Official Epson PowerLite Home Cinema 5010 / 6010 thread - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #3061 of 3675 Old 06-05-2013, 08:46 AM
Patzig's Avatar
Quoted: 136 Post(s)
Liked: 275
Well, I received my first 5010-R from VisualApex. PQ seems awesome and 3D is cool. I came from a DLP Optoma HD20...so the change over to LCD is interesting. The black levels and color depth are no doubt better on the 5010. But one weird thing I've noticed: In a still scene of a movie, with very slow movement in it...sometimes i notice an "anomaly" where colors seems to shift around with each other. Really hard to explain, but looking at a sweater on a chick with a detailed pattern or different colors...the red and blue colors almost seemed to dance around with the white on the sweater. I don't know, maybe I'm crazy. Everything default on projector, no iris, no 3d, no frame interpolation, no super resolution. BTW, I've read through pages 80-103 and couldn't find anything on this.
EDIT: I have messed around with the LCD alignment, but have not "perfected" my convergence yet. Is it possible that my current bad convergence is causing this?
Patzig is offline
post #3062 of 3675 Old 06-05-2013, 02:53 PM
jnabq's Avatar
Liked: 39
Not sure if the artifacts are a result of the convergence, guess it might could attribute? Are you seeing this on a good bluray image? There are some links and links to discussions on the first post of this thread, concerning alignment, and look into the "pixel width" posts linked to there as well.
jnabq is offline
post #3063 of 3675 Old 06-05-2013, 02:56 PM
jnabq's Avatar
Liked: 39
Nice review Kraine, you might consider adding, the US equivalent model number in the description, ie. 3020, in future reviews. Makes it a little easier for someone to locate the review in a search.
jnabq is offline
post #3064 of 3675 Old 06-05-2013, 10:49 PM
nando820's Avatar
Quoted: 24 Post(s)
I have the 5010
The HDMI input 1 stopped working tonight. I turned on my system and all it displayed was no signal I disconnected the cable on the back of the projector and put it on HDMI 2 change inputs and the image came on. It's there a setting that would block an HDMI input or that's it, it just broke
nando820 is offline
post #3065 of 3675 Old 06-06-2013, 06:42 AM - Thread Starter
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
Originally Posted by nando820 View Post
I have the 5010
I do not believe so.
Are you connecting your player directly to the projector or through a receiver.
A quick check would be to connect the player directly to the projecter and see if HDMI1 works.
2016
42Plasmaman is offline
post #3066 of 3675 Old 06-06-2013, 07:06 AM
nando820's Avatar
Quoted: 24 Post(s)
Through a receiver but it outputs the video fine when connecting to HDMI 2, but I could give it a try..
nando820 is offline
post #3067 of 3675 Old 06-06-2013, 07:52 AM
Mr.G's Avatar
Quoted: 767 Post(s)
Liked: 442
I have the 5010
Electronics can sometimes benefit from a powered down/unplugged state which serves as a reset of sorts. Try leaving your 5010 unplugged for a few hours or overnight. This may revive the HDMI input - doesn't hurt to try.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3068 of 3675 Old 06-08-2013, 09:21 AM
datr's Avatar
I got my third unit (in as many weeks; two RMAs) the other day from visual apex and the internal 3D emitter doesn't work. Fantastic. I give up on the 5010. I'll have to look elsewhere.
datr is offline
post #3069 of 3675 Old 06-10-2013, 06:03 PM
BiTeZ's Avatar
Hi all, I'm trying to get my new 6010 set up and configured to my system. I am trying to get the best performance out of this projector and have reviewed to see if I can find anyone's calibration settings online with no luck. I would be open to suggestions for software I can buy and do it yourself if you have any recommendations.
In a nutshell I'm really after a couple of major items. First I will let you know I am running the video out to the projector from a Denon 4308CI using Monoprice redmere cables.
When I go to the "Info" screen in the "menu" of the projector, it says my input signal is component, and the resolution it is receiving is 480p. I can't understand why it is showing this when I have it connected to a HDMI cable, and should be getting a 1080p signal.
Any suggestions on how I can verify the quality of the video signal out the projector is displaying?
Thanks in advance.
BiTeZ is offline
post #3070 of 3675 Old 06-10-2013, 06:27 PM
drhankz's Avatar
Quoted: 95 Post(s)
Liked: 73
Thanks in advance.
