Official Epson PowerLite Home Cinema 5010 / 6010 thread - Page 120 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #3571 of 3675 Old 12-22-2015, 01:45 PM
jiggyk4's Avatar
New firmware
Hey guys im on my second 5010 and got the two red leds a yr ago and was able to fix with the 1.09 firmware but today it is happening again. Could someone send me the newest firmware for me to try? I was able to get it to come back on by hitting the side but now its broke again. Email jernst_5@hotmail.com if someone can thanks
jiggyk4 is offline
post #3572 of 3675 Old 12-22-2015, 01:58 PM
CheapB's Avatar
Quoted: 42 Post(s)
I have sent you an email with the latest firmware, but It is likely not going to help. I was in pretty much the same situation and fixed it with a firmware update and then a few months later I had to take the projector apart. It doesn't hurt update the firmware so by all means go ahead and do that. Next you want to check the reason for the red LED. you can connect your PC to the serial port on the back and see what error code it is throwing. You dont want to chase a CF issue if the real issue is a fan.. after this report back and we can discuss next steps. Let me know if you need help with connecting the PC and projector
CheapB is offline
post #3573 of 3675 Old 12-22-2015, 03:08 PM
jiggyk4's Avatar
Well I managed to get it working by smacking the side with my hand and it fired right up lol should I even mess with the firmware now lol
jiggyk4 is offline
post #3574 of 3675 Old 12-23-2015, 12:17 AM
CheapB's Avatar
Quoted: 42 Post(s)
Likely not a good idea to do this while the bulb is mounted. In any case - my guess is that you have a Cinema Filter with a clutch that is too tight. If it is acceptable to you that you never know if the projector will fire up or not you can continue the slapping process, but likely you are running a risk of the CF getting completely stuck or break a tooth of the gear. Again - before you do anything - make sure you are fixing the right problem by pulling the error code.
CheapB is offline
post #3575 of 3675 Old 12-23-2015, 03:53 AM
jiggyk4's Avatar
I agree next time i get the error i will see what the code is first i hate not knowing if it will work or not. I will let you know if it happens again thanks
jiggyk4 is offline
post #3576 of 3675 Old 12-29-2015, 10:38 PM
Liked: 0
6010 Shutting Down
I had my 6010 replaced under warranty 3 months ago. After 3 months of flawless performance, the refurbished replacement unit has started shutting down on its own after 5-10 minutes of operation. No red or orange light... Just the flashing blue for about 30 seconds while the fan runs to cool it. Then the lens covers move in place and the unit shuts off completely. Assuming I was sent a refurbished unit that had the most up to date firmware as of mid-August 2015, what else should I try?
Bimmer4me is offline
post #3577 of 3675 Old 12-30-2015, 12:11 AM
CheapB's Avatar
Quoted: 42 Post(s)
If you still have warranty I suggest to have it replaced. If not - you can obviously try new firmware if you are not on the latest. I would also remove the lamp and re-seat it. You can check the firmware version this way:
Press and hold the Menu button on the remote control or on the projector’s control panel for at least 8 seconds, then release
Within 4 seconds of releasing the Menu button: Press and release the ESC button twice, (Esc + Esc)
press right until you get to the versions screen
The row starting with P: should end with V110 or V111
CheapB is offline
post #3578 of 3675 Old 01-07-2016, 09:14 PM
Liked: 0
Thanks... I've got "P 4600496401WWV110"... so that's V110? Any need to update to V111 in this case?
I assume that even though I was sent a replacement unit in August, if the warranty on my original unit was to expire Nov/16 then my warranty is up...?
post #3579 of 3675 Old 01-07-2016, 10:12 PM
Liked: 0
Also, I swapped out the bulb for a new one and same thing: 10-15 minutes after start up the machine turns itself off/fan cools for a few moments and then off completely.
post #3580 of 3675 Old 01-09-2016, 10:04 AM
mactoast's Avatar
Hey everyone,
I bought my 6010 3.5 years ago and had to send back the first one with a failure in the first year. I got a reconditioned one that was better than the new one ever was.
Mine had basically worked great since then but I notice a lot of dust being pulled in around the lens area. You can see it all looking at the bright light just in front of the lens.
So, two questions. Is there a gasket in this area that may be missing or not seated properly? I am noticing some vertical smearing on my screen now. Its very faint but there.
Is there a benefit to taking the projector apart for some internal cleaning? Can you even get at anything without major disassembly? I don't want to make matters worse on a functioning projector.
