Got acer K330, how the hell can i get HDMI to work? - AVS Forum | Home Theater Discussions And Reviews
Old 12-09-2011, 10:16 AM - Thread Starter
seph22's Avatar
Anyone got this projector to work with his PS3 in HD? a simple yes/no would be nice, i have tried multiple cables and all it will never work in 720p or 1080p i can only get it to work on hdmi at 480p but the screen goes crazy (weird blur/artifacts/etc) when i connect the PS3 to any other LCD it works perfectly with no issue whatsoever
So have you played PS3 on HD 720p or 1080p on the ACER K330?
seph22 is offline
Old 12-09-2011, 10:45 AM
Brioches2's Avatar
Switched off before change hdmi port?
Brioches2 is offline
Old 12-09-2011, 10:55 AM
Raine0's Avatar
Quoted: 47 Post(s)
Bad news? Sounds like a faulty hdmi connection on the unit. When I had the unit, everything worked ok. Whether the pj was on or not when I plugged in the hdmi cable, it worked fine regardless.
Raine0 is online now
Old 01-25-2012, 03:15 AM - Thread Starter
seph22's Avatar
Update: i have replaced the projector a while ago but there is a new problem, the new one works with my pc but not with my ps3
seph22 is offline
Old 08-18-2012, 02:20 AM
displaylou's Avatar
One Faulty unit may acceptable but two? OMG! get another brand, LG PA70G with same resolution but has a 700 lumens, meaning you get more 200lumens than Acer K330. Please read the "LG PA70G LED 1280x800 700 Lumens" Thread.
displaylou is offline
Old 08-18-2012, 02:48 PM
man4mopar's Avatar
What does the PS3 say when you select 720P as the resolution or is it not selectable?
man4mopar is offline
Old 09-04-2012, 08:10 PM
n1co35's Avatar
Anyone get 1080p to work on ps3? Mine can only go 1080i if I remember correctly the first time i tried my ps3 1080p was working now that I tried again it can only go to 1080i. When I check the 1080p it will try to resynch and it says input not supported on the top right.
n1co35 is offline
Old 09-04-2012, 10:12 PM
man4mopar's Avatar
Why are you trying to send a 1280 x 800 native projector 1080P? Send it 720P it will render better (Look Better) .
Old 09-04-2012, 11:05 PM
deeimpala's Avatar
No problems with 720p sent to my K330 over an Xbox 360 on cheap 30ft ebay cable. I went one step further and disabled HDMI edid in the Xbox settings menu , then I told the Xbox to send 1280x780 always over HDMI.
I also have my one and only Xbox360 connected to a 4x HDMI Splitter , that splitter then send out 4 Identical signals to two 42" lcd's , one 32" led, and my baby K330. They all accept the 1280x780 signal and scale it better then the projector can ( read FullScreen ) My projector has 10 missing pixels on the top and bottom , but I like it better that way then 720p and missing 80pix.
Yes I can watch my Xbox on all 4 TV's at the same m*therf*ckin !! time cool.gif Legal Hack tongue.gif
deeimpala is offline
