which LED project to pick? Acer K330 or Optoma or Viewsonic? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 11-10-2011, 10:09 AM - Thread Starter
seph22's Avatar
Can someone update me please i been away for a while, Since these projectors got released and available in the market
Which one is the one to Get?
Was the K330 audio out port removed or is it still there? I'm thinking of getting ACER K330 or should i get another projector? any feedback is appreciated.
seph22 is offline
post #2 of 33 Old 11-10-2011, 10:16 AM
HenryDudley's Avatar
The Acer has audio out.
They're all essentially the same projector. I would just get whatever is cheapest. I only have the Acer so if there's no real price difference, I would say the Acer.
Oh, and I forgot the mandatory these projectors are noisy warning.
HenryDudley is offline
post #3 of 33 Old 11-10-2011, 10:19 AM - Thread Starter
seph22's Avatar
So other than being loud noisy projectors is there any major cons? I don't want to buy one and regret it later :P
What about image quality (Brightness/CA etc) and focus issues of the acer ?
I'm leaning toward the acer right now due the Audio out port and being the cheapest one, it's available in amazon USA right now for 599$
http://www.amazon.com/Acer-K330-WXGA...0948153&sr=8-4
seph22 is offline
post #4 of 33 Old 11-10-2011, 11:45 AM
pshosh's Avatar
HenryDudley, would you rate the clones above the QUMI in picture quality and in general overall? And have you seen the Dell M110? How does it compare to the other sub-$700 LED pjs out there?
pshosh is offline
post #5 of 33 Old 11-11-2011, 01:24 AM
Amber Ale's Avatar
k330 doesn't have the warm up focus problem, but read this topic.
edit:
also in the k330 topic.
Originally Posted by tataniko View Post
Check optoma thread at page 15.
I am big Qumi fan, and I have experience more than 200 led hours with her, also I created Qumi article in wiki, but K330 is much better for home entertainment system than Qumi.
Edit2: Just checked prices for the k330, to high (6-700) $$$ in my opinion. Hope they come down. The k11 is down to $300 in some places.
Amber Ale is offline
post #6 of 33 Old 11-11-2011, 03:56 AM - Thread Starter
seph22's Avatar
edit:
K330 is 599$ in the amazon USA link i posted above
seph22 is offline
post #7 of 33 Old 11-11-2011, 06:28 AM
eat meat's Avatar
the acer has been reported to have the same warm up problem.
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #8 of 33 Old 11-11-2011, 10:01 AM
I thikn the Qumi has a slightly better image, but I would still choose the Acer.
Not like the Qumi, no, but the focus certainly does change on mine. I think it is extremely dependant on the environment. In my case it's noticable warming up from <68 degrees.
It's worth keeping in mind that tataniko is essentially a volunteer Acer marketing bot who rates it 11/10 and considers it the best thing on earth even though it has a fair share of problems. Noisy, light leakage (if you care)/not that dark blacks, heavy CA, noisy, slight RBE, the built-in media player is unable to play pretty much all HD content found online, noisy, the speaker is fairly mediocre (but what can you expect) and so on. I still like it though. Overall it's maybe a 6/10, but you can't really find anything comparable that does much better.
post #9 of 33 Old 11-11-2011, 12:30 PM
oriel's Avatar
HenryDudley;21199512]I thikn the Qumi has a slightly better image, but I would still choose the Acer.
what makes you think the Qumi has slightly better image? the Acer would have to look like crap compared to the LG HW300Y
Vivitek Qumi vs. LG HW300Y
http://www.youtube.com/watch?v=YCYzu6IhbSc
Acer K330 vs LG HW300
http://www.youtube.com/watch?v=0-BKQAhMfA8
oriel is offline
post #10 of 33 Old 11-11-2011, 01:40 PM - Thread Starter
seph22's Avatar
So basically all the 500lumen LED are **** with focus problems, noisy as hell, CA issues, etc
Seems like I'll save money money and ignore them until LED projectors get it right.
