Acer K330 and Optoma 3D Xl Box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-30-2011, 10:51 AM - Thread Starter
Paddo5819's Avatar
Short question: Does the Acer K330 work with Optoma 3D Xl Box?
My Acer K330 says on HDMI Input with connectet 3D Box "Input not supported"
And now????
Paddo5819 is offline
post #2 of 9 Old 11-30-2011, 03:44 PM
Sisyphus's Avatar
Probably not, as the 3DXL won't work with the Viewsonic PLED-W500, which is basically the same projector as the Acer K330.
However, there is another 3D processor, the Viewsonic VP3D1, that does work with the Viewsonic PLED-W500, so it will probably work with the Acer K330 as well. Keep in mind this hasn't been verified.
Sisyphus is offline
post #3 of 9 Old 11-30-2011, 04:14 PM
JOHNnDENVER's Avatar
Uhhhh.. This is not even a 3D projector right?
JOHNnDENVER is offline
post #4 of 9 Old 11-30-2011, 05:30 PM
eat meat's Avatar
yes its a 3d pj(all the clones are) ,as far as I know they will only do 1024x768 ,caped there for some reason.
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #5 of 9 Old 12-01-2011, 10:31 AM
I pulled it's specs up. I seen no mention of 3D support at all.
But even if it is 3D? The light output is to low for 3D use.
post #6 of 9 Old 12-01-2011, 10:39 AM
eat meat's Avatar
http://www.projectorcentral.com/Acer-K330.htm
3D Projector: PC 3D Ready
Comments: The Acer K330 takes advantage of the latest technologies. When paired with a computer supporting 120Hz output and 3D software along with 3D glasses, the Acer K330 can project 3D content to give entertainment an incredible boost
(fifth element)
eat meat is offline
post #7 of 9 Old 12-01-2011, 11:06 AM
There is no mention of it on Acer's site, nor Amazon's site for the projector.
If it took 3D at 720p 120hz then it should be working with the 3DXL. It must only take 3D at some other resolution / frame rate.
post #8 of 9 Old 01-12-2012, 03:36 AM
punguy's Avatar
did anyone tried yet?
punguy is offline
post #9 of 9 Old 01-13-2012, 09:28 AM
From above
"as far as I know they will only do 1024x768"
This will NOT work with the 3DXL, has to take 3D at 720p 120hz.