TRY NO ADJUSTMENTS - It Work Fine Out-of-the-BOX
DavidK442 likes this.
drhankz is offline
post #3071 of 3675 Old 06-10-2013, 07:07 PM
erichoya's Avatar
What is the video source?
Epson 5010 with 110" Accuscreen. Yamaha rx-v773, HTPC with XBMC.
erichoya is offline
post #3072 of 3675 Old 06-11-2013, 06:20 AM
TboneofLA's Avatar
Thanks in advance.
I just got a 5010 but it's still sitting in the box so I can't comment on the calibration of it yet but but according to what I've read the cinema and natural modes are pretty good out of the box. That said I will still calibrate it using my EyeOne LT and Color HCFR software. The EyeOne was a little over $100 when I got it but here are probably newer meters available. Color HCFR is free.
Price is what you pay. Value is what you get.
TboneofLA is offline
post #3073 of 3675 Old 06-11-2013, 03:28 PM
BiTeZ's Avatar
The video source is a SHAW HD receiver Motorolla HD PVR 630.
This was a great question as I ended up looking deeper into the HD PVR and discovered that in the video settings menu that if you leave the video output set to HDMI then it will send a 480p signal, but you can override this and force the PVR to send a 1080i signal which has resolved my problem.
Now it's just a matter to tweaking the projector instead of ensuring the appropriate signal is being sent.
Thank-you.
BiTeZ is offline
post #3074 of 3675 Old 06-11-2013, 03:28 PM
BiTeZ's Avatar
Yes but I want to be able to confirm that I am at least am getting a high quality HD signal 1080p, not 480p.
BiTeZ is offline
post #3075 of 3675 Old 06-16-2013, 03:42 PM
SGinAZ's Avatar
Quoted: 22 Post(s)
So I had another hiccup with my third 5010 (2nd refurb). It periodically does the high fan speed startup before "rebooting" and the starting normally. The other night the fan spun up but the lamp never came on and the red lamp indicator started flashing. I turned off the projector and powered off the switch on the back. Tried again with the same results. I then shut it down, turned it off and pulled power. I opened it up and pulled out the lamp for inspection. Seeing nothing amiss I reseated it and turned it back on. That time it started right up and has subsequently restarted without issue... Gremlins....
When I got this model I was torn between a BenQ and the Epson... The 5010 is really trying to make me regret my choice....
SGinAZ is offline
post #3076 of 3675 Old 06-16-2013, 06:52 PM
nando820's Avatar
Quoted: 24 Post(s)
I been having the same issues lately where sometimes the lamp won't come up and the red light starts blinking. Turning off and on seems to fix it at times.... This along with the fact that the HDMI input 1 died its gonna force me to send it back and start the refurbished Epson cycle....
nando820 is offline
post #3077 of 3675 Old 06-17-2013, 12:23 AM
xplorar's Avatar
Quoted: 37 Post(s)
Has any of you 5010 owners have chance to compare picture quality with 5020? I bought 5010 just just before 5020 came out. Ever since 5020 came out, I can't shake the feeling that I am missing out on improvements because of my haste.
xplorar is offline
post #3078 of 3675 Old 06-17-2013, 05:06 AM
drhankz's Avatar
Quoted: 95 Post(s)
Liked: 73
NO DIFFERENCE - Even Epson claims - NO DIFFERENCE
drhankz is offline
post #3079 of 3675 Old 06-17-2013, 05:21 AM
JeffreyJonesBSME's Avatar
Liked: 36
That's not exactly true. Epson is claiming higher contrast ratio on the 5020.
5010: 200000:1
5020: 320000:1
Other than that, I don't really know.
Another difference is IR vs RF glasses.
"Engineers aren't boring people, we just get excited over boring things".
--Anon.
JeffreyJonesBSME is offline
post #3080 of 3675 Old 06-17-2013, 05:29 AM
drhankz's Avatar
Quoted: 95 Post(s)
Liked: 73
5010: 200000:1
5020: 320000:1
Human Eyes Can't Measure the Difference .
IR versus RF is just a transmission type. I use RF on my IR 5010.
drhankz is offline
post #3081 of 3675 Old 06-18-2013, 10:58 PM
xplorar's Avatar
Quoted: 37 Post(s)
Your observation about human eye not being able to make out the said Contrast Ratio difference is interesting (and comforting for us 5010 owners smile.gif). If possible, please explain further.