I thought Acer k330 had no focus issues :/
seph22 is offline
post #11 of 33 Old 11-11-2011, 01:46 PM
The videos are worthless. It's close to impossible to show what the projector actually looks like through a Youtube video and even harder to do a comparison. When the videos are as poorly done as the ones linked, you might as well just watch dancing hamsters or sneezing pandas instead. But based purely on them the Qumi wins in the first because you can actually make out details and not just a bright white light that washes everything out, and the LG in the second because the Acer gets the color completely wrong and is very oversaturated.
post #12 of 33 Old 11-11-2011, 02:01 PM
It's not an actual problem. It takes a couple of minutes here, so there's no need for any refocusing. Based on your environment it might not even manifest itself at all. The CA... okay, it's not very good, but I don't notice it on video. I can easily see it when browsing the web or doing other things with static graphics (especially straight lines), but I don't do that. As far as noise levels are concerned, yeah they are noisy. It's not something you'd put on your table for some casual TV watching like in the marketing brochures. Put it under a table or something though and crank up the sound a little and it's not a problem.
As for waiting, it depends on what you're looking for... Is it the right choice for the videophile to put in his home theater together with his $1000 screen? Probably not. The casual normal user though, who wants something that isn't fixed and that can just be whipped out wherever and whenever he wants to watch something, it's not bad. The only con is the noise.
I guess in a way with the LED projectors you're paying a premium for the technology and not necessarily the quality you might expect for the price range.
post #13 of 33 Old 11-11-2011, 03:20 PM
pshosh's Avatar
And the Qumi is much quieter?
pshosh is offline
post #14 of 33 Old 11-11-2011, 03:51 PM - Thread Starter
seph22's Avatar
The casual consumers appeal for these projectors is the fact you get big screen for small price, but things changed
People in the past had to chose between 4000$ 50inch 720p HDTV vs 1000$ projector
Now it's for 700$~ you get one of those
50Inch 1080p HDTV with great IQ/no side issues VS
70-90inch 720p with average IQ and lot of issues that annoys people.
And you don't get noisy sounds, no CA, no focus change, no lack of inputs/outputs/bad black levels/lack of brightness at daytime/bad IQ (CA/blur/focus uniformity/etc)/etc by going with HDTV instead of those awful projectors
lol i know it sounds like ranting but I'm not, My point is only HDTV are getting bigger and cheaper as we speak while projectors are going backward with ton of issues that shouldn't exist in the first place (seems like they are trying to make quick money only) while resolution is lower (you need the high resolution for a big screen)/not bright enough to support really "big" screen which is the advantage of the projectors
seph22 is offline
post #15 of 33 Old 11-11-2011, 04:34 PM
oriel's Avatar
I more ore less agree about being worthless, but the same could said about guesses and personal opinions unless someone owns both projectors, and then you cant even be sure. anyway anyone looking for a dedicated movie projector would be better of looking elsewhere, and not get fooled by the long led life. the new dell looks promising and 32db in eco will make you feel so good when you turn it off
oriel is offline
post #16 of 33 Old 11-11-2011, 05:06 PM
jeffers7's Avatar
Been lurking a lil bit the past couple of days, trying to weigh up if i want a projector (live in a bedsit, but bed has its headboard against the wall the couch faces, so was thinking projector so can just turn and project it on whichever wall suits best). It worth getting one of these LED projectors then (e.g. do the bugs/issues just not make it worth it)? or any imminent upcoming ones that will fix these bugs? mainly attracted by the fact not having to replace bulb, as this would be in lieu of a TV (can live without either though ). sort of up to ~£500 spend
(tacked my thing onto here as was same topic, opposed to making new, will probably revert to lurking now)
jeffers7 is offline
post #17 of 33 Old 11-11-2011, 06:35 PM
oriel's Avatar
do you call Pianos Transport when you want to move your TV that would be
one reason why I prefer projectors "not these noisy picos,,.
if it wasn't for the size and weight of these TVs then again I actually prefer
smaller screens for casual Tv viewing Big all the time would drive me
so a projector is more ideal for me, and there is still a long way from 80inch
to my 150inch. looking outside my own needs I am sure you are right
oriel is offline
post #18 of 33 Old 11-11-2011, 07:35 PM
eat meat's Avatar
what picos have you owned that you thought were to loud?
