Epson 3010 glasses - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 367 Old 04-24-2012, 02:31 PM
xhonzi's Avatar
Quoted: 30 Post(s)
Does Epson use the same synch pattern as Panasonic?
xhonzi is offline
post #302 of 367 Old 04-24-2012, 03:19 PM
falafala's Avatar
Quoted: 23 Post(s)
Originally Posted by gustavoya View Post
Based in this post I made some research and I come across this paper with research on 3D IR protocols, since the 3D glasses from samsung are really cheap($15 a pair) many people, like me could benefit if someone with electronic knowledge could make a device to change the protocol from Epson to Samsung. I'm attaching the link to the paper and the two extracts of the protocols.
http://cmst.curtin.edu.au/local/docs...3D-Sync-IR.pdf
[img=http://s16.postimage.org/q6dktyhht/panasonic.jpg]
[img=http://s16.postimage.org/gkolrefpt/samsung_2010_protocol.jpg]
these guys already built a universal IR emitter for thier paper...what the hell is stopping them from making millions selling it ?
falafala is offline
post #303 of 367 Old 04-30-2012, 07:18 PM
ulvy's Avatar
Originally Posted by mflanagan View Post
Does anyone know where to get Extra Monster Glasses without having to buy the whole kit? I need a couple more.... Seems like a waste of money to keep buying kits with one pair of glasses in it.
Thx
Flan
My local Bestbuy has 3 sets that are on clearance for $79. These are not the kits. The kit was on sale for $99.
ulvy is offline
post #304 of 367 Old 05-02-2012, 08:07 PM
Thupdhon's Avatar
Ps3 3d glasses on sale at Canadian best buy for $49.90
Thupdhon is offline
post #305 of 367 Old 05-05-2012, 08:40 AM
ntk1's Avatar
hello
someone know if this glasses works with the epson 5010
http://www.monsterproducts.com/produ...n=5938&id=9132
thanks
ntk1 is offline
post #306 of 367 Old 05-05-2012, 03:09 PM
riddle's Avatar
Quoted: 12 Post(s)
yes will works
riddle is offline
post #307 of 367 Old 05-09-2012, 10:11 AM
financethis's Avatar
is there anything special i have to do to make the sony ps3 glasses work with my epson 3010?
also i can use these ps3 glasses with my other 2 epson glasses at the same time too right?
epson 3010 projector
marantz 1402 avr
infinity beta mains, center and surrounds
110" dalite screen
tc sounds pro 5100 subwoofers
financethis is offline
post #308 of 367 Old 05-09-2012, 11:29 AM
xhonzi's Avatar
Quoted: 30 Post(s)
The PS3 glasses will synch to the IR signal the 3010 is already sending to your Epson glasses.
The only thing you need to do to get them to work is turn them on.
xhonzi is offline
post #309 of 367 Old 05-09-2012, 12:09 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
+1!
CORRECT!
Ed
old corps is offline
post #310 of 367 Old 05-11-2012, 04:39 AM
mankhan's Avatar
Originally Posted by ntk1 View Post
hello
thanks
Monster glasses works fine and not better then Epson glasses but same. Epson glasses are fully tuned as well to their best. I have monster and at the brightness level acceptable they both work same.
mankhan is offline
post #311 of 367 Old 05-28-2012, 10:04 AM
ntk1's Avatar
but the epson cost more
ntk1 is offline
post #312 of 367 Old 05-29-2012, 09:25 AM
xhonzi's Avatar
Quoted: 30 Post(s)
Well... the two pair of Epsons I have were "free".
xhonzi is offline
post #313 of 367 Old 06-07-2012, 09:32 AM
klointheridge's Avatar
N00b here. I just installed an Epson 6010 and have the Monster Vision 3D glasses. How do I pair them to work with my projector? Sorry if this has been answered...but I haven't found it yet.
klointheridge is offline
post #314 of 367 Old 06-07-2012, 09:56 AM
xhonzi's Avatar
Quoted: 30 Post(s)
I don't have the Monsters myself, but this is my understanding:
The monsters have an adapter that has an IR receiver. Your 6010 should have an IR emitter on the front around the lens, and somewhere on the back. If you place the IR receiver of the adapter in view of the IR emitter on the back of the 6010, it should send a synch signal to your Monster glasses. There's a little joystick on the adapter that will allow you to tune duty cycle (how long each lens is open) so that you can adjust the brightness/crosstalk tradeoff.
Hope that helps.
xhonzi is offline
post #315 of 367 Old 06-07-2012, 11:10 AM
Never mind. I finally found the online user guide and found where the IR blaster was receiving a strong enough signal. Kinda was hoping not to have to use that as I now have to figure out how to hide the wires and blaster for a clean install.
post #316 of 367 Old 06-07-2012, 11:18 AM
Hope that helps.
Thank you! It does indeed as now I'll see if there is an IR emitter on the back too.
post #317 of 367 Old 06-09-2012, 05:08 PM
dbox1080p's Avatar
I bought the Epson glasses and they arrived 2 days before my 5010 is to come on Monday. I have a mr potato head and the epsons are very loose. Am I now to assume that whatever oher glasses I get will have a lesser image quality ?
Why wouldn't the monster glasses be the best if they have more light coming through ?
dbox1080p is offline
post #318 of 367 Old 06-09-2012, 06:42 PM
Rigby Reardon's Avatar
Did you notice that the arms are adjustable? There are two little switches on the inner sides, which can be used to lock the arms in a narrower position.
No.