Any feed back from people who have taken theirs apart would be great.
Thanks in advance.
mactoast is offline
post #3581 of 3675 Old 01-13-2016, 12:50 AM
xplorar's Avatar
Quoted: 37 Post(s)
Originally Posted by mactoast View Post
Hey everyone,
Thanks in advance.
I too have noticed dust inside lens of my 2 year old 5010 but it doesn't seem to be affecting the image quality. Maybe its affecting contrast a bit, I can't tell. Of late, I can see faint smudge on a corner on the screen when screen is completely dark. It isn't noticeable when picture is on. I have read that this may be dust on one of 3 LCD panels inside the lens assembly. No idea how to clean it. I read somewhere, that sucking air using a vacuum cleaner (after removing the paper filter) may push off such dust. Though it was risky, I did that. Unfortunately, it didn't make any difference either on dust inside lens or smudge on screen. No idea what else could be done,
xplorar is offline
post #3582 of 3675 Old 01-13-2016, 12:39 PM
CheapB's Avatar
Quoted: 42 Post(s)
Yes, that is v1.10. I forgot if you are under warranty - if so, get it replaced. If not - you can certainly try 1.11. I doubt it will help, but there is really no downside to trying. Since you are not getting any error messages it is likely not throwing an error code on the serial port, but it is worth a try to pull ERR? after it shuts down
CheapB is offline
post #3583 of 3675 Old 01-17-2016, 07:50 PM
Liked: 0
Epson 6010 power is shutting down on its own.
I recently had an issue with my over 3 year old Pro Cinema 6010 projector which was replaced as a warranty exception by Epson in early December 2015 by a refurbished 6010. First replacement #1 picture was perfect and it worked well for about 3 weeks until all of the sudden the unit just shut itself off just like i turned it off. After this started to occur at random timing on the first time, it shut down about 4 more times on the same day. Next day it auto shutdown about another 3 times at random intervals. Day 3 worked well while watching a movie and other shows. Then day 4 it started to shut down another 3 times. So i called Espon support (who has always been very nice and helpful) who suggested changing outlets which is hard to do with a ceiling mounted projector. Epson decided to send another replacement #2 which was received a few days later. Problem with this model was a small dust particle creating another small green dot on the screen which was the original problem with my first projector which worked fine for over 3 years and never shut itself down. So after speaking to Epson support again was advised they would not just "pull one off the shelf" but rather pull one and have their team test it all out. A few extra days later, replacement #3 arrived yesterday. All worked well first evening watching a movie and other shows with no problem and a great picture! So today while watching the football playoffs, projector #3 starting shutting down randomly again like replacement #1 . So i switched to other outlet and it did it again. So i switched out surge protector and it did it again. All in total today it probably shut down at least 6 times during two football games and some other shows....
I am at an end as to what may be the problem. I do plan on contacting Epson support again this week, but not sure what they will do other than send another unit.
Has anyone else seen similar issues with the 6010 models or refurb replacements? Any ideas of what the problem may be? I am guessing since Epson did the extra test on replacement #3 which was done on 1/14/16, that it should have the latest firmware. Appreciate any suggestions or comments.
rankat1 is offline
post #3584 of 3675 Old 01-17-2016, 07:51 PM
Liked: 0
Unhappy Epson 6010 Shutting Itself Off
rankat1 is offline
post #3585 of 3675 Old 01-17-2016, 08:59 PM
CheapB's Avatar
Quoted: 42 Post(s)
If you read the thread you will find other people with similar problems. I would try to bypass the surge protector all together as a test. Also you can see the procedure to test the newest firmware a few posts up. In any case it doesnt seem like Epson is doing a great job testing refurbs. This has been an issue for years and crazy that they are not getting that under control.
CheapB is offline
post #3586 of 3675 Old 01-23-2016, 09:00 AM
Liked: 0
You need an usb to RS232 cable - not sure which will work on a MAC ten you need a terminal emulation program that supports serial ports - I am using Putty on Windows. this list is a bit dated by hopefully that can be used as inspiration. http://lifehacker.com/5857046/the-be...r-for-mac-os-x The projector will respond with a ":" when you are properly connected and hit enter
Thanks just ordered the cable. So since my last post everything has seemed to be working fine didn't shut off once. Then last weekend I was watching playoff football no issues, switched to AppleTv watched a few fights on the undercard during half time and then back to cable. About an hour or so later it shut off.
