Solid Horizontal Lines on Optoma DS303 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-01-2011, 07:56 AM - Thread Starter
jordoborg's Avatar
For the past couple of weeks, I've been having solid, coloured horizontal lines displayed from my projector. This occurs whether I have an input cable inserted to the projector or not. I've also tried different power outlets in case it was an interference issue, although the lines aren't scrolling, so I don't think that's the case anyway. The lines appear immediately upon starting the projector although the intensity of the lines varies. I've tried reseating the bulb assembly, but no changes to the projection. Here is a picture of the issue:
http://imageshack.us/photo/my-images/197/optoma.jpg/
Any suggestions?
jordoborg is offline
post #2 of 3 Old 11-01-2011, 08:19 AM
checklst's Avatar
Looks like a electronic problem......you are correct by allowing the start up screen to project without cables attached.....this screen tell a PJ company if they have an internal electronic problem.
Hopefully you are still under warranty.....Good luck
checklst is offline
post #3 of 3 Old 11-01-2011, 10:00 AM - Thread Starter
jordoborg's Avatar
No warranty.
