has had this for a while now but normally it would go away after about 15 or 20 minutes. It seems to be getting worse, a blue tinge remains in the upper left corner and a green tinge is left on the lower left corner even after it has been on for hours. Anyone know the cause of this or how to fix it?
post #2031 of 2034 Old 06-16-2016, 05:30 AM
financeguy89's Avatar
How many hours are on your current lamp? If it's fairly new and your still having the problem, it's probably time to get a differing unit. I sold mine last year and bought a BenQ 1085st and absolutely love it! I'm throwing a 180" image and there is no crosstalk/ghosting whatsoever when we watch 3d. It's the most amazing home theatre experience and pretty much trumps the image at every theatre I've been to since setting it up except for the Imax Laser experience I had at the Imax theatre in Branson, MO.
financeguy89 is offline
post #2032 of 2034 Old 06-16-2016, 06:23 AM
Quoted: 353 Post(s)
Liked: 131
I have about 2,500 hours on this bulb, and a new one in my closet. I am trying to hold off until these bulbs are exhausted before I get a new one. It is not too distracting, and I can probably live with it as long as it doesn't get much worse.
I have a Qumi that I use for portable and bedroom watching from time to time. I'm kinda hoping for something with laser or led to come out that is affordable with decent output and quality for my next upgrade.
post #2033 of 2034 Old 06-16-2016, 06:48 AM
I would be doing the same thing if you still own one more bulb. As you can probably tell, this thread is pretty much dead so there just isn't a whole lot of response. Hopefully someone else has experienced a similar problem and found a solution. If I were you, I would at least try swapping out the bulbs and see if it makes a difference. If it doesn't, then you know for sure it's a problem with your unit. Keep me posted. I'm curious to hear how it goes. It seems like the LED and Laser stuff isn't being adapted at companies like Epson, BenQ, Optoma etc.. I'm hoping my current unit will hold up till BenQ offers a 4k PJ for around $1k. My BenQ 1085st was a refurb that I snatched from the factory for only $750 and the color just blows me away. I'm also running a Darbee which basically takes it in the direction of 4k. With content that is high res, the detail with the darbee on a 180" screen is mind blowing. It will be interesting to see if the projector manufacturers in the $1k-$2k move toward LED or Laser in the move towards 4k. I'm surprised that JVC hasn't offered a true 4k PJ yet. They should start coming out pretty soon by companies other than Sony. Best of luck with your issues.
post #2034 of 2034 Old 08-31-2017, 04:06 AM
pege36's Avatar
Have any one found a firmware update for this projector?
pege36 is offline
Epson , Epson Powerlite Home Cinema 3010e Full Hd 1080p 2d And 3d Home Theater Projector With Integrated Spe , Projectors