Will I be able to look at the errors of the past or do I have to connect right after the issue happens?
Thanks in advance
jrasch12 is offline
post #3587 of 3675 Old 01-23-2016, 09:31 AM
CheapB's Avatar
Quoted: 42 Post(s)
Thanks in advance
I am not aware of an error log, so only when it throws the error and goes in standby. Your situation is a bit strange as you get no red leds. Are you using a surge protector?
CheapB is offline
post #3588 of 3675 Old 01-24-2016, 07:59 AM
Liked: 0
I am not using a surge protector, and have not since I have owned it.
So as soon as it shuts down plug the computer into the projector? Is there a video on using the terminal to check the error?
Will look to get this done next weekend once I get the cable and I think i will need to watch something for 2hrs on apple TV then switch to cable and hopefully it triggers in an hour, so I can test.
jrasch12 is offline
post #3589 of 3675 Old 01-24-2016, 02:41 PM
CheapB's Avatar
Quoted: 42 Post(s)
There is a really bad video here.
just try w/o an error and it should return : when ready and a ERR0 if everything is ok
CheapB is offline
post #3590 of 3675 Old 02-08-2016, 08:20 PM
KevinYee's Avatar
I'm on my 3rd 5010. The current replacement one has been running for over a year. Wouldn't you know it, on the day that I'm hosting a Superbowl viewing party at my house, it suffers the dreaded red light of death. It died midway thru the 3rd quarter. I hate this damn projector.
KevinYee is offline
post #3591 of 3675 Old 02-10-2016, 01:44 PM
KevinYee's Avatar
I called Epson tech support, and the person on the line basically said my unit was out of warranty, and she couldn't help me. Only thing she would to is direct me to a local service center.
What's happening with my 5010 this time (again, this is the 3rd unit I'm on), is that on power up, the lens door will open, the blue light will come on. then a few seconds later the lens door will close, and then the red TEMP light will start to blink. After a minute or so the projector will power itself back down.
What do these symptoms point to as being the problem?
thanks.
KevinYee is offline
post #3592 of 3675 Old 02-12-2016, 08:38 PM
ptchan5's Avatar
Originally Posted by Greg P. View Post
Short version: as of 6 May 2015, Epson is providing v1.10 for the Home Cinema 5010. I can provide it to anyone who doesn't want to deal with tech support, though in my experience it was quick and entirely painless.
Long Version
I've experienced the blinking blue power LED/high fan/lamp never comes on problem a handful of times since I bought my 5010 in 2012.
Typically, I'd give up after letting it sit that way for minutes or hours, then unplugging and trying again a few times. The longest this ever went on was 3 evenings, with the projector unplugged during the day in between - eventually, it would fix itself. At least once (and maybe every time, I don't recall), I got the double blinking red, which went away after an unplug/re-plug cycle, and then everything was back to normal again.
Two weeks ago, it happened for 4 nights in a row, and I finally got annoyed enough to dig the PJ box out of storage to find the 'Private Line' card, and called Epson. Of course, I decided to do this on a Friday night, and as luck would have it, the PJ fixed itself shortly after and worked fine through the weekend (and the week since).
I ended up calling on Wednesday anyway, and was able to quickly reach a tech - they didn't even ask for the Private Line PIN, which was nice, since my warranty had expired about a year ago.
They sent me firmware version 1.10, which installed without any problems over my old v1.03. Of course, since the PJ was working normally again anyway, I won't have any idea if the new FW fixes the problem unless it happens again in the future.
The zip file they sent me--via a third-party website, "Hightail"--included the 1.10 FW, plus a PDF file with instructions, the FW updater utility, and a custom USB driver. As someone who's used computers for >25 years and written software for >15, the custom USB driver was super sketchy, as was the VB script that the updater utility required to be run first under administrator privileges to register some custom software library. (.OCX I think? I'm not on the machine I used for the upgrade right now.)
The custom USB driver lets the PJ pretend that its USB port is an old-school COM (serial) port. I guess they didn't want to spend the extra $1 or so per unit and just use the standard USB serial port emulation chip?
Anyhow, aside from the sketchy software stuff, I was able to upgrade the FW on the first try, and the PJ started up normally (as it had anyway for the last several days). The service menu now shows "110" at the end of the "P" version string, as expected. So, it would seem that 1.10 is now the latest version for the 5010 - and also the 5010e and 6010, according to the instructions PDF.
