best bang for the buck - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-23-2012, 05:33 AM - Thread Starter
nikunjbhakta's Avatar
Which projector will I get the best picture quality out of? Would like to have a bright picture on about 200".
3d is optional.
nikunjbhakta is offline
post #2 of 4 Old 01-23-2012, 06:17 AM
srauly's Avatar
The Definator X-1.
Scott R
I'd much rather watch a great movie in B&W at 240 lines of resolution than a lousy movie in 1080p with lossless audio.
srauly is offline
post #3 of 4 Old 01-23-2012, 09:10 AM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
200" is pushing it , but a Panasonic AR-100u can do it in a near-best mode, you could also try a Benq w1200 or Viewsonic Pro8200 for DLP but would likely need a little gain at that screen size. Even the Epson 5010 could do it in torch modes.
The Panny ar100u does about 2000 lumens in a near best mode, and 2500 in dynamic mode.
The Viewsonic can do about 1500 lumens calibrated or 1800 in dynamic mode, and the Benq w1200 about 1000+ at closest throw and about 1500+ in dynamic mode.
There are $3000 to $5000 large venue projectors that can do it which are sort of a mix between business and home theater (more business though). Epson makes a couple, the G5450 and G5750 can do 4000/4500 lumens, about 2500/3000 calibrated to near-best modes. NEC makes one for a little more that is advertised at 5000 lumens, but not sure what the calibrated lumens are. These projectors are brighter with a bit less contrast, but they aren't horrible at contrast like some older business projectors used to be.
The Epson g5750 is probably the best one for overall brightness under $4000, but the Panny ar100u is much much cheaper and can get pretty close in a near best mode (Vivid Cinema tracks at 6400k at 2000 lumens, still not really D65 though since the gamut isn't perfect, but close enough).
Access HERE from this thread
coderguy is offline
post #4 of 4 Old 01-24-2012, 03:30 PM - Thread Starter
What about the Panasonic PT-AE7000?
