I want to buy a projector - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 51 Old 01-30-2012, 10:19 AM
man4mopar's Avatar
Originally Posted by langers_2004 View Post
Ok thanks :-)
Did you purchase official glasses or cheaper ones? There are pairs for around £35 each which seems very reasonable.
My H9500BD came with a pair of Acer glasses, then I purchased two extra pair of True Depth glasses. Any DLP link glasses will work but some hold color accuracy and black level's better then others and it varies with projector's.
I know your also researching into a way to use your IR glasses, again wish I could help but no experience/research done by me in that area either.
man4mopar is offline
post #32 of 51 Old 01-30-2012, 10:21 AM - Thread Starter
langers_2004's Avatar
Ok thanks again.
Just had a look at the acer throw distance and it doesnt seem to be as 'short' as they advertise. The optoma seems to use much less space to get a larger screen.
langers_2004 is offline
post #33 of 51 Old 01-30-2012, 11:16 AM - Thread Starter
Well just bagged one with two pairs of glasses for £560, so pretty chuffed. Couldnt really afford it but didnt want to let it get away. A week off food should be worth it :-D
post #34 of 51 Old 01-30-2012, 01:23 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Which one did you get?
Sonyad is offline
post #35 of 51 Old 01-31-2012, 01:51 PM - Thread Starter
I ended up getting the optoma gt750 :-) Used but only 44hours on the bulb so thought id go for it considering the reduction in price, two pairs of glasses are a bonus too!
post #36 of 51 Old 02-01-2012, 08:24 AM - Thread Starter
It is amazing. i cannot believe how good the screen quality is. So much better than my tv...
post #37 of 51 Old 02-01-2012, 09:35 AM
man4mopar's Avatar
Good to read, enjoy!!
post #38 of 51 Old 02-01-2012, 09:47 AM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Great news. What are you projecting on?
Sonyad is offline
post #39 of 51 Old 02-01-2012, 12:07 PM - Thread Starter
I went to Ike and bought a white blackout blind, 200 x 195 so its perfect and rolls away neatly into the ceiling.
Just tried 3D and i cant believe i was ripped off on my samsung. There are things literally hitting me in the face!
post #40 of 51 Old 02-01-2012, 12:13 PM
man4mopar's Avatar
Welcome to DLP no cross talk 3D, That and a much larger screen add's to the depth
post #41 of 51 Old 02-01-2012, 12:40 PM - Thread Starter
Very chuffed. May sell the 3d tv and get a standard plasma.
Can i sell the 3D glasses and maybe telly on here, i think the samsung glasses i have a quite rare now.
post #42 of 51 Old 02-01-2012, 01:37 PM - Thread Starter
Should also add i got 2 pairs of optoma 3d glasses with the projector. They are the dlp ones.
I want to buy some more pairs but dont want to pay a lot of money for them. Say £30-£40 a pair. They are more for when friends are round so dont need to be amazing!
post #43 of 51 Old 02-02-2012, 03:17 PM
tico2209's Avatar
there is a projector almost identical to what you mention but with native 1080p, almost 0 input lag and 3d?
tico2209 is offline
post #44 of 51 Old 02-02-2012, 08:25 PM
man4mopar's Avatar
Alright what one is that?
post #45 of 51 Old 02-03-2012, 02:34 AM - Thread Starter
Here is a ink to my post showing the set-up and my gratification.
http://www.avsforum.com/avs-vb/showt...0#post21590400
post #46 of 51 Old 02-03-2012, 10:55 AM
tico2209's Avatar
I'm between Acer 9500BD and Optoma HD33 but i'm not sure yet...
tico2209 is offline
post #47 of 51 Old 02-03-2012, 11:25 AM
man4mopar's Avatar
Ok, just so you know niether of those are 0 input lag. Both are around 30ms, which by my reading's are the best input lag times out now for 3D 1080P projecting. But that said both can only out put 24fps with 1080P 3D so most gamers go to 720P 60fps. Nothing out now that I know of will do 3D 1080P 60fps, which almost all PC gamers are after.
post #48 of 51 Old 02-03-2012, 01:12 PM
tico2209's Avatar
But for play with no problems online gears of war 3, fifa, CoD or forza with friends any of these 2 projectors will work? i'm not a prefessional gamer but i like to play about 2 hours per day online...and i'm a newbie in the projector's world.
If we remove the 3d capability, which 1080p projector is the best?
tico2209 is offline
post #49 of 51 Old 02-03-2012, 01:28 PM
man4mopar's Avatar
Well what percentage gaming/Movie or other example 25% gaming 75% Movies?
The HD33/3300 and the H9500BD are both very good 1080P projectors and excel at 3D for movie's. I have the H9500BD and played Assassins Creed Revelation with 3D and was very pleased with it.
If looking for 1080P 2D only projectors I would research into the Mitsubishi HC4000 and BenQ W6000.
But if almost 100% used for gaming online and looking for 3D gaming I would look at the Optoma GT750 and Acer H5360BD. Both of those can play PS3, 360 3D gaming and 3D Blurays. They are native 720P projectors and all games I know of on PS3 and 360 are 720P or lower so.
post #50 of 51 Old 02-03-2012, 02:17 PM
tico2209's Avatar
Maybe 50/50...i'll play around 20 hours per week (only can play at nights) and see 1080p movies on weekends with my girlfriend or family.
I have a multimedia center (HiMedia 900b) so I want to play all 1080p 3D movies and tv shows that i have but also want to play with no problems
tico2209 is offline
post #51 of 51 Old 02-03-2012, 03:02 PM
man4mopar's Avatar
Then I would say read through both the HD33/3300 thread and the H9500BD thread and make your choice. I would stay away from the Epson 3010 due to the at best 60ms input lag.