My zip did not include any release notes, however, which it sounds like is typical lately? I read through a few dozen pages of this thread, and earlier posts spoke of receiving release notes, but later posts, like the latest before this one, seemed not to have gotten them.
Regardless, if anyone wants the v1.10 firmware, send me a message and I'll forward it along. There's no way for me to tell if it fixed the problem for me, since it fixed itself before I installed the new version, but it doesn't seem to have caused any new problems of its own. I also have yet to notice any differences in behavior or picture quality between 1.03 and 1.10.
Greg, can I get the FW 1.10 sent to me? want to fix my flashing blue light on my 5010
Thanks in advance,
Peter
ptchan5 is offline
post #3593 of 3675 Old 02-14-2016, 05:07 PM
Liked: 2
Flashing blue light on home cinema 5010...again..
Hello, i posted a few months ago with a flashing blue light that was temporarily resolved by pulling and reinstalling the lamp. Well it's back and the previous troubleshooting is not correcting it this time (crossing those fingers that it wouldn't do it again didn't work ). May i get the latest 5010 FW sent to me with a link or instructions or a link as to how to update?
email: aaaand it won't let me put my email in until i post a few more times..
Thanks a ton in advance
Laramor is offline
post #3594 of 3675 Old 02-15-2016, 08:59 AM
Liked: 0
There is a really bad video here. https://www.youtube.com/watch?v=lJU0DVRYqVE
so I finally got the cable and was attempting to connect to the projector but not really sure what to do. When I open terminal how do I connect to the projector do I just turn the projector on? do I have to go into setting somewhere to connect?
Thanks in advance.
jrasch12 is offline
post #3595 of 3675 Old 02-15-2016, 06:23 PM
Liked: 2
****Laramor@gmail.com*** can i get the latest firmware for the HC 5010.
Laramor is offline
post #3596 of 3675 Old 02-24-2016, 03:53 PM
ddell's Avatar
5010E Intermittent Problem - Might Firmware Help
Hi, I have a 5010E I bought in 2012. I had an occasional problem in the early days (should have returned the unit, but didn't) where only during startup, the startup would fail, the window close, and the lamp light would go flashing red (never stop). It would shut down after about 5 minutes. If I unplugged and replugged the projector, it would start up fine. After a few instances like that, it's been working fine for years without that problem recurring, but the bulb was getting old, and needed replacing. Now that I've replaced the lamp, that same issue is happening again. Called Epson & they're no help, but they are offering to replace the bulb. Claims it's likely the unit itself, since both bulbs exhibited this behavior. . They could be right, but I'd like to try firmware since I'm still on version 101. The fact that the projector has never had an issues once starting and unpluggin an replugging seems to help makes me doubt the bulb as an issue. Also tried reseating the lamp which helped for a while as well, but it's still happening on occasion...
Advice?
David
ddell is offline
post #3597 of 3675 Old 02-24-2016, 04:23 PM
Liked: 3
How does the clarity compare to the likes of a 1080p lcd tv, is it very close?
djos333 is offline
post #3598 of 3675 Old 02-25-2016, 02:57 AM
ashyt16's Avatar
Quoted: 37 Post(s)
Depends on the size of the TV. If it's 7ft wide, very good.
ashyt16 is offline
post #3599 of 3675 Old 02-27-2016, 08:21 PM
REGEN45's Avatar
Liked: 1
I used about 5 different epson 5010 projectors and each had dust all around it's optics, it is not affecting picture qualty. Only 1 projector had rare overheating problems. But none of them ever shut down itself.
xplorar likes this.
REGEN45 is offline
post #3600 of 3675 Old 02-28-2016, 08:25 AM
kalister's Avatar
Liked: 0
Long Version
Good morning Greg,
could you please be so kind and send me the latest firmware (1.10?) for the projector.
i am not able to send you a PM as i have not enough postings within the forum...
The latest one i was able to find is the 1.09. (i failed by the way to bring the projector into upgrade mode - pressing Power on and enter on the control panel doesn´t work for me;(
maybe it is not logical for me "The following button sequence must be performed on the projector’s control panel. While holding down both the “Power ON” and “Enter” buttons on the control panel, turn the power switch ON. This will put the projector in “Download Mode”"
how can i press the power switch ON when i should press this button together with enter as well????)
thnks in regard and the best to you...
greetings from Austria
kalister
Epson 5010 (9000 in Europe)
kalister is offline
Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Pro Cinema 6010 Projector , Projectors , Epson Powerlite Home Cinema 8350 , Cpu Fan