Rigby Reardon is offline
post #319 of 367 Old 06-10-2012, 10:09 AM
teeger's Avatar
Liked: 33
I just bought another pair (now have 2) of the Sony PlayStation glasses. Although my projector doesn't exhibit very much cross-talk at all, I have to admit that by comparing the Epson glasses with the Sony PlayStation glasses that the Sony's reduce crosstalk (at least with my 3010) better than the original Epson glasses.
I really like the fact that the Sony's are rechargeable - but I guess the glasses (sadly) are disposable once the lithium-ion internal battery wears out. The instructions suggest that the battery is "non-replaceable", which sucks. Does anyone know if the Panasonic (or other compatible brands) have internal batteries that can be replaced when / if needed?
The PlayStation glasses work every bit was well as my Epson glasses ... the color temp. of these glasses is a touch warmer and maybe the glasses are just a tiny bit darker also. You'd be hard pressed to see this unless doing very careful A / B comparisons. This isn't a drawback to me . . . it's simply the characteristic of the manufacturing from one maker vs. another. Both the Epson and Sony are great. When I managed to pick up both pairs for $39.95 each, I certainly couldn't complain.
Ian
teeger is offline
post #320 of 367 Old 06-10-2012, 05:24 PM
dbox1080p's Avatar
I just bought 5 pairs of sony glasses so its good to hear your enjoying them teeger
post #321 of 367 Old 06-11-2012, 08:52 AM
FreyTheater's Avatar
Ian
This was a big reason why I decided to go with the OEM Epson glasses for my 5010 instead of rechargable glasses - in the rechargeables, once the Lithium battery wears out, shorts out, or otherwise fails (which it eventually will), the battery can't easily be replaced, if at all... btw, the Panasonics are rechargeable as well. I purchased 6 pair of the Epson 3D glasses so far, and hoping to pickup 2 more pair yet. I purchased a bulk lot of 50 Sony batteries on eBay for just $18.00 (the name-brands do have a history of having longer life than a lot of the lesser brands), so those batteries should last me for quite awhile, with a 10 year shelf life... I've had my projector and the glasses since February and have used them for 3D quite a bit, and am still on all of the original batteries; I believe they are supposed to last for approx. 80 hours (40 movies!) per battery...
FEEL an awesome 3D Blu-ray movie in the Frey Theater - Now with projection in glorious "FREYMAX" 3D!
FreyTheater is offline
post #322 of 367 Old 06-11-2012, 10:20 AM
xhonzi's Avatar
Quoted: 30 Post(s)
My "Dollar Tree" stores carry three packs of 2032 batteries for a dollar. If you want to stock up on some additional batteries for cheap. They're Sunbeam brand. Just a little cheaper than 50 for $18, but you also don't have to buy 50 at a time. wink.gif
xhonzi is offline
post #323 of 367 Old 06-11-2012, 07:27 PM
srenjith's Avatar
Hi All,
Pls let know whether this PS3 model glasses work with EPSON 3010.
http://www.amazon.com/Sony-TDG-BR250-Rechargeable-Adult-Glasses/dp/B004U5QE4W/ref=pd_rhf_dp_shvl1
Thanks in advance.
RENJITH,
India.
srenjith is offline
post #324 of 367 Old 06-11-2012, 07:31 PM
teeger's Avatar
Liked: 33
No, I doubt those Sony's will work with you Epson. Here is a link that shows the ones, that work, which I have.
http://www.amazon.com/Sony-98079-PlayStation-3D-Glasses/dp/B00562O8U0/ref=pd_cp_e_1
Ian
teeger is offline
post #325 of 367 Old 06-11-2012, 07:52 PM
srenjith's Avatar
Ian
Thanks Ian, but those are not avilable in India...Only this models are available and costs around 40$...
srenjith is offline
post #326 of 367 Old 06-16-2012, 12:23 PM
dbox1080p's Avatar
I cant believe how uncomfortable the sony ps3 glasses are on the nose and head uhggggg. I bought 9 pairs total
post #327 of 367 Old 06-18-2012, 09:15 AM
stevedawg85's Avatar
Quoted: 30 Post(s)
So my 3010 is coming in this Friday and I want to be ready for 3d content... but am I?
I have some files on my PC that are SBS. I have the Radeon HD 5550 Video Card which advertises it as "stereoscopic" 3d. Is this the real/good stuff :P? Can I use the included active shutter glasses on these SBS movies I have and get the full experience?
stevedawg85 is offline
post #328 of 367 Old 06-18-2012, 09:49 AM
xhonzi's Avatar
Quoted: 30 Post(s)
I would call SBS files "not the full experience". For basically 2-3 reasons-
1. SBS-50% format have half the horizontal resolution of either 2D or "good" 3D. Both left+right pics are squeezed into a single frame.
2. It probably doesn't contain the original HD audio.
3. It's probably pirated content, right?
It won't look as good and it won't sound as good.
xhonzi is offline
post #329 of 367 Old 06-18-2012, 09:50 AM
xhonzi's Avatar
Quoted: 30 Post(s)
I, with my man sized head, find them uncomfortable too. My wife and kids seem to have no complaints.
xhonzi is offline
post #330 of 367 Old 06-18-2012, 10:16 AM
Quoted: 30 Post(s)
err, no coment :P...
thanks for the info though! I'll make sure to do a 3d blu ray to get the full effect. But for the time being, this will be as good as it gets huh? I just want to make sure this isn't one of those, converting 2d to 3d, or just as good/bad as using red/blue glasses as an alternate to active shutter glasses.
Epson , Panasonic , Panasonic Ty Ew3d2mmk2 Ultimate 3d Starter Kit Avatar 3d 2 Rechargeable Glasses , Mitsubishi , Nvidia , Samsung , Samsung Ssg 4100gb 3d Active Glasses 2012 Model , Mitsubishi 3dgx103 Xpand 3d Glass Black