I don't care about IR Vs RF. IR is working fine for me. I also don't care about THX color modes. What I think I am missing out is -
1) Better Contrast Ratio (which may not be a factor as per drhankz)
2) Better 3D picture because of Auto-Iris
xplorar is offline
post #3082 of 3675 Old 06-19-2013, 10:31 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
That measurement is only theory. In real life your room will kill your contrast ratio, unless it is all black felt and you aren't in it.
Auto-Iris in 3D doesn't matter much because almost always you want maximum brightness. I do think there are shots where this would make a difference though.
Also there is the idea that 2.0 versions are usually better. Given all my troubles with the 5010 I would hope so anyway.
wnielsenbb is offline
post #3083 of 3675 Old 06-19-2013, 12:40 PM
ashyt16's Avatar
Quoted: 37 Post(s)
Has firmware 1.09 been made available yet?
ashyt16 is offline
post #3084 of 3675 Old 06-27-2013, 12:16 AM
wickedg8gt's Avatar
Quoted: 61 Post(s)
Liked: 26
Hey guys I have a question. I'm moving and have to downsize my current theater screen. I currently have a 134in Carada Criterion BW with my 5010 about 15ft away as is sitting area. In my new area the 5010 lens is only going to be 10 ft from screen as is the seating area. According to screen calculators with full zoom out I can only get about 103 inch screen and should have about 38fl brightness. I want to get another Carada screen but should I get a 1.0 gain ( Classic White) or 1.4 gain ( Brilliant White). Im not as knowledgeable on screens as where I live there aren't any theatre showrooms. Thanks for the help I appreciate it.
wickedg8gt is offline
post #3085 of 3675 Old 06-27-2013, 05:39 AM
Liked: 36
In my theaters, I've always had complete light control, so I've always had screen gain of 1.0-1.2
I'd consider the higher gain if you won't have light control.
I personally wouldn't pay a high premium for the higher gain.
Good luck.
--Anon.
post #3086 of 3675 Old 06-27-2013, 12:11 PM
wickedg8gt's Avatar
Quoted: 61 Post(s)
Liked: 26
Thanks. Its going to be completely light controlled because its in a basement.
post #3087 of 3675 Old 06-27-2013, 07:31 PM
jnabq's Avatar
Liked: 39
If your expecting around 38fl, then I wouldn't go no more than 1.0, maybe drop to .08, but 1.0 will give you a little boost for when the lamp starts to dim somewhat. FYI, movie theater is around 16fl.
But, I think that number at 38fl seems kinda high, according to Coderguys calc, www.eliteprojectorcalculator.com 10' throw, onto a 103" screen, in eco mode you should see about 20.1fl on a 1.0 gain, and 26.8 in high mode, before any lamp dimming. You might want to compare the numbers there. I think his lumen calc is pretty accurate.
jnabq is offline
post #3088 of 3675 Old 06-27-2013, 11:23 PM
wickedg8gt's Avatar
Quoted: 61 Post(s)
Liked: 26
Thanks for the help. I was using Projector Peoples calculator. But ill try doing some more comparisons.
post #3089 of 3675 Old 06-28-2013, 07:35 PM
BiTeZ's Avatar
I did a pixel alignment on my 6010 tonight as I noticed some of the lines are out of whack. Everything came into alignment quite nicely, however on the left of my screen when using the R/G/B pattern colour the bottom left corner is green instead of bluish white. I've made sure my blue and red lines are right where they should be, but no matter what cannot get the green to go away.
Does anyone have any idea what this might be related to?
Thanks for your help on this one!
BiTeZ is offline
post #3090 of 3675 Old 06-28-2013, 08:14 PM
jnabq's Avatar
Liked: 39
Might be related to the "smearing" that can occur with these pj's, due to the alignment software? My left side blue does it some. http://www.avsforum.com/t/1449027/epson-5020ub-owners-thread/750#post_23471072 About all you can do is get it as close as you can, as perfect alignment on a 3 lcd is almost impossible.
Also see the links in the first post in this thread regarding, the "pixel width" theory using the lcd alignment.
jnabq is offline
Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Pro Cinema 6010 Projector , Projectors , Epson Powerlite Home Cinema 8350 , Cpu Fan