(fifth element)
eat meat is offline
post #19 of 33 Old 11-12-2011, 02:56 AM
Amber Ale's Avatar
It's Tiger direct selling through Amazon, but if you buy from TD you can get the projector and a Universal Projector Mount.
td link
post #20 of 33 Old 11-12-2011, 04:51 AM - Thread Starter
seph22's Avatar
HDTVs are improving though, those new LED projectors are slim and light as hell, and when you hang them on a wall they pretty much take no space.
seph22 is offline
post #21 of 33 Old 11-12-2011, 07:37 AM
oriel's Avatar
only the LG HX300g which was fairly quiet compeered to these new models.
had a defective Infocus x9 I could only use in normal mode 30db and it was
annoyingly loud. the specks tels me these picos are noisy, you can almost tell by looking at them, its like they where designed to look cool above anything else
a tiny high pitch fan defeats my idea of a movie projector. tell me you dont find
them noisy, and I cant ague. what we consider noisy is fairly subjective
oriel is offline
post #22 of 33 Old 11-12-2011, 08:17 AM
oriel's Avatar
I was trying to say something like that
oriel is offline
post #23 of 33 Old 11-12-2011, 11:46 PM
tataniko's Avatar
There are three types of new generation LED projectors:
Pico 10-80 lumens
Pocket 100-300 lumens
Portable 350-500 lumens
It is not easy to direct compare different types and forms factor projectors.
I have experience about Pocket projector Vivitek Qumi, and Portable projector Acer K330. Both have many issues, but I can live together them and don't bother me. Finally I kept Acer K330, because I wanted more lumens, bigger screen size, full remote and louder speaker, but overall I am very satisfied the new generation HD pico chipset projectors like Acer K330 and Vivitek Qumi.
tataniko is offline
post #24 of 33 Old 11-27-2011, 02:54 AM - Thread Starter
seph22's Avatar
bought the Acer K330 New online for 399$ as a deal @blackfriday
I will list my impressions here when i receive mine
Anyway its price got lowered too amazon atm is selling it for 499$ and QUMI for 399$
Good to see prices dropping because at the previous prices it was not worth it atm (the MSRB of 600-700$ was overpriced, 400-500 MAX where they should have launched at)
seph22 is offline
post #25 of 33 Old 11-27-2011, 07:04 AM
maelstromm's Avatar
Where did you get it for 399?
maelstromm is offline
post #26 of 33 Old 11-27-2011, 10:11 AM
Strife18's Avatar
I'm in the same boat as the original poster. I am between the Qumi or...whatever I hear is best of the clones. Sounds like its the Acer. However I am in Canada and haven't found the Acer for under $600-700 here. Where I can get the Qumi for $399.
So I am at a loss. Any suggestions. It's for playing movies and xbox 360 while im on the road for work.
Strife18 is offline
post #27 of 33 Old 02-16-2012, 11:00 PM
zook09's Avatar
has any of u have any info on the Dell M110 ? the reviews in general are very few.
zook09 is offline
post #28 of 33 Old 02-18-2012, 12:11 PM
fiocco's Avatar
Viewsonic it better, better color, remote and quieter.
fiocco is offline
post #29 of 33 Old 02-19-2012, 08:32 PM
Jeff J's Avatar
did you see the projector central review? review highlights the lack or a color control and "neon" looking colors.
http://www.projectorcentral.com/dell...?page=Overview
Jeff J is offline
post #30 of 33 Old 02-19-2012, 09:40 PM
zook09's Avatar
thanks Jeff !
[quote=Jeff J;21670412]did you see the projector central review? review highlights the lack or a color control and "neon" looking colors.
zook09 is offline
taboola here
