Official Epson PowerLite Home Cinema 5010 / 6010 thread - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
Old 02-25-2013, 09:29 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
Well, all their replacement projectors are "refurbished" so someone sent them in because they were bad for some reason. My experience is they don't really fix what was wrong with them, or even dust them off for that matter. Now that doesn't mean your projector didn't actually go bad. It could fail again. The issue is how you handle it with Epson. They may make you pay for shipping if you don't replace your projector. I would watch it carefully. My first projector took like 7 minutes to turn on so perhaps waiting 5 minutes wasn't enough. Anyway that wasn't acceptable and they exchanged that one for another with different problems, which eventually died. My third has a 1 minute startup once in a while, and terrible convergence. There is a tool in the menu that lets you pop up just two colors to see. Instructions are buried in this thread.
I would watch it as much as you can.
Good luck.
wnielsenbb is offline
Old 02-25-2013, 10:17 AM
MStanic's Avatar
Good luck.
Thanks, sorry to hear about all the problems you're having.
That's my concern though with accepting a refurb unit. I've read a few instances where the projectors are scuffed, scratched, smudged and just don't look like they were taken care of by the previous owner or Epson themselves. And that's just the outside but I've also read where the thing just doesn't work right, dust in the lense, etc. It's a coin toss really but I guess I have nothing to lose if I keep mine and just return the refurb. If it happens again, then I will just call Epson for the replacement but I'm just not sure how they will react to me not taking the refurb to begin with. I guess I can always try it out and see how it looks and performs. Just not that easy to take down and put back up without someone lending a hand. It's tight to the ceiling and makes it difficult to work with on your own. Plus, Epson wants my projector shipped back within 7 days of receiving the refurb in order to remove the temporary fund hold on my credit card.
Always a hassle when stuff goes bad. Like today, still waiting for it to be delivered so had take work off.
MStanic is offline
Old 02-25-2013, 10:06 PM
jwv651's Avatar
I turn on my 6010 today and got a error message called Cinema Filter Error. Please Contact Epson Support. I had to unplug the unit to get it working again. I just reached 400 hrs and I dread sending my projector to Epson being everything else works perfect and convergence is very good .
Joe V.
jwv651 is offline
Old 02-26-2013, 03:36 PM
MStanic's Avatar
I just recieived my refurb unit and the box was not even sealed. Only the folded tops, that come together to close on top of the box, were taped. However, they were not taped to the sides/edge of the box so this was basically an open flap. Underneath, the projector was exposed with only the plastic and foam keeping it somewhat safe. However, in looking at the projector, it looks okay and it looks new so I can't complain about that.
Either way, I am very reluctant to even replace my current one as I have a bad feeling about the way this refurb came shipped (in an unsealed box). The box even says "refurbished product" to make it even more ominous.
I think I will keep mine as it's been working fine since the issues I reported. I still have time on my warranty so if it ever becomes unuseable I will replace it with the dreaded refurb model.
What checks are you guys running for convergence?
MStanic is offline
Old 02-26-2013, 07:10 PM
musicalfox's Avatar
Quoted: 16 Post(s)
MStanic, I spoke too soon about v. 1.08 curing the flashing blue light/high fan etc. start-up symptom. I just turned on my unit today and got the same thing. Anyway, I'm going to run the issue by Epson again but, like you, I am not keen on swapping out my otherwise-good 6010. Please re-post on the thread if you learn anything new about this issue (and whether your 6010R works out).
musicalfox is offline
Old 02-27-2013, 06:17 AM
yonk's Avatar
I swapped out my original flaky 5010 for one marked "Refurbished" last week and the refurb works perfectly.  I've not checked the FW level, but it boots up quickly, all LCDs are perfectly aligned and it just all-around works/looks better than the original ever did.
YMMV
Frank
Frank Terhaar-Yonkers
Apex, NC
W4FTY
yonk is offline
Old 02-27-2013, 07:35 AM
MStanic's Avatar
yonk,
Glad your 5010 refurb worked out. Coin toss really with new or refurb and electronics in general. I can't really complain though as I've been very lucky with all of my electronics as they just work and I've never had to have a refurb replace them (knock on wood). I guess that's why I'm so reluctant with this incident.
musicalfox,
I never realized 1.08 was supposed to fix the issue that I encountered with my 6010 (blue light blinking and high fan noise with no lens cover opening...basically, unit just stuck in this mode on power up even if left ON for more than 5 minutes). Again, I encountered this issue and only upgraded to 1.08 to try and reset/recover the unit into a working state. I have never encountered this issue before (on 1.04) and have not encountered it on 1.08 since being lucky enough to have my unit recover from this state. So far so good on my end but still deciding on swapping for refurb or returning it . Should my 6010 just fizz out again or go completely wonky, then the refurb will have to be the solution.
MStanic is offline
Old 02-27-2013, 09:00 AM
yonk's Avatar
Yep, luck and persistence.  At least Epson support seems eager to please, and the whole swap process from phone call to new unit re-hung on the ceiling and running was 3 days.
Before my father-in-law retired he worked for Phillips, head of their service division.  This before everything was outsourced.  I would always buy the refurbs (getting the same as-new warranty) and save major $.  His opinion was that the refurbs (this was back when ..) were as reliable or better then new because they had actually been tested more/better.  These days, who knows ..
Good luck!
Yonk
Apex, NC
W4FTY
yonk is offline
Old 02-27-2013, 11:38 PM
musicalfox's Avatar
Quoted: 16 Post(s)
yonk,
musicalfox,
Yup, I don't know what to do. Epson Level 2 told me that 1.08 should have solved the high fan/blue flash etc. start-up symptom. Now I have asked them how we get out of that state without compromising the lifespan of the unit. (Apparently my idea of turning the unit off at the rear is not a good one, but neither would I think is allowing the fan to run at high for etermity.) So, I will monitor the situation over the next week or two and see if I will also need to request a new -R unit and/or warranty repair.
Old 03-01-2013, 11:14 AM
CrocDoc's Avatar
Guys,
I have been away for awhile, and I have a 5010 with 1.04, with around 250 hrs on it. I have the high fan/blue flash etc. problem on start up at times. I got the firmware upgrade from another forum member, but never installed it because of having to use Windows XP. Did you find a work around, or did Epson come out with a better way to install it?
CrocDoc is offline
Old 03-01-2013, 12:03 PM
drhankz's Avatar
Quoted: 84 Post(s)
Liked: 67
Originally Posted by CrocDoc View Post
Guys,
There is no work around other than some Windows 7 Ultimate Owners
have used a Virtual XP system with some luck.
The FW - any version up to 1.08 DOES NOT FIX THE PROBLEM.
drhankz is online now
Old 03-01-2013, 12:21 PM
CrocDoc's Avatar
Thanks for the reply. That was my miss understanding. I thought I read it did fix it. It sounds like the FW is still a pain to install. What is Epson saying about this issue? It is really annoying when it happens, because I have to unplug the projector for a min. When I plug it back in, all is well again. I would say it happens about every 10 power up cycles. Does this sound like what everyone else is seeing?
CrocDoc is offline
Old 03-01-2013, 12:45 PM
drhankz's Avatar
Quoted: 84 Post(s)
Liked: 67
Some End User THOUGHT it fixed it but changed his mind after he said it did.
I have no clue what Epson is saying
Old 03-01-2013, 06:06 PM
musicalfox's Avatar
Quoted: 16 Post(s)
Yes, I was the one who was originally told by Epson in an e-mail that the high fan/blue flashing symptom should be fixed by FW v. 1.08, but this FW update did not fix it. Epson also recommends not turning off or unplugging the projector when the symptom occurs. Here is a quote from Epson's e-mail to me:
"If this is a frequent occurrence, I would not recommend continuing to use the hard switch on the rear of the projector to turn it off and on again. Shutting off with the hard switch, does not allow for the projector to go through it's proper shut down process. Doing this on occasion wouldn't likely be a problem, but doing this regularly can possibly affect the life span of the projector. There is no other firmware update or workaround that I am aware of to address the issue that you have described. Unfortunately, if the projector continues to do this we will likely need to look at repairing/replacing the projector under warranty."
Old 03-01-2013, 06:18 PM
CrocDoc's Avatar
That’s good to know about the hard switch. When my 5010 goes through this high fan/blue flashing, I usually let it do its thing until the fan shuts off and I am left with just blue flashes. The only way I have found to bring it back to life is to unplug it for a minute, and then it acts normal again. Like I said, this only happens around every 10 or so power up cycles. I am not going to return it because of this, and I have just learned to accept it.
CrocDoc is offline
Old 03-02-2013, 06:08 AM
drhankz's Avatar
Quoted: 84 Post(s)
Liked: 67
One would HOPE Epson would know if it did work.
I thought it was a judgement that you made.
Thanks for the FEEDBACK.
Old 03-02-2013, 12:23 PM
Govinda's Avatar
Does anyone know how to use the 3DIMENSION command by serial cable to the TW9000?
I'm using EventGhost connected to the TW9000 by RS232 to power on and off the projector by sending the PWR command. I can also do other commands on this Epson Excel list however when sending "3DIMENSION?" I always get "ERR" as a response frown.gif
I'd like to use EventGhost to set the projector to 3D mode automatically when playing a 3D Side-by-Side movie.
Govinda is offline
Old 03-02-2013, 12:33 PM
drhankz's Avatar
Quoted: 84 Post(s)
Liked: 67
9D is the CODE for going from 2D to 3D
9E is the Code for 2D
9F is the Code for 3D
Old 03-02-2013, 03:20 PM
Govinda's Avatar
Unfortunately, those does not do what one might think. 9D-F does the same as the remote keys. That is enable or disable the possibility to use 3D Format rolleyes.gif
I could set the 3D Format to Side-by-Side then use 9D to switch between 3D on or off however this messes up the 2D mode. Using 2D while 3D Format is set to Side-by-Side does only display the left side of the image.
What I need is to set the "3D display setup" to Side-by-Side directly while leaving the 3D mode on. Then change "3D display setup" to Auto to change back to 2D. Something like 3DIMENSION 03:02 and 3DIMENSION 03:00 according to the Excel sheet:
Code:
"01:3D Display
    00:ON
    01:OFF
02:2D-to-3D Conversion
    00:ON
    01:OFF
03:3D Format
    00:Auto
    01:2D
    02:Side by Side
    03:Top and Bottom
04:3D Depth
    01:Weak
    02:Medium
    03:Strong
05:3D Brightness
    01:Low
    02:Medium
    03:High
06:3D IR Emitter
    01:Built in
    02:External
07:3D Viewing Notice
    00:ON
    01:OFF
INIT (Setting only)
I've tried different 3DIMENSION commands but they keep returning "ERR". Also the command "3DIMENSION?" returns "ERR" even though it should be "OK" according to the documentation. I guess the 3DIMENSION command is misspelled or something else isn't right.
Govinda is offline
Old 03-02-2013, 04:02 PM
drhankz's Avatar
Quoted: 84 Post(s)
Liked: 67
If you need Side by Side - there is NO KEY for that.
Old 03-02-2013, 04:02 PM - Thread Starter
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
I've had the issue a few times and when it occurs, the projector will shutdown on its own.
I then unplug the power for a minute, plug it back in, wait 5 minutes & turn it back on and it powers up normally.
*When the issue occurs, it takes the projector about 5 minutes to shutdown AFTER it closes the lens cover.
I've never had an issue where the projector is locked up, doesn't turn off and requires a hard power shutdown.
2016
42Plasmaman is offline
Old 03-02-2013, 05:49 PM
musicalfox's Avatar
Quoted: 16 Post(s)
That's great information, thanks, Plasmaman. I've also just started getting a situation where the high fan/blue light flash cycle starts, continues for about 3 minutes and then, with no further action taken, the projector just powers up normally with the on-screen Epson logo. So, maybe the lesson is to just let it run through whatever it's doing.
Old 03-07-2013, 03:04 PM
jwv651's Avatar
Well I received my replacement 6010 and there is several dust blobs and the convergence is horrible. I ended up with a second level tech and he was rude. Anyways they are sending out another unit and I pray it is better than the last replacement. mad.gif
Joe V.
jwv651 is offline
Old 03-07-2013, 04:11 PM
ashyt16's Avatar
Quoted: 37 Post(s)
Can you add your problem to the Epson problem thread?
ashyt16 is offline
Old 03-08-2013, 10:09 AM
naif1992's Avatar
In my Sony TV, I have an option called Backlight which increases the light (not the brightness) coming out of the TV making it better at day time. Is there such an option of the Epson 5010 projector? I would like to make it as bright as possible to be able to use it at day time. I currently have it on Dynamic but it still does not produce enough light to be viewable at day time. Another question, how do I find out the number of hours the projector was used for? Not lamp hours, but hours that the actual projector was used for. I remember reading about it somewhere. I have to press the menu button for a few seconds and then do something else that I can't remember to see how many hours the projector has been used for. The reason why I need to know this info is because I accidentally reset the lamp hours and now I don't know my lamp hours.
Thank you in advance.
naif1992 is offline
Old 03-08-2013, 10:30 AM
JeffreyJonesBSME's Avatar
Liked: 36
naif1992,
It sounds like your screen gain is too low for the amount of ambient light you are talking about.
What screen gain do you have currently?
"Engineers aren't boring people, we just get excited over boring things".
--Anon.
JeffreyJonesBSME is offline
Old 03-08-2013, 01:48 PM
naif1992's Avatar
How can I find out the gain of my screen?
naif1992 is offline
Old 03-08-2013, 01:50 PM
ashyt16's Avatar
Quoted: 37 Post(s)
The 5010 has Living room mode, this is the brightest then there is eco mode or full mode for lamp brightness. So for maximum brightness you would select both. Does it really matter how many hours you have done, it will fail when it fails? I am still on the original bulb of my NEC PJ after 10 years and thousands of hours and it's still bright as ever.
ashyt16 is offline
Old 03-09-2013, 06:23 AM
ashyt16's Avatar
Quoted: 37 Post(s)
If anybody is using the Panasonic glasses for these PJ's you may be interted in my repair thread incase you break your glasses: smile.gif
http://www.avsforum.com/t/1462412/panasonic-3d-glasses-repair-with-pics
ashyt16 is offline
Old 03-11-2013, 10:55 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
Dynamic is the brightest it gets. For max brightness make sure high lamp mode on and the projector is as close to the screen as you can. If you are in a bright room the best solution isn't the projector, but the screen. My Vutec Silverstar made a giant difference in high light conditions, even my wife was impressed. The SI Black Diamond is good for this too I guess.
Lamp hours don't really matter. Lamps vary quite a bit. I have had lamps last 8000 hours and the same exact model last only 1800. When it gets too dim it is time to replace.
Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Pro Cinema 6010 Projector , Projectors , Epson Powerlite Home Cinema 8350 , Cpu Fan
